Ищу исполнителя завершить прошивку
nero32
Всем привет! есть скетч, он не полный, мне нужно лишь решить вопрос с программой, железо я могу собрать сам.
Итак, вот ссылка на видео, в котором показана работа программы
https://youtu.be/AYJJvmFzb14
вот скетч
#include "LedControl.h"
pin 12 DataIn
pin 11  CLK
pin 10 LOAD
Two MAX7221's
LedControl lc=LedControl(12,11,10,2);
//buttons and inputs
const int button0 = A0;
const int button1 = A1;
const int button2 = A2;
const int button3 = A3;
const int pot1 = A4;
const int greenpin = 5; //green LED
const int redpin = 6; //red LED
const int yellowpin = 8; //yellow LED
const int emitters = 3; //emitters are connected in serial
const int speaker = 4; //piezo
const int colons =  13; //colons are connected in serial
unsigned long totalsectime = 35; //this value is the beginning countdown time
//totalsectime will later be filled in by time set function by inputs
 randomSeed(analogRead(A5)); //sets pin A5 as an input to generate a random number
 pinMode(colons, OUTPUT);
 pinMode(speaker, OUTPUT);
 pinMode(emitters, OUTPUT);
 pinMode(button0, INPUT);
 pinMode(button1, INPUT);
 pinMode(button2, INPUT);
 pinMode(button3, INPUT);
 pinMode(pot1, INPUT);
 pinMode(greenpin, OUTPUT);
 pinMode(redpin, OUTPUT);
 pinMode(yellowpin, OUTPUT);
 // number of devices LedControl
 int devices=lc.getDeviceCount();
 //init all devices in a loop
 for(int address=0;address<devices;address++) {
   //take out of power saving mode
   lc.shutdown(address,false);
   // set brightness - depends on Rset values
   lc.setIntensity(0,15);
   lc.setIntensity(1,1);
   /* and clear the display */
   lc.clearDisplay(address);
   //sets the number of digits that each 7221 will scan through when multiplexing
   lc.setScanLimit(0, 6);
   lc.setScanLimit(1, 6);
//COLON BLINK FUNCTION for normal countdown 2 blink/second
int colonsState = LOW;
long previouscolonsMillis = 0;
long colonsinterval = 250;
void colonBlink(){
 unsigned long currentcolonsMillis = millis();
 if(currentcolonsMillis - previouscolonsMillis > colonsinterval) {
   // save the last time you blinked the LED
   previouscolonsMillis = currentcolonsMillis;
   // if the LED is off turn it on and vice-versa:
   if (colonsState == LOW)
     colonsState = HIGH;
     colonsState = LOW;
   // set the LED with the ledState of the variable:
   digitalWrite(colons, colonsState);
//GENSER SEQUENCE PREAMBLE
void genserOne() {
 //GEnSEr
 //G
 lc.setRow(0,0,B01011110);
 //E
 lc.setChar(0,1,'E',false);
 //n
 lc.setRow(0,2,0x15);
 //S(5)
 lc.setChar(0,3,'5',false);
 //E
 lc.setChar(0,4,'E',false);
 //r
 lc.setRow(0,5,0x05);
 delay(400);
 //clear
 lc.clearDisplay(0);
 delay(40);
 //random 1
 lc.setRow(0,0,B01001001);
 lc.setRow(0,1,B00010101);
 lc.setRow(0,2,B00100011);
 lc.setRow(0,3,B00000011);
 lc.setRow(0,4,B01010100);
 lc.setRow(0,5,B01000011);
 delay(200);
 //clear
 lc.clearDisplay(0);
 delay(40);
 //CAluri
 //C
 lc.setRow(0,0,B01001110);
 //A
 lc.setChar (0,1,'A',false);
 //l(lowercase "L")
 lc.setRow(0,2,B00110000);
 //u
 lc.setRow(0,3,B00011100);
 //r
 lc.setRow(0,4,B00000101);
 //i
 lc.setRow(0,5,B00010000);
 delay(200);
 //clear
 lc.clearDisplay(0);
 delay(40);
 //4th Sequence
 lc.setRow(0,0,B00100011);
 lc.setRow(0,1,B00000011);
 lc.setRow(0,2,B01010100);
 lc.setRow(0,3,B01000011);
 lc.setRow(0,4,B00010011);
 lc.setRow(0,5,B00011001);
 delay(200);
 //clear
 lc.clearDisplay(0);
 delay(40);
 //Second CAluri sequence
 //C
 //A
 //l(lowercase "L")
 //u
 //r
 //i
 delay(200);
 //clear
 lc.clearDisplay(0);
 delay(40);
 //6th Sequence
 lc.setRow(0,0,B00101010);
 lc.setRow(0,2,B00011010);
