Arduino uno перестала прошиваться
Сб, 04/02/2017 - 19:44
Всем привет!
Arduino uno работало нормально, но в один прекрасный момент перестали заливаться скетчи.
Заливал через USB, программер AVRISP mkII.
Драйвера переустанавливал, порт тоже менял.
Пожалуйста помогите, как оживить?
Arduino: 1.7.11 (Windows XP), Плата"Arduino Uno" Sketch uses 450 bytes (1%) of program storage space. Maximum is 32 256 bytes. Global variables use 9 bytes (0%) of dynamic memory, leaving 2 039 bytes for local variables. Maximum is 2 048 bytes. avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x60 Проблема загрузки на плату. Для достижения дзен, курить http://www.arduino.cc/en/Guide/Troubleshooting#upload .
если заливали програматором через ISP, то затерли загрузчик, подключите програматор и запишите загрузчик
Пожалуйста по подробнее
Выполнить в оболочке IDE: Инструменты - Записать Загрузчик
Вопрос? А вы где такую версию скачали? Замените на 1.8.1
Ты определись, через USB заливаешь или через программатор AVRISP mkII?
В Arduino Uno Есть USB, туда подключаюсь и заливал скетчи. Может нечайно сменил программер и щас туплю? поправьте если что то не правильно
Сейчас попробую
Ясно, значит программатора нет.
Эта настройка на загрузку через USB не влияет, она для программатора.
Какие драйвера и откуда брал? В диспетчере устройств при подключении COM-порт появляется? А при отключении пропадает?
При отключении пропадает.
USB-Serial CH340
PS: скорость порта менял на 115200
