Помогите разобратся с роботом
keeper1978
делал робота по мануалу отсюда
скетч
// ���� ������ � ArduinoKit.ru
#include <AFMotor.h>
#include <Servo.h>
#include <NewPing.h>
#define TRIG_PIN A4 // Pin A4 on the Motor Drive Shield soldered to the ultrasonic sensor
#define ECHO_PIN A5 // Pin A5 on the Motor Drive Shield soldered to the ultrasonic sensor
#define MAX_DISTANCE 200 // sets maximum useable sensor measuring distance to 200cm
#define MAX_SPEED 180 // sets speed of DC traction motors to 180/256 or about 70% of full speed - to get power drain down.
#define MAX_SPEED_OFFSET 20 // this sets offset to allow for differences between the two DC traction motors
#define COLL_DIST 10 // sets distance at which robot stops and reverses to 10cm
#define TURN_DIST COLL_DIST+10 // sets distance at which robot veers away from object (not reverse) to 20cm (10+10)
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE); // sets up sensor library to use the correct pins to measure distance.
AF_DCMotor motor1(1, MOTOR12_1KHZ); // create motor #1 using M1 output on Motor Drive Shield, set to 1kHz PWM frequency
AF_DCMotor motor2(2, MOTOR12_1KHZ); // create motor #2, using M2 output, set to 1kHz PWM frequency
Servo myservo;  // create servo object to control a servo
int pos = 0; // this sets up variables for use in the sketch (code)
  int maxDist = 0;
  int maxAngle = 0;
  int maxRight = 0;
  int maxLeft = 0;
  int maxFront = 0;
int course = 0;
int curDist = 0;
String motorSet = "";
int speedSet = 0;
//-------------------------------------------- SETUP LOOP ----------------------------------------------------------------------------
  myservo.attach(9);  // attaches the servo on pin 9 (SERVO_2 on the Motor Drive Shield to the servo object
  myservo.write(90); // tells the servo to position at 90-degrees ie. facing forward.
  delay(2000); // delay for two seconds
  checkPath(); // run the CheckPath routine to find the best path to begin travel
  motorSet = "FORWARD"; // set the director indicator variable to FORWARD
  myservo.write(90); // make sure servo is still facing forward
  moveForward(); // run function to make robot move forward
//---------------------------------------------MAIN LOOP ------------------------------------------------------------------------------
delay(50);                      // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
  unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
  Serial.print("Ping: ");
  Serial.print(uS / US_ROUNDTRIP_CM); // Convert ping time to distance and print result (0 = outside set distance range, no ping echo)
  Serial.println("cm");
  checkForward(); // check that if the robot is supposed to be moving forward, that the drive motors are set to move forward - this is needed to overcome some issues with only using 4 AA NiMH batteries
  checkPath(); // set ultrasonic sensor to scan for any possible obstacles
void checkPath() {
  int curLeft = 0;
  int curFront = 0;
  int curRight = 0;
  int curDist = 0;
  myservo.write(144); // set servo to face left 54-degrees from forward
  delay(120); // wait 120milliseconds for servo to reach position
  for(pos = 144; pos >= 36; pos-=18)     // loop to sweep the servo (& sensor) from 144-degrees left to 36-degrees right at 18-degree intervals.
    myservo.write(pos);  // tell servo to go to position in variable 'pos'
    delay(90); // wait 90ms for servo to get to position
    checkForward(); // check the robot is still moving forward
    curDist = readPing(); // get the current distance to any object in front of sensor
    if (curDist < COLL_DIST) { // if the current distance to object is less than the collision distance
      checkCourse(); // run the checkCourse function
      break; // jump out of this loop
    if (curDist < TURN_DIST) { // if current distance is less than the turn distance
      changePath(); // run the changePath function
    if (curDist > curDist) {maxAngle = pos;}
    if (pos > 90 && curDist > curLeft) { curLeft = curDist;}
    if (pos == 90 && curDist > curFront) {curFront = curDist;}
    if (pos < 90 && curDist > curRight) {curRight = curDist;}
  maxLeft = curLeft;
  maxRight = curRight;
  maxFront = curFront;
void setCourse() { // set direction for travel based on a very basic distance map, simply which direction has the greatest distance to and object - turning right or left?
