I need Help Arduino Ethernet Shiled and SD Card reading
wtrk
Hi everyone. I dont read crylic and sorry if wrong section this topic.
I want to make a project with arduino  and need your helps.
I have arduino uno and want to take  values of some sensors on online waching the web server far away with LAN connection.
ALso these values want to save in SD card and anytime anywhere want to reach with IP in our network.
Basicly reading sensor values and save this values in SD card on the ethernet Shield. After that same time online monitoring  this values and access SD card datas.
Онлайн
Hi, wtrk
Sorry, but this is cyrillic only forum.
There are a lot examples for "web-managed arduino" in Google, especially on english.
WBR
Alexander
Hi,
It is almost 100% Russian-speaking forum. Not sure if anybody here is ready to help you with your idea, basis you are looking for help in English only.
Basically rule of thumb here is that you should show what you've already done, what have your tried and what is not working if you are looking for help. Ataching some code if any.
On the other hand if you a looking for someone to make your project from scratch (freelancer), you need this section http://arduino.ru/forumy/ishchu-ispolnitelya . Please give more technical details, your budget, payment type (e.g. Paypal) and some kind of contacting details, so freelancers can contact you directly
DetSimen
DetSimen аватар
goto arduino.cc/forum
wtrk
Thanks for your answers. I dont bother crylic just wanted to say which forum Im not sure.
Yes I can find some example on the web and forum but didnt collect codes which is I need exactly.
if someone who know I explained my idea please share me about codes
DIYMan
DIYMan аватар
Та ладна, типа ВНЕЗАПНО сюда принесло т-ща импортного? не-ве-рю. Я быстрее поверю, что это новый способ выманивать готовый код :)
Я даже по-аглицки не буду утруждаться, просто напишу товарищу: у меня есть готовый код для того, что описано. Проверенный, выдаёт страницу с таблицей показаний за указанный интервал времени, есть фильтрация по датам. Работает под W5100, данные сохраняются на SD. Стоимость - 5 000 рублей, с учётом того, что надо будет допилить под твои датчики. Устроит - пиши.
Alexander
Человек из Турции.
DIYMan
DIYMan аватар
Alexander пишет:
Человек из Турции.
Ну значит, переведёт гугль-транслейтом сразу на турецкий :)
Онлайн
DIYMan пишет:
Alexander пишет:
Человек из Турции.
он тебе счас ответит, что не может заплатить в рублях, но готов перевести тысячу долларов, если ты сообщишь ему номер и CVV своей кредитки :)
negavoid
Тoлькo этoт чeлoвeк не пеpевoдuт гyглoм, а пuшeт caм, неyжтo нe вuдaть по aшuпкам?
Maaaan, nobody here would share codes for free. You have two options - ask strictly pointed short questions with samples you've done, and you will get help easily, or just hire somebody using corresponding thread.
wtrk
DIYMan пишет:
Is it possible to write English ?
Alexander
You can use google translate.
DIYMan is offering you his working code plus coding some adjustments matching your sensors you will need. He wants 5000 Rub (about USD 90, about 338 Turkinsh Lira)
Please see my comment above regarding the way this forum works
trembo
trembo аватар
It's a forum for Olympic Programmers from Russia
