Управляемая ШИМ - синусоида
questioner
Всем привет. Очередной новичек с кучей вопросов. Для управления мосфетом нужна шим-синусоида с управляемой частотой (потенциометр).
Нашел статью с готовы кодом http://cxem.net/arduino/arduino16.php , решение мне подходит, но компилятор выдает ошибку:
Arduino: 1.6.9 (Windows 7), Плата:"Arduino Nano, ATmega328"
sketch_jun11a:15: error: 'prog_uchar' does not name a type
 PROGMEM  prog_uchar sine256[]  = {
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28:0,
                 from sketch\sketch_jun11a.ino.cpp:1:
C:\Users\1\Documents\Arduino\sketch_jun11a\sketch_jun11a.ino: In function 'void __vector_9()':
sketch_jun11a:113: error: 'sine256' was not declared in this scope
   OCR2A=pgm_read_byte_near(sine256 + icnt);
                Код:
 * DDS Sine Generator mit ATMEGS 168
 * Timer2 generates the  31250 KHz Clock Interrupt
 * KHM 2009 /  Martin Nawrath
 * Kunsthochschule fuer Medien Koeln
 * Academy of Media Arts Cologne
#include "avr/pgmspace.h"
// table of 256 sine values / one sine period / stored in flash memory
  127,130,133,136,139,143,146,149,152,155,158,161,164,167,170,173,176,178,181,184,187,190,192,195,198,200,203,205,208,210,212,215,217,219,221,223,225,227,229,231,233,234,236,238,239,240,
  242,243,244,245,247,248,249,249,250,251,252,252,253,253,253,254,254,254,254,254,254,254,253,253,253,252,252,251,250,249,249,248,247,245,244,243,242,240,239,238,236,234,233,231,229,227,225,223,
  221,219,217,215,212,210,208,205,203,200,198,195,192,190,187,184,181,178,176,173,170,167,164,161,158,155,152,149,146,143,139,136,133,130,127,124,121,118,115,111,108,105,102,99,96,93,90,87,84,81,78,
  76,73,70,67,64,62,59,56,54,51,49,46,44,42,39,37,35,33,31,29,27,25,23,21,20,18,16,15,14,12,11,10,9,7,6,5,5,4,3,2,2,1,1,1,0,0,0,0,0,0,0,1,1,1,2,2,3,4,5,5,6,7,9,10,11,12,14,15,16,18,20,21,23,25,27,29,31,
  33,35,37,39,42,44,46,49,51,54,56,59,62,64,67,70,73,76,78,81,84,87,90,93,96,99,102,105,108,111,115,118,121,124
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
int ledPin = 13;                 // LED pin 7
int testPin = 7;
int t2Pin = 6;
byte bb;
double dfreq;
// const double refclk=31372.549;  // =16MHz / 510
const double refclk=31376.6;      // measured
// variables used inside interrupt service declared as voilatile
volatile byte icnt;              // var inside interrupt
volatile byte icnt1;             // var inside interrupt
volatile byte c4ms;              // counter incremented all 4ms
volatile unsigned long phaccu;   // pahse accumulator
volatile unsigned long tword_m;  // dds tuning word m
  pinMode(ledPin, OUTPUT);      // sets the digital pin as output
  Serial.begin(115200);        // connect to the serial port
  Serial.println("DDS Test");
  pinMode(6, OUTPUT);      // sets the digital pin as output
  pinMode(7, OUTPUT);      // sets the digital pin as output
  pinMode(11, OUTPUT);     // pin11= PWM  output / frequency output
  Setup_timer2();
  // disable interrupts to avoid timing distortion
  cbi (TIMSK0,TOIE0);              // disable Timer0 !!! delay() is now not available
  sbi (TIMSK2,TOIE2);              // enable Timer2 Interrupt
  dfreq=1000.0;                    // initial output frequency = 1000.o Hz
  tword_m=pow(2,32)*dfreq/refclk;  // calulate DDS new tuning word
  while(1) {
     if (c4ms > 250) {                 // timer / wait fou a full second
      c4ms=0;
      dfreq=analogRead(0);             // read Poti on analog pin 0 to adjust output frequency from 0..1023 Hz
      cbi (TIMSK2,TOIE2);              // disble Timer2 Interrupt
      Serial.print(dfreq);
      Serial.print("  ");
      Serial.println(tword_m);
   sbi(PORTD,6); // Test / set PORTD,7 high to observe timing with a scope
