Работа скетча без подключения wifi
viktor6
Всем привет. Нужна ваша помощь как сделать чтобы без подключения к wifi работал скетч.
За сам скетч не пинайте сильно только учусь.
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
const char* ssid = "******";
const char* password = "******";
const char* mqtt_server = "192.168.0.100";
const int buttonPin = 15;     // the number of the pushbutton pin
const int ledPin =  5;      // the number of the LED pin
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
void setup_wifi() {
  delay(10);
  // We start by connecting to a WiFi network
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  randomSeed(micros());
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
  Serial.println();
  // Switch on the LED if an 1 was received as first character
  if ((char)payload[0] == '1') {
    digitalWrite(ledPin, LOW);   // Turn the LED on (Note that LOW is the voltage level
    // but actually the LED is on; this is because
    // it is active low on the ESP-01)
  } else {
    digitalWrite(ledPin, HIGH);  // Turn the LED off by making the voltage HIGH
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Create a random client ID
    String clientId = "ESP8266Client-";
    clientId += String(random(0xffff), HEX);
    // Attempt to connect
    if (client.connect(clientId.c_str())) {
      Serial.println("connected");
      // Once connected, publish an announcement...
      client.publish("outTopic", "hello world");
      // ... and resubscribe
      client.subscribe("inTopic");
    } else {
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  Serial.begin(115200);
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed. If it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
  } else {
    // turn LED off:
  if (!client.connected()) {
    reconnect();
  client.loop();
  long now = millis();
  if (now - lastMsg > 2000) {
    lastMsg = now;
    ++value;
    snprintf (msg, 50, "hello world #%ld", value);
    Serial.print("Publish message: ");
    Serial.println(msg);
    client.publish("outTopic", msg);
xDriver
xDriver аватар
что он по вашему должен делать без ВИФИ?
viktor6
xDriver пишет:
При нажатии на buttonPin = 15 должен включится ledPin =  5
Или чтото не так?
xDriver
xDriver аватар
ну закоментарьте строки 96-98 и 113-126
viktor6
Допустим во время включения esp нет wifi но нужно чтобы он выполнял некоторые функции, а когда wifi повляется то уже конектица до mqtt брокера
Например система протечки воды не хорошо если вдруг пропадет WIFI и система перестанет работать.
xDriver
xDriver аватар
в данном исполнении - не выйдет. функция  setup_wifi() не отдаст управление пока не появится сеть.
переписывать алгоритм.
viktor6
xDriver пишет:
А можете дать пример как это сделать?
xDriver
xDriver аватар
в смысле, переписать весь код?
viktor6
xDriver пишет:
Хм я думал уже гдето подобное было. Ну да ладно будем учится если знаний хватит.
Можете подсказать по каким критерия задавать поиск гугле?
xDriver
xDriver аватар
зачем гуголь, прямая ссылка http://arduino.ru/forum/obshchii/pesochnitsa-dlya-vsekh-novichkov#comment-406075
