Помогите пожалуйста новичку
kizyaevvalik
#include <Arduino.h>
#include <AccelStepper.h>
AccelStepper mystepper(1, 5, 4);
int data;
int data1;
int coefi = 8;
void  setup () {
    Serial.begin (115200);
    mystepper.setMaxSpeed(5000);
    mystepper.setAcceleration(800);
void  loop () {
     stepButton();
void stepButton(){
  if  (Serial.available()) {
        data1 = Serial.read();
        data = Serial.parseInt()-'0';
        Serial.println(data);
         if (data1=='X'){
          //mystepper.setSpeed(9000);
          mystepper.setCurrentPosition(0);
          mystepper.runToNewPosition(data);
        if  (data1 ==  'E') {
          mystepper.runToNewPosition(2500*coefi);
        if  (data1 ==  'J') {
          mystepper.runToNewPosition(-5000*coefi);
        if  (data1 ==  'B' ) {
          mystepper.setSpeed(-9000);
          mystepper.runToNewPosition(-1000*coefi);
        if(data1 == 'C'){
          mystepper.runToNewPosition(-2500*coefi);
        if(data1 == 'D'){
          mystepper.runToNewPosition(5000*coefi);
Код C#
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.IO.Ports;
using System.Diagnostics;
using AngleSharp.Text;
//using System.Windows.Documents;
namespace WindowsFormsApp2
    public partial class Form1 : Form
        bool isConnected = false;
        public Form1()
            InitializeComponent();
        private void button1_Click(object sender, EventArgs e)
            comboBox1.Items.Clear();
            string[] portnames = SerialPort.GetPortNames();
            if (portnames.Length == 0)
                MessageBox.Show("COM PORT not found");
            foreach (string portName in portnames)
                comboBox1.Items.Add(portName);
                Console.WriteLine(portnames.Length);
                if (portnames[0] != null)
                    comboBox1.SelectedItem = portnames[0];
        private void connectToArduino()
            isConnected = true;
            string selectedPort = comboBox1.GetItemText(comboBox1.SelectedItem);
            serialPort1.PortName = selectedPort;
            serialPort1.Open();
            button2.Text = "Disconnect";
        private void disconnectFromArduino()
            serialPort1.Close();
            button2.Text = "Connect";
        private void Form1_FormClosing(object sender, FormClosingEventArgs e)
            // При закрытии программы, закрываем порт
            if (serialPort1.IsOpen) serialPort1.Close();
        private void button2_Click(object sender, EventArgs e)
            if (!isConnected)
                connectToArduino();
                disconnectFromArduino();
        private void button3_Click(object sender, EventArgs e)
            if (isConnected)
                if (checkBox1.Checked)
                   serialPort1.Write("X");
                if (checkBox2.Checked)
                    serialPort1.Write("E");
                if (checkBox3.Checked)
                    serialPort1.Write("J");
        private void button4_Click(object sender, EventArgs e)
             if(checkBox1.Checked)
                serialPort1.Write("B");
                serialPort1.Write("C");
                serialPort1.Write("D");
        private void button5_Click(object sender, EventArgs e)
            string[] lines = richTextBox1.Text.Split('\n');
            foreach (string s in lines)
                serialPort1.Write(s);
            private void Form1_Load_1(object sender, EventArgs e)
        private void richTextBox1_TextChanged(object sender, EventArgs e)
kizyaevvalik
Привет всем.Помогите пожалуйста новичку.Не могу понять в чем проблема. В общем отправляю на ардуино нано код типа X1000 и так много раз, но в прекрасный момент код перестает исполняться и шаговый двигатель останавливается на 13 строчке кода. Использую ардуино нано, шд Nema 17, С# VB.NET.
kizyaevvalik
Может как то буфер переполняется я ХЗ?
kizyaevvalik
xDriver
xDriver аватар
в 25 строке что происходит?
kizyaevvalik
Считывает числовые данные
kizyaevvalik пишет:
ага, считало оно, положим 1000, а потом вычло '0' ?
xDriver
xDriver аватар
a "-'0'" в конце, это че?
kizyaevvalik
без -0 точно так же останавливается на 13 строчке
Это типо чтобы не переводило по ASCII таблице. А какое ты значение ввел такое и пришло на ардуино. По моему так. не судите строго я новичек
kizyaevvalik пишет:
Это в принципе невозможно, чтобы код до этого исполнялся, а потом остановился на 13 строке. 13 строка - это setup(). код исполняет ее при старте ардуино, один единственный раз задолго до того, как принимает что-то по Сериал
xDriver
xDriver аватар
b707 пишет:
kizyaevvalik пишет:
лучше задать вопрос так - как вы определяете, что останавливается на 13 строчке?
kizyaevvalik
Нет. Вы не так поняли. Останавивается на 13 строчке моего типо G-code. Тоисть я посылаю команды X1000 много раз вот 13 раз X1000 исполняет а остальные команды нет
kizyaevvalik пишет:
ничего не понял, простите. 13 раз исполняется? или на 13-й строке останавливается? а эта 13-ая строка всегда разная или одна и та же? может в самой этой строке дело, а не в коде?
kizyaevvalik
Строчки кода могут быть разные но всегда исполняет только 13 строчек
kizyaevvalik
Я пробовал через монитор порта в ардуино посылать X1000. Но ни каких проблем не было
а в вашем окошке для кода richTextBox1 в виндовой программе - случайно не 13 строчек?
kizyaevvalik
как раз нет я намного больше туда вписывал
kizyaevvalik пишет:
не, ну может оно у вас отсылает только 13 строк?
Попробуйте написать простенькую программу для ардуинки, которая просто считала бы все пришедшие строчки
kizyaevvalik
А как я увижу что на ардуинку приходит если у меня порт уже занят отправкой данных?
kizyaevvalik пишет:
много вариантов - подключить к ардуине экранчик, или вывести на другой USB порт через внешний USB-UART переходник, например
kizyaevvalik
Понял.Спасибо.Попробую.
Morroc
Онлайн
Есть снифферы порта. На комп поставьте и смотрите обмен.
