O-Clock простые часы на матрице 8х32
YRA
Добрый день! Не получается вывести давление в mm ртутного столба- выводит в паскалях. Что где еще менять кроме 41 строки, да и скетч  крайний от уважаемого vikonix уже исправленный  под mm закачал, и перед этим произвел очистку EEPROM.
Спасибо нашел у себя ошибку. Решено
vikonix
peterzonda пишет:
how do i insert a photo?
On top of editor press icon with pictures.
You will see picture configurator.
Press button "Выбор на сервере" ("Select on server").
First, download your image to server and after that select image.
peterzonda
I tried it and it doesn't work.
When I save, it will show me only the first post
vikonix
I am now downloaded and inserted new image.
peterzonda
peterzonda
peterzonda
vikonix
I can't see in you list the RTCLib subdirectory.
C:\Users\vikon\Documents\Arduino\libraries>dir
10.06.2020  23:29    <DIR>          .
10.06.2020  23:29    <DIR>          ..
10.06.2020  23:28    <DIR>          Adafruit_ADXL343
10.06.2020  23:28    <DIR>          Adafruit_BME280_Library
10.06.2020  23:28    <DIR>          Adafruit_BusIO
10.06.2020  23:28    <DIR>          Adafruit_Unified_Sensor
10.06.2020  23:28    <DIR>          Bounce2
26.02.2020  23:21    <DIR>          LEDMatrixDriver
26.02.2020  23:22    <DIR>          NonBlockingRTTTL
26.02.2020  23:10               106    readme.txt
10.06.2020  23:28    <DIR>          RTClib
10.06.2020  23:29    <DIR>          TinyWireM
vikonix
RTClib must be same as https://github.com/adafruit/RTClib
Check this file https://github.com/adafruit/RTClib/blob/master/RTClib.h
  uint8_t dayOfTheWeek() const;
  /* 32-bit times as seconds since 2000-01-01. */
  uint32_t secondstime() const;
  /* 32-bit times as seconds since 1970-01-01. */
  uint32_t unixtime(void) const;
peterzonda
vikonix
First of all lets try to understand what library is used in compilation.
This system usually does a good job of picking the correct library but in some cases it does end up grabbing a different library than you had intended. To make this less of an issue, the Arduino IDE will display a list of the matching libraries it found and which it used in the black console window at the bottom of the Arduino IDE window. When it thinks the information is not critical, it may only show it if you have
File > Preferences > Show verbose output during compilation enabled. So if you're in doubt, it's a good idea to turn that option on at least for one compilation.
And set "Compiler warnings" option to "default".
Select this options and then run compilation and check what library was really used.
Alternative way is to check ".../XXXUSER/AppData/arduino_build_xxxxxx/"
Where "sketch" compiled project files
"libraries" set of all used libraries in project
vikonix
Black screen compiler output:
Using library EEPROM at version 2.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM
Using library RTClib at version 1.8.0 in folder: C:\Users\vikon\Documents\Arduino\libraries\RTClib
Using library Bounce2 at version 2.53 in folder: C:\Users\vikon\Documents\Arduino\libraries\Bounce2
Using library NonBlockingRTTTL at version 1.2.2 in folder: C:\Users\vikon\Documents\Arduino\libraries\NonBlockingRTTTL
Using library LEDMatrixDriver at version 0.2.2 in folder: C:\Users\vikon\Documents\Arduino\libraries\LEDMatrixDriver
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
Using library Adafruit_Unified_Sensor at version 1.1.3 in folder: C:\Users\vikon\Documents\Arduino\libraries\Adafruit_Unified_Sensor
Using library Adafruit_BME280_Library at version 2.0.2 in folder: C:\Users\vikon\Documents\Arduino\libraries\Adafruit_BME280_Library
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\vikon\\AppData\\Local\\Temp\\arduino_build_275480/src.ino.elf"
Sketch uses 24422 bytes (79%) of program storage space. Maximum is 30720 bytes.
Global variables use 957 bytes (46%) of dynamic memory, leaving 1091 bytes for local variables. Maximum is 2048 bytes.
sel_oleg
Мой вариант на матрицах 8х32. Питание общее, на каждой матрице своя ардуинка, часы показывают день недели т.к. супруга неработающий пенсионер, вечный выходной, и нужно не путаться в днях недели. Точка над днем недели - как маятник прыгает вправо-влево, показывает что часы идут. DS3231 год без корректировки.
Под знаком градуса - стрелка, замеры каждые 10 минут, показывает давление растет или падает. Температура с DS18b20 на длинном кабеле выведен через отверстие в раме на улицу
v258
А одна ардуина разве две матрицы не потянула бы?
vikonix
Да одной ардуинки на 2 индикатора вполне достаточно.
sel_oleg
Можно и на одной. Но часы и термометр-барометр делались с разрывом по времени, и потом только решил поставить в один корпус. Сделано на недорогих 168 mini, которых лежит достаточно. Зимой будет нечего делать - м.б. переведу на одну нано.
Смысл поста был показать как использовано пространство матрицы, шрифты и что выводится. Да, разделителя между часами и минутами нет, только два столбца расстояния, меня устраивает, день недели был важнее.
Сенин Андрей Ге...
Собираю реально просто часы- только отображение времени) Нашел скетч, но там нет фотоэлемента и соответственно авторегулировки яркости. Может подскажешь куда копать)
Заранее спасибо.
