Часы стрелочные Ардуино Нано и 1.8TFT SPI
Втр, 01/08/2017 - 14:07
//#include <TinyGPSplus.h> //жпс парсер-источник точного времени //#include <SoftwareSerial.h>//связь с модулем жпс #include <SPI.h> #include <TFT.h> #define cs 10 #define dc 8 #define rst 9 #define TFT_SCLK 13 // set these to be whatever pins you like! (slow connection) #define TFT_MOSI 11 // set these to be whatever pins you like! #define halfheght 64 #define halfwidth 80 #define seclen 50 #define minlen 48 #define hwrlen 40 // заготовка для данных от жпс //static const uint32_t GPSBaud = 9600; //TinyGPSPlus gps;//example of gps class //SoftwareSerial ss(6, 7);//NMEA protocol connection TFT TFTscreen = TFT(cs, dc, rst); int clockCenterX=80; int clockCenterY=64; int oldsec=0; volatile float x1, y1, x2, y2, x3, y3, x4, y4; byte sec,mnt,hwr=0; void drawSec(float s) {//отрисовка секундной стрелки float ps = s-1; TFTscreen.stroke(0, 0, 0); if (ps==-1)ps=59; ps=ps*6; ps=ps+270; drawSecHand(ps); TFTscreen.stroke(255, 0, 255); s=s*6; s=s+270;//270 drawSecHand(s); } void drawSecHand(float s){ x1=seclen*cos(s*0.0175); //6.28/360=001745 y1=seclen*sin(s*0.0175); x2=5*cos(s*0.0175); y2=5*sin(s*0.0175); Serial.print(s); Serial.print("s,");Serial.print(s*0.0175); Serial.println(":угол"); TFTscreen.line(x1+clockCenterX, y1+clockCenterY, x2+clockCenterX, y2+clockCenterY); } void drawHwrHand(float h){ x1=hwrlen*cos(h*0.0175); y1=hwrlen*sin(h*0.0175); x2=5*cos(h*0.0175); y2=5*sin(h*0.0175); x3=20*cos((h+5)*0.0175); y3=20*sin((h+5)*0.0175); x4=20*cos((h-5)*0.0175); y4=20*sin((h-5)*0.0175); TFTscreen.line(x1+clockCenterX, y1+clockCenterY, x3+clockCenterX, y3+clockCenterY); TFTscreen.line(x3+clockCenterX, y3+clockCenterY, x2+clockCenterX, y2+clockCenterY); TFTscreen.line(x2+clockCenterX, y2+clockCenterY, x4+clockCenterX, y4+clockCenterY); TFTscreen.line(x4+clockCenterX, y4+clockCenterY, x1+clockCenterX, y1+clockCenterY); } void drawMinHand(float m){ x1=minlen*cos(m*0.0175); y1=minlen*sin(m*0.0175); x2=5*cos(m*0.0175); y2=5*sin(m*0.0175); x3=30*cos((m+4)*0.0175); y3=30*sin((m+4)*0.0175); x4=30*cos((m-4)*0.0175); y4=30*sin((m-4)*0.0175); TFTscreen.line(x1+clockCenterX, y1+clockCenterY, x3+clockCenterX, y3+clockCenterY); TFTscreen.line(x3+clockCenterX, y3+clockCenterY, x2+clockCenterX, y2+clockCenterY); TFTscreen.line(x2+clockCenterX, y2+clockCenterY, x4+clockCenterX, y4+clockCenterY); TFTscreen.line(x4+clockCenterX, y4+clockCenterY, x1+clockCenterX, y1+clockCenterY); } void drawDisplay() { // Очистка дисплея TFTscreen.background(0, 0, 0); // Рисуем циферблат TFTscreen.stroke(255, 255, 255); TFTscreen.background(0, 0, 0); for (int i=0; i<3; i++) { TFTscreen.circle(clockCenterX, clockCenterY, halfheght-i); } for (int i=0; i<5; i++) { TFTscreen.circle(clockCenterX, clockCenterY, i); } //Отображаем числа на циферблате TFTscreen.stroke(192, 192, 255); TFTscreen.text("3", clockCenterX+halfwidth-28, clockCenterY-3); TFTscreen.text("6", clockCenterX-2, clockCenterY+halfheght-12); TFTscreen.text("9", clockCenterX-halfwidth+23, clockCenterY-3); TFTscreen.text("12", clockCenterX-8, clockCenterY-halfheght+6); //Рисуем метки часов в виде рысочек for (int i=0; i<12; i++) { if ((i % 3)!