   cbi(PORTD,6); // Test /reset PORTD,7 high to observe timing with a scope
// timer2 setup
// set prscaler to 1, PWM mode to phase correct PWM,  16000000/510 = 31372.55 Hz clock
void Setup_timer2() {
// Timer2 Clock Prescaler to : 1
  sbi (TCCR2B, CS20);
  cbi (TCCR2B, CS21);
  cbi (TCCR2B, CS22);
  // Timer2 PWM Mode set to Phase Correct PWM
  cbi (TCCR2A, COM2A0);  // clear Compare Match
  sbi (TCCR2A, COM2A1);
  sbi (TCCR2A, WGM20);  // Mode 1  / Phase Correct PWM
  cbi (TCCR2A, WGM21);
  cbi (TCCR2B, WGM22);
// Timer2 Interrupt Service at 31372,550 KHz = 32uSec
// this is the timebase REFCLOCK for the DDS generator
// FOUT = (M (REFCLK)) / (2 exp 32)
// runtime : 8 microseconds ( inclusive push and pop)
ISR(TIMER2_OVF_vect) {
  sbi(PORTD,7);          // Test / set PORTD,7 high to observe timing with a oscope
  phaccu=phaccu+tword_m; // soft DDS, phase accu with 32 bits
  icnt=phaccu >> 24;     // use upper 8 bits for phase accu as frequency information
                         // read value fron ROM sine table and send to PWM DAC
  if(icnt1++ == 125) {  // increment variable c4ms all 4 milliseconds
    c4ms++;
    icnt1=0;
 cbi(PORTD,7);            // reset PORTD,7
dimax
dimax аватар
Онлайн
там сразу 2 ошибки. 15 строка должна быть такой: uint8_t const  PROGMEM  sine256[]  = {
questioner
Спасибо - сработало.
Один вопрос: что нужно прочитать, чтобы самому видеть такие ошибки?
П.с. Еще у американцев нашел исправление - тоже компилятор не ругается, но оно другое:
const PROGMEM unsigned char sine256[]  = {
dimax
dimax аватар
Онлайн
questioner, в принципе это не ошибка. Там написано всё правильно, просто последние версии ардуины кишат багами. В данном случае не подгружается инклюд из 12 строки скетча в нужный момент времени.
questioner
Как в этом коде поменять диапазон регулировки частоты скажем в 10 раз?
Сам спросил - сам отвечаю :
 67     dfreq=analogRead(0)/10;
Обожаю Ардуино !!! Я знаком с ним всего 4 дня (вечера), а уже управляю оборотами однофазного двигателя собственной конструкции !!! Мечта инженера "непрограммиста"
Lion777
повезло, что есть чужой готовый код, вот и обожаешь, а если бы просидел с месяцок, изучая как это самому написать, вот тогда посмотрел бы я на то, как ты обожаешь ))).
a5021
Еще хорошо, что есть чужие готовые буквы. Если бы буквы каждому самому пришлось изобретать, до сих пор бы за мамонтом бегали с каменными молотками.
questioner
С обоими комментаторами согласен на 100%. Вот только с ардуиной месяцок нужно посидеть, чтобы свой код написать, а с авр-ом или пик-ом - годик.
dimax
dimax аватар
Онлайн
questioner, как вы просто и оптимистично всё измеряете :)  Всё от способностей человека  зависит, и от желания учиться.  Код из верхнего поста среднестатический пользователь ардуины вообще вряд ли напишет сам, хоть за месяц хоть за год. Даже что-б просто разобрать и понять как всё там работает -и то нужны  знания и опыт работы с аналогичными программами.
questioner
А возможно ли сделать "разбор" этого кода? Очень нужно, т.к планирую контроллер для трехфазного двигателя, да еще и с датчиками.. Ох и тяжело будет с нуля, но мне деваться некуда. Для меня было сюрпризом, что двигатель моей конструкции заработал с первого раза, да еще и хорошо. Теперь заднюю не включить ))
dimax
dimax аватар
Онлайн
questioner, там есть специфика, без знаний которой бессмысленно начинать разбирать этот скетч. Предварительно необходимо изучить до полного понимания как минимум 2 важных составляющих этой программы  -это знать как работают таймеры (режимы, прерывания, настройка). И знать как работает DDS с аккумулятором фазы.  Остальное уже мелочи.
Клапауций 232
a5021 пишет:
всем сброситься по одному доллару - молотки мой дид придумал.
questioner
dimax, ткните носом, что необходимо прочесть?