 lc.setRow(0,3,B01001000);
 lc.setRow(0,4,B01000001);
 lc.setRow(0,5,B01001001);
 delay(200);
 //clear
 lc.clearDisplay(0);
 delay(40);
 //6th Sequence
 lc.setRow(0,0,B00010011);
 lc.setRow(0,1,B00011001);
 lc.setRow(0,2,B00100010);
 lc.setRow(0,3,B00011000);
 lc.setRow(0,5,B00100101);
 delay(250);
 //clear
 lc.clearDisplay(0);
 delay(75);
void displayFade() {
 //clear
 delay(100);
 //INSERT FUNCTION FOR DIGIT FADING AFTER ZERO
 lc.setRow(0,0,B01111000);       //partially zapped 0
 lc.setRow(0,1,B01111110);       //0
 lc.setRow(0,2,B01111110);       //0
 lc.setRow(0,3,B01111110);       //0
 lc.setRow(0,4,B01111110);       //0
 lc.setRow(0,5,B00011110);       //partially zapped 0
 delay(30);
 lc.setRow(0,0,B00110000);       //partially zapped 0
 lc.setRow(0,4,B10000000);       //0
 lc.setRow(0,5,B00000110);       //partially zapped 0
 delay(30);
 lc.setRow(0,0,B00000000);       //fully zapped 0
 lc.setRow(0,5,B00000000);       //fully zapped 0
 delay(30);
 lc.setRow(0,1,B01111000);       //partially zapped 0
 lc.setRow(0,4,B01000000);       //partially zapped 0
 delay(30);
 lc.setRow(0,1,B00110000);       //partially zapped 0
 lc.setRow(0,4,B00000110);       //partially zapped 0
 delay(30);
 lc.setRow(0,1,B00000000);       //fully zapped 0
 lc.setRow(0,4,B00000000);       //fully zapped 0
 delay(55);
 lc.setRow(0,2,B01111000);       //partially zapped 0
 lc.setRow(0,3,B01000000);       //partially zapped 0
 delay(30);
 lc.setRow(0,2,B00110000);       //partially zapped 0
 lc.setRow(0,3,B00000110);       //partially zapped 0
 delay(30);
 lc.setRow(0,2,B00000000);       //fully zapped 0
 lc.setRow(0,3,B00000000);       //fully zapped 0
void displayWrap() {
 //INSERT DISPLAY WRAP
 delay(40);
 lc.setRow(0,0,B00000010);
 lc.setRow(0,1,B00000010);
 lc.setRow(0,2,B00000010);
 lc.setRow(0,3,B00000010);
 lc.setRow(0,4,B00000010);
 lc.setRow(0,5,B00000010);
 delay(40);
 lc.setRow(0,0,B01000000);
 lc.setRow(0,1,B01000000);
 lc.setRow(0,2,B01000000);
 lc.setRow(0,5,B01000000);
 delay(40);
 lc.setRow(0,0,B00100000);
 lc.setRow(0,1,B00100000);
 lc.setRow(0,2,B00100000);
 lc.setRow(0,3,B00100000);
 lc.setRow(0,4,B00100000);
 lc.setRow(0,5,B00100000);
 delay(40);
 lc.setRow(0,0,B00010000);
 lc.setRow(0,1,B00010000);
 lc.setRow(0,2,B00010000);
 lc.setRow(0,3,B00010000);
 lc.setRow(0,4,B00010000);
 delay(40);
 lc.setRow(0,0,B00001000);
 lc.setRow(0,1,B00001000);
 lc.setRow(0,2,B00001000);
 lc.setRow(0,3,B00001000);
 lc.setRow(0,4,B00001000);
 lc.setRow(0,5,B00001000);
 delay(40);
 lc.setRow(0,0,B00000100);
 lc.setRow(0,1,B00000100);
 lc.setRow(0,2,B00000100);
 lc.setRow(0,3,B00000100);
 lc.setRow(0,4,B00000100);
 lc.setRow(0,5,B00000100);
 delay(40);
 delay(40);
 delay(40);
 delay(40);
 delay(40);
 delay(40);
 delay(40);
 delay(40);
 lc.setRow(0,0,B00000001);
 lc.setRow(0,1,B00000001);
 lc.setRow(0,2,B00000001);
 lc.setRow(0,3,B00000001);
 lc.setRow(0,4,B00000001);
 lc.setRow(0,5,B00000001);
void updatespeaker(){
 static int state = 0;
 static unsigned int beeptime = 250;
 static unsigned int sinterval = 500;
 static unsigned int freq = 2500;
 static unsigned long lasttimeon = 0;
 unsigned long m = millis();
 if (state == -1){
   lasttimeon = m;
   state = 1;
   tone(speaker,1000);
   noTone(speaker);
   tone(speaker,1000);
   return;
 if (state == 0){
   if (m >= lasttimeon +sinterval){
     state = 1;
     tone(speaker,freq);
     lasttimeon = m;
   return;
 if (state == 1){
   if (m >= lasttimeon + beeptime){
     noTone(speaker);
     state = 0;
     beeptime = 100;
   return;
//setting up seconds time conversion
#define secondsinaday 86400  //((60*60)*24)