[code] void AdjustBright() { // current bright level static int CurBrightLevel = 0;
// logarithmic level byte level[] = {0,0,0,0,0,0,1,2,4,8}; // 0 = low, 15 = high // maximal analog value const int MaxAnalogValue = 1023;
int v = analogRead(Photo_Pin); //Serial.print(F("Light level=")); Serial.println(v, DEC);
#if 0 //switch off LED in full dark if(v == 0) lmd.setEnabled(false); else lmd.setEnabled(true); #endif
// calc linear level int l = (v * sizeof(level)) / MaxAnalogValue; // get logarithmic level l = level[l];
if(CurBrightLevel != l) { CurBrightLevel = l; lmd.setIntensity(CurBrightLevel); } }
[/code]
[code] // photo resistor pin const uint8_t Photo_Pin = A3; //Photoresistor connected to +5V with 10KOm to -V
[/code]
Это все или я что то упустил?
v258
Первое, что ты упустил - вставь правильно код - http://arduino.ru/forum/obshchii/vstavka-programmnogo-koda-v-temukommentarii
В таком виде его читать невозможно
Считывать и устанавливать яркость можно, например, так
void setMatrixIntensity()
  static uint32_t  flag = 0;
  if (millis() - flag >= 200)
    flag = millis();
    static byte x = 0;
    x = byte(((analogRead(PHOTORESISTOR_PIN) >> 6) * 2 + x) / 3);
    constrain(x, 1, 15);
    matrix.setIntensity(x); // это уже зависит от выбранной тобой библиотеки
Считывается с усреднением по трем последним замерам.
vikonix
Не очень понятен вопрос. Нужно добавить в другие часы регулировку яркости?
А чем эти часы сложнее, гибридный датчик можно не устанавливать.
Да, функция AdjustBright() регулирует яркость индикатора. Ее нужно периодически вызывать.
Здесь устанавливается яркость индикатора:
YRA
Спасибо автору за проект! Пока вид такой. Ввод информации будет на две стороны. Осталось обработать цапоном платы  т.к. на улице будут, и в корпус определить.
Сенин Андрей Ге...
Решил вопрос с яркостью вообще без скетча. В матрице заложена регулировка яркости, в даташит на чип описано. Убирается один резистор, к этой ноге подтягивается с питания резистор на 300 кОм, что бы в полной темноте матрица совсем не тухла, а вместо убранного резистора ставится фоторезистор на 10 кОм. Все- регулировка плавная и мгновенно реагирует на освещенность в помещении.
YRA
http://we.easyelectronics.ru/part/analogovaya-regulirovka-yarkosti-sveto...
ссылка где расписано,  как сделать регулировку
Сенин Андрей Ге...
Да, так и делал. Резистор на 350 кОм поставил, в полной темноте светит достаточно и не слепит.
YRA
Буду пробывать, но у меня на улице будут висеть под навесом, или у детей в доме, на тррассе, а там кромешной темноты не бывает, на столбе фонарь на улице, но это будет наверное не совсем быстро.То что на фото сегодня собрал с двух торон, поставид матрицы, входят в Коробка распаечная TPLAST 150*110*70 , плата под нее раисовалась и выпиливалась
на улицу надо вот такую матрицу (32х16см)
как сделать часы с автояркостью и коррекцией хода из сети - описано тута
Сенин Андрей Ге...
Для улицы раз 5 больше ставить надо.
Сенин Андрей Георгиевич пишет:
не наш метод. Раз в конструкции есть контроллер, значит программная регулировка даст куда больше возможностей... Правильнее разобраться в 10 строчках кода. чем резисторы перепаивать.
эти матрицы можно обьединять в длину и ширину :)
Сенин Андрей Ге...
Знаю)
YRA
Ребята, да во дворе в частном доме я живу и  ставлю :" Трохи, тилько для себе!" - синий- чтобы из дома видеть,а зеленый- из беседки, сею есть и работают другие, но эти детям в дом поставлю, что бы внуки радовались и деда вспоминали.
Manole_Kristya
Собрал,всё отлично, одно маленькое но, в пищалке постоянный фон, при показе даты, температуры, давления фон становится громче. Кто может помогите!
vikonix
Нужно по питанию поставить фильтр. Я ставил электролит и керамику в параллель.
В документации есть пример.
Сенин Андрей Ге...
Мне цифровая регулировка не зашла, яркость регулируется с задержкой и снижается или повышается ступеньчато. А с доработкой платны все происходит моментально. На любителя конечно.
Manole_Kristya
К сожалению не всё так просто. Навтыкал везде куда дотянулся. Правда не керамику а плёночные + электролиты.
Сенин Андрей Ге...
Смотри что у тебя с питанием, пробуй от другого бп запитать, мне кажется причина в этом.
peterzonda
Я хочу спросить.
Плохо показывает Давление.Попробовал 3 BME280.
peterzonda
BME показывает плохое атмосферное давление
vikonix
А что не правильно?
Какое правильное давление в вашей местности?
vikonix
Manole_Kristya Можно еще попробовать конденсатор параллельно динамику. 10нан для начала.
peterzonda
Давление должно быть 1020 гПа.
Я делал разные виды мераков и правильно указывал.
peterzonda, похоже вы находитесь на высоте примерно 200-250м над уровнем моря
vikonix
peterzonda
oclock.cpp:82
#define SEALEVELPRESSURE_HPA (1013.25)
В скобках задается давление на уровне моря. Меняя это значение можно менять привязку и тем самым менять текущее значение, которое будут показывать часы.
peterzonda
Я пробовал данные еще, но это не помогло.
peterzonda
я не могу разместить фото
peterzonda
Ответить на комментарий.
Он продолжает мне это писать.
DetSimen
DetSimen аватар
Онлайн
Мошт, тебе продать буквы помельче?  У меня есть лишние.
Green
Лучше очки посильнее. У меня знакомый капсом пишет из за того же.
peterzonda
Skušal som zmenšiť pismo.
peterzonda
Peterzonda, зачем нам это фото, что оно дает в теме? Лучше напишите, какая высота над уровнем моря там, где вы сделали это фото
