Нужно подкорректировать код
Aidos Sadak
Собрал вендинговый аппарат воды из реле, монетоприемника HX-616, датчика расхода воды YF-S201. Мой код не работает, нужно подкорректировать код или при необходимости, полностью переписать.
#include <LCD_1602_RUS.h>
LCD_1602_RUS lcd(0x27, 16, 2);
int coinpin=2;
int relay = 13;
int start_stop = 8;
const int sensor_pulse =12;
volatile int pulse = 0;
volatile unsigned long timelastPulse = 0;
boolean coinInsert = false;
int buttonState = 0;
int credits = 0;
boolean currentstart_stop = LOW;
boolean laststart_stop =LOW;
boolean lastsensor_pulse = LOW;
boolean currentsensor_pulse = LOW;
boolean relayState = LOW;
float cal = 2.5;
float counter = 0.0;
int TotalCount = 0;
int set_point = 0;
void setup(){
  pinMode(relay, OUTPUT);
  pinMode(coinpin,INPUT_PULLUP);
  lcd.init();
  lcd.backlight();
boolean debounce(boolean last, int pin)
boolean current = digitalRead(pin);
if (last != current)
delay(5);
return current;
void loop(){
  currentstart_stop = debounce(laststart_stop, start_stop);
  currentsensor_pulse = debounce(lastsensor_pulse, sensor_pulse);
  if (currentstart_stop == HIGH && laststart_stop == LOW){
    if (relayState == HIGH){
      digitalWrite(relay, LOW);
      relayState = LOW;
    else{
      digitalWrite(relay, HIGH);
      relayState = HIGH;
  laststart_stop = currentstart_stop;
if(relayState == LOW){
attachInterrupt(digitalPinToInterrupt(coinpin),coinInterrupt,FALLING);
 unsigned long lastTime = millis() - timelastPulse;
 if((pulse > 0) && (lastTime > 24)){
  coinInsert = false;
  credits += pulse;
  pulse = 0;
if (credits == 1){
    set_point = set_point +500;
else if  (credits == 2){
    set_point = set_point +1000;
else if  (credits == 3){
    set_point = set_point +1500;
else if  (credits == 4){
    set_point = set_point +2000;
else if  (credits == 5){
    set_point = set_point +2500;
else if  (credits == 6){
    set_point = set_point +3000;
else if  (credits == 7){
    set_point = set_point +3500;
else if  (credits == 8){
    set_point = set_point +4000;
else if  (credits == 9){
    set_point = set_point +4500;
else if  (credits == 10){
    set_point = set_point +5000;
else {
  set_point = 0;
counter = 0;
TotalCount = 0;
  if(relayState == HIGH){
  if (lastsensor_pulse== LOW && currentsensor_pulse == HIGH){
      counter = counter + cal;
 lastsensor_pulse = currentsensor_pulse;
if(counter >= 10){
  TotalCount = TotalCount + 10;
  counter = 0;
 lcd.setCursor(3, 0);
 lcd.print(set_point);
 lcd.setCursor(4, 1);
 lcd.print(TotalCount);
 if(set_point <= TotalCount){
  relayState = LOW;
  TotalCount=0;
  counter=0;
void coinInterrupt(){
  pulse++ ;
  timelastPulse = millis();
man9913
3тр, если монетник рабочий и подключен правильно
man9913@mail.ru