#define secondsinhour 3600  //(60*60)
#define secondsinminute 60
long countpreviousMillis = 0;   //stores count milliseconds
long countinterval = 1000; //1 second
void displayDate(){
 unsigned long countcurrentMillis = millis();
 if(countcurrentMillis - countpreviousMillis > countinterval) {
   // save the last time counted
   countpreviousMillis = countcurrentMillis;
   totalsectime--; //decrement of 1 second
   unsigned long sectime = totalsectime;
   /*takes the totalsectime variable and converts it inside of this function
   so that the time conversions do not interfere with the later functions */
   unsigned long days = sectime/secondsinaday; //calculates seconds in a day
   sectime = sectime % secondsinaday; //takes the remainder of the previous calculation
   unsigned long hours = sectime/secondsinhour; //calculates seconds in an hour
   sectime = sectime % secondsinhour; //takes the remainder of the previous calculation
   unsigned long minutes = sectime/secondsinminute; //calculates seconds in a minute
   unsigned long seconds = sectime % secondsinminute; //takes the remainder, and that is seconds
/*below takes the values generated from above and makes variables for each digit to display
based on on dividing the values by hundreds/tens/single numbers*/
   unsigned long days_hundreds = days/100;
   unsigned long days_tens = (days %100)/10;
   unsigned long days_units = (days %100)%10;
   unsigned long hours_tens = (hours %100)/10;
   unsigned long hours_units = (hours %100)%10;
   unsigned long minutes_tens = (minutes %100)/10;
   unsigned long minutes_units = (minutes %100)%10;
   unsigned long seconds_tens = (seconds %100)/10;
   unsigned long seconds_units = (seconds %100)%10;
//below is where the magic happens
//sends digit to: 7221 device
//digit order
//variable from above calculations
//true/false for the decimal point
   lc.setDigit(1,0,days_hundreds,false);
   lc.setDigit(1,1,days_tens,false);
   lc.setDigit(1,2,days_units,false);
   lc.setDigit(0,0,hours_tens,false);
   lc.setDigit(0,1,hours_units,false);
   lc.setDigit(0,2,minutes_tens,false);
   lc.setDigit(0,3,minutes_units,false);
   lc.setDigit(0,4,seconds_tens,false);
   lc.setDigit(0,5,seconds_units,false);
   if(sectime==15){   //wrap-around when time reaches 15 seconds
     displayWrap();
   if(totalsectime <=5 ) {   //lights emitter LEDs when time reaches 5 seconds and keeps speaker solid
     updatespeaker();
     digitalWrite(emitters, HIGH);
   else{
     digitalWrite(emitters, LOW);
   /*Below is the "reset" mode that I have worked out right now, but is due to change
   as I get more things sorted out, and this will do other things. Right now is just
   for testing/looks.*/
   if(totalsectime <= 0){
     delay(2500);
     displayFade();
     genserOne();
     displayWrap();
     updatespeaker();
     totalsectime = random(16756131);
 if(totalsectime > 5){   //colon blink function for normal countdown
   colonBlink();
   updatespeaker();
 displayDate();
Мне нужно добавить несколько кнопок к этой программе, и заставить светодиоды мигать, вообщем это чисто игрушка, но мне очень важно воссоздать ее. Если кто то смотрел сериал в 90х тот наверно узнает вот такое устройство.
https://www.youtube.com/watch?v=708JIPJzye8&index=3&list=FL85QeCTfcOIuDtsZerr5gOA&t=56s
Вообщем кто возьмется сделать напишите!
karamzin01
р е а л и з у е м о - maslachenko767@mail.ru , консультации, подбор компонентов бесплатно, гарантии
nero32
Написал на почту!
nero32
Человек не отвечает, ищу дальше исполнителя!
rst
Это не человек, это бот. Он тут всюду.
nero32
rst пишет:
классссс....