=0) drawMark(i); } // t = rtc.getTime(); drawMin(mnt); drawHour(hwr, mnt); drawSec(sec); oldsec=sec; } void drawMark(int h)//Отрисовка меток { float x1, y1, x2, y2; h=h*30; h=h+270; x1=(halfheght-4)*cos(h*0.0175); y1=(halfheght-4)*sin(h*0.0175); x2=(halfheght-9)*cos(h*0.0175); y2=(halfheght-9)*sin(h*0.0175); TFTscreen.line(x1+clockCenterX, y1+clockCenterY, x2+clockCenterX, y2+clockCenterY); } void drawMin(int m)//отрисовка минутной стрелки { int pm = m-1; TFTscreen.stroke(0, 0, 0); if (pm==-1) pm=59; pm=pm*6; pm=pm+270; drawMinHand(pm); TFTscreen.stroke(0, 255, 0); m=m*6; m=m+270; drawMinHand(m); } void drawHour(int h, int m)//отрисовка часовой стрелки { int ph = h; TFTscreen.stroke(0, 0, 0); if (m==0) { ph=((ph-1)*30)+((m+59)/2); } else { ph=(ph*30)+((m-1)/2); } ph=ph+270; drawHwrHand(ph); TFTscreen.stroke(255, 255, 100); h=(h*30)+(m/2); h=h+270; drawHwrHand(h); } void setup(){ //Serial.begin(9600); //отладка //ss.begin(GPSBaud); //связь с жпс TFTscreen.begin(); TFTscreen.setTextSize(1); TFTscreen.background(0, 0, 0); drawDisplay(); } void loop()//основной цикл работы стрелочных часов { sec++; if (sec>59) { sec=0; mnt++; if (mnt>59) { mnt=0; hwr++; if (hwr>11) hwr=0; } } delay(100);//(1000)//100 - для отладки, 1000- работа int x, y; //t = rtc.getTime(); if (oldsec!=sec) { int t1=0; int t2=0; int t3=0; if(hwr>=12){ t1=(hwr-12)*5; } else { t1=hwr*5; } t2=mnt/12; t3=t1+t2; byte a=mnt+1; byte b=mnt+2; byte c=mnt+3; byte d=t3+1; byte e=t3+2; byte f=t3+3; byte g=t3+4; if ((sec==d)||(sec==e)||(sec==f)||(sec==g)) { drawHour(hwr,mnt); } if ((sec==a)||(sec==b)||(sec==c)) { drawMin(mnt); } if (sec==0) { drawMin(mnt); drawHour(hwr, mnt); } drawSec(sec); oldsec=sec; } // Serial.print("часы-минуты ");Serial.print(hwr);Serial.println(mnt); }
Это модифицированный файл. При незначительной доработке с запасом влез в НАНО.
Исходник взят сдесь http://arduino-project.net/analog-clock-arduino-mega/
Посмотреть можно здесь https://youtu.be/9y7nvNXAOv0
Дисплей цветной 1.8TFT SPI 128x160 ST7735
Дисплей на каком контроллере?
ST7735
Т.к. появился вопрос, я решил чуть почистить чужой код от избыточности. Это сообщение компоновщика: "Скетч использует 11694 байт (38%) памяти устройства. Всего доступно 30720 байт.Глобальные переменные используют 134 байт (6%) динамической памяти, оставляя 1914 байт для локальных переменных. Максимум: 2048 байт.", код прилагаю...
Этот скеч будет работать с модулем NEOWAY M590E ?
Если будет, то как его вживить в скеч ?
Я не в курсе. Между gps и gsm слишком велика разница. У меня gps корректировал время, у них там на орбите оно точнее нашего по телевизору. А с другой стороны минуты ничго не решат. В любом случае для gps протокол обычно NMEA, и вопрос только в скорости обмена по rs232 или его модификациям
сорри за скепсис... но вообще аналоговые часы - это стандартный пример к библиотеке TFT экрана... В чем новизна конкретно вашего проекта?
Хотелось вместить в мой камень, он меньше размером памяти. Заодно оптимизировать код. После этого я его еще двое сократил. Но это мало кого заинтересовало. Давно это было, сейчас я все пишу на ассемблере.
А не подскажете, какой Вы камень использовали? - просто в заголовке темы указан Нано... В Нано-то скетч из примеров влезает легко, он по моему всего килобайт 10-12 занимает
все? на ардуине? Большие проекты с разветвленной логикой - на асме?
Простите, но по-моему это бессмысленная трата времени. Какие-то небольшие критичные к времени куски - да, но весь проект...
Кто-то играет в шахматы, кто-то пьет водку, кто-то мусорит в лесах и на озерах, много кто программирует на си++, я их не критикую. Не могу критиковать того, кого не понимаю. Материть - могу, а критиковать бесполезно.
Братцы, подскажите что сделать, что бы обновлялась дата и день недели при 00:00, а то я в программировании вообще никак? Когда нажимаю на монитор порта, то обновление происходит, а самостоятельно нет.
Скетч взял здесь из источника первого поста, дисплей от сотового из соседней темы:
после строчки 233 вставьте
Спасибо большое b707, помогло. Пиво бы Вам за такое :)
Спасибо, b707, за помощь!