Если возможно, на русском.
dimax
dimax аватар
Онлайн
questioner, а вот тут проблемка -я не встречал таких книг, статей на эти темы, что б можно было сказать что там всё изложено просто и в доходчивой форме. Обычно это скупой пересказ даташита, а даташиты как известно пишут не для чайников, а для уже специалистов в данном вопросе.  Читайте всё подряд, что найдёте. Я помню читал книгу Евстифеева про микроконтроллеры avr, она легко находится поиском. Про DDS чтива почти нет. Впрочем есть неплохая статья Л.Ридико про DDS. Ну а в общем как говорится гугль вам в помощь :)
a5021
Я или не въехал в суть вопроса или не вижу сложности. Для генерации синусоидальных колебаний посредством ШИМ-выхода МК (+ интегрирующая цепочка), всего и нужно, лишь в необходимом темпе подкидывать в регистр сравнения значения синуса, вычисленные или табличные.
dimax
dimax аватар
Онлайн
a5021, совершенно верно, с одним только нюансом - темп всегда один для любой частоты, в данном случае 31кГц. Функция  DDS имея на входе требуемое значение частоты определяет какие значения таблицы пропустить, а какие нет что б выдать требуемую частоту.
questioner
dimax пишет:
Я вот из этого поста понял больше, чем из статьи, на которую вы дали ссылку! А не проще было сразу так сказать? Принцип достаточно прост, а вот объяснение в источниках "мозгодробильное". Все можно объяснить гораздо проще.
dimax
dimax аватар
Онлайн
questioner, не проще. Вернее это слишком поверхностно, и понимания работы всё равно не даст. Например с пониманием как это работает можно рассчитать для каждой конкретной генерируемой частоты разрядность выдаваемой синусоиды. Она же 8-битная только до определённой частоты, а выше разрядность начинает падать.
questioner
Насколько сложно теперь переделать этот код под трехфазный? Смещение, естесственно 120 градусов и чтобы частота также регулировалась?
a5021
Потребуется три таблицы, три шим канала и управление этим хозяйством. Теоретически это возможно.
questioner
Ресурса железа хватит?
a5021
У атмеги328 шесть шим-каналов. Были бы еще три из них на одном таймере, так совсем бы хорошо было. Но в принципе, и так наверное прокатит.
nevkon
Может я буду не прав, но достаточно будет сделать еще 2 переменные PROGMEM в которых будет смещение на 120 и 240 градусов и вызываться они будут рядом с первой, но для других ног. Если я правильно понимаю там идут значения в равных участках времени и этих значений 256 (раз пишут про 8 бит), а значит 256/3=85. Так вот первые 85 значений перекидываем в конец для второй переменной и 170 или 171 значение перекидываем в конец для третьей переменной.
Или можно даже использовать одну переменную, но вызывать ее со сдвигом для каждой фазы - займет меньше места, но потребует чуть больше вычислительных ресурсов от МК для поиска позиции.
genadii
  Дима здравствуйте тема похожая я задался целью управлять сигналом HCR 04 переменной  длительности  шим портом ардуино для получения тонального сигнела пропорционально длительности входного в аудио диапазоне. подскажете можно ли использовать analogWrite () и нужент скетч.
Petropavel
Приветствую всех, что ни правил - не идет компиляция (ошибка в строке 024 , впрочем я человек в этих делах новый - учусь только), не мог бы кто-нибудь  разместить  здесь, либо отоcлать мне вышеуказаный рабочий скетч (.ino) на      vip.petropavel@mail.ru  . Заранее Вам благодарен.
dimax
dimax аватар
Онлайн
Petropavel, это 100% рабочий скетч.
Lion777
иде какая ? возможно в ней проблема, а то есть тут некоторые логики на старом сидят...
bwn
Lion777 пишет:
А в чем такое преимущество новых? У меня например, еще 0023 не снесена.))))
dimax
dimax аватар
Онлайн
Да, особенно учитывая, что скетч 2009 года :) А тот товарищ скорее всего про всплывающую кнопку "скопировать код" не знает, и накосячил с вставкой кода.
Ruslani4
Здравствуйте, когда выводил этот сигнал через нч получил синусойду, но частота менялась сама, с определённой переодичностью( т.е. секунду 1 частота, секунду другая, секунду 3я, секунду 4я, и так по кругу), я только только осваиваю ардуин, и не понимаю что сделать чтобы частота не скакала, а была 1ой заданной, как в примере 1000гц, и регулировалась через А0, стоит убрать 85-99 строки или 106-121, а может их оба, или убрать  tword_m, а вместо него ставить dfreq, хотя мне кажется что мы так изменяем частотк через А0, подскажите пожалуйста, что нужно сделать
kerpi4
Добрый день! Видел, писал про то, что хочешь на трехфазный двигатель сделать управление. Получилось? Стоит подобная задача, если увидишь, отзовись, пожалуйста.
andryn
kerpi4 пишет:
Если еще актуально, то тут: http://arduino.ru/forum/programmirovanie/preobrazovatel-chastoty-dlya-3kh-fazovogo-asinkhronnogo-dvigatelya-na-arduino попытался это сделать.