Если не срочно, то могу поковырять. wrk.sadman@gmail.com
Онлайн
sadman41 пишет:
Садман, там просто поковырять мало - там "всю систему менять надо". ИМХО, типичная задачка "помогите выйти из цикла" :)
rst
"Ковыряние" такого говнокода должно стоить дороже чем переписывание с нуля. имха.
Так что думаю, что садман просто хочет заработать по-больше. таков бизнес-план  ;)
nero32
rst пишет:
я не против переписания кода с нуля, тем более на видео все показано...
Дмитрий Бардынин
Неро32, каков бюджет?
nero32
да я даже понятия не имею сколько это стоит. предлагайте!
$100
nero32
Я не торгуюсь, но хочу высказать своё мнение, как бы за эту сумму я могу встроить в схему отдельно ну например  attiny 13 и реализовать на ней включение и выключение схемы, а мигание шкалой светодиодов может заняться например пара микросхем к примеру 555 и счётчик, ну это я так, к слову о 100 баксах. Я никого не третирую, каждый сам оценивает свою работу, возможно это того стоит, но все должно быть соизмеримо.
Цену услышал, подожду ещё!
Онлайн
nero32 пишет:
если сами можете - почему не делаете?
А чтоб оценить стоимость - прикиньте, за сколько вы бы согласились выполнить встраивание тиньки для кого-то еще... Это всегда очень по разному воспринимается - когда для себя делаешь и когда для чужого дяди
И потом - исполнителю ведь понадобится с десяток семисегментных индикаторов и светодиодна шкала для тестов - вы их в цену включили или нет?
Вы сами-то на сколько расчитывали? если вместо 100 баксов готовы за 80 - подождите, может кто и найдется. А если вы ожидали 20 - то делайте сами. вряд ли кто-то возьмется, тут только чтоб утрясти с вами ТЗ - больше времени потратишь. чем заработаешь :)
А говорит, что не знает что почём. Вона как соображалка сразу заработала =))
Gas311
Gas311 аватар
nero32 пишет:
Ну зачем там тиньки? Всё на ардуине можно сделать
nero32
b707 пишет:
nero32 пишет:
вижу эту работу примерно 5000р! Железо в Протеус собрать нельзя для проверки ?
Gas311
Gas311 аватар
Почему же нельзя?
Дмитрий Бардынин
За 5т.р. объясню Вам, как работает эта программа, и Вы сами сможете добавлять светодиоды и кнопки. Но железо должно быть собрано и работать с предложенной прошивкой. Этапов будет несколько, и оплата будет частями. Но готовое рабочее железо - условие старта.
Gas311
Gas311 аватар
Так он в протеусе соберёт.
brokly
brokly аватар
Что то мне это напоминает.... Пару лет назад, для каких то квестов, что то похожее лепил. Клиенту тогда результат в протеусе показывал :) Но такой код, я точно написать не мог бы, слишком сложно :(
ALEGYR
nero32 пишет:
Соизмеримо с чем? С тем что не можешь (или не хочешь) купить в магазине, или с тем что тебе очень хочется поиметь игрушку,  но не очень хочется самому париться с ней и тратить на нее СВОЕ время?
Твои 5 000 рублей это стоимость двух рабочих дней специалиста средней квалификации! И это при условии что ты ему даешь полное ТЗ! У тебя же только одни фантазии и мечты, реазизация которых может растянуться не на пару дней, а на пару недель!!! За 5000 рублей, две недели даже гости из ближнего зарубежья не работают!!!
nero32
ALEGYR пишет:
nero32 пишет:
Вы больше болтавней занимаетесь! поэкономьте пожалуйста своей время.
brokly
brokly аватар
Это не болтовня.Вам объяснили как формируется цена . Но если вам лень вдуматься в написанное, то это ваши проблемы. Никто вам ничего не сделает. Попробуйте сначала написать вменяемое тз. Может тогда и найдете кого то.
Онлайн
nero32 пишет:
ну блин... о чем спор-то? 6500 (100 баксов) - это дорого, а 5 тыр нормально?
Детский сад какой-то....
если еще не пропало желание что-то заказывать - скиньте мне подробное ТЗ на ded собака cur-ex.ru, может и договоримся
nero32
b707 пишет:
nero32 пишет:
вот, именно вам и напишу !
Вот и пойми - как они исполнителя выбирают ))
DetSimen
DetSimen аватар
sadman41 пишет:
Интуицея
Kakmyc
Сделаю за 5
kakmycmail@gmail.com
nero32
Kakmyc пишет:
Сделаю за 5 kakmycmail@gmail.com
Хорошо, я уже написал предыдущему исполнителю, если у нас с ним не сложится работа, напишу вам.