    if (maxAngle < 90) {turnRight();}
    if (maxAngle > 90) {turnLeft();}
    maxLeft = 0;
    maxRight = 0;
    maxFront = 0;
void checkCourse() { // we're about to hit something so move backwards, stop, find where the empty path is.
  moveBackward();
  delay(500);
  moveStop();
  setCourse();
void changePath() {
  if (pos < 90) {veerLeft();} // if current pos of sensor is less than 90-degrees, it means the object is on the right hand side so veer left
  if (pos > 90) {veerRight();} // if current pos of sensor is greater than 90-degrees, it means the object is on the left hand side so veer right
int readPing() { // read the ultrasonic sensor distance
  delay(70);
  int cm = uS/US_ROUNDTRIP_CM;
  return cm;
void checkForward() { if (motorSet=="FORWARD") {motor1.run(FORWARD); motor2.run(FORWARD); } }     // make sure motors are going forward
void checkBackward() { if (motorSet=="BACKWARD") {motor1.run(BACKWARD); motor2.run(BACKWARD); } } // make sure motors are going backward
// In some cases, the Motor Drive Shield may just stop if the supply voltage is too low (due to using only four NiMH AA cells).
// The above functions simply remind the Shield that if it's supposed to go forward, then make sure it is going forward and vice versa.
void moveStop() {motor1.run(RELEASE); motor2.run(RELEASE);}  // stop the motors.
void moveForward() {
    motor1.run(FORWARD);      // turn it on going forward
    motor2.run(FORWARD);      // turn it on going forward
  for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2) // slowly bring the speed up to avoid loading down the batteries too quickly
    motor1.setSpeed(speedSet);
    motor2.setSpeed(speedSet+MAX_SPEED_OFFSET);
    delay(5);
void moveBackward() {
    motorSet = "BACKWARD";
    motor1.run(BACKWARD);      // turn it on going forward
    motor2.run(BACKWARD);     // turn it on going forward
    delay(5);
void turnRight() {
  motorSet = "RIGHT";
  motor1.run(FORWARD);      // turn motor 1 forward
  motor2.run(BACKWARD);     // turn motor 2 backward
  delay(400); // run motors this way for 400ms
  motor1.run(FORWARD);      // set both motors back to forward
void turnLeft() {
  motorSet = "LEFT";
  motor1.run(BACKWARD);     // turn motor 1 backward
  motor2.run(FORWARD);      // turn motor 2 forward
void veerRight() {motor2.run(BACKWARD); delay(400); motor2.run(FORWARD);} // veering right? set right motor backwards for 400ms
void veerLeft() {motor1.run(BACKWARD); delay(400); motor1.run(FORWARD);} // veering left? set left motor backwards for 400ms
проблема вот в чем приподключении питания через мотор шилд работают только сервы движки малчат при подключении через юсб все работает вроде нормально
питание крона 9в
в чем может быть проблема
keeper1978
и при включении плата издаёт ровномерное пищание это нормально ?
vladk
сам же говоришь, что трабла в питании: может крона- дохлая, а может и стабилизатор сдох, раз уж слышен писк
keeper1978
что означает писк
vladk
судя по схеме, пищать могут двигатели от нехватки тока. Подключи крону и попробуй руками колеса подтолкнуть- должны будут прокручиваться легко. но в твоем случае лучше использовать раздельное питание шилда и уны, но хорошо проверенными эл-ми питания
keeper1978
а как запилить раздельное питание
vladk
одну крону или блок батарей подцепить на уну, а второй блок или крону на шилд
keeper1978
а перекоса не будет никакого
vladk
Чтобы избежать повреждения платы Arduino, на которой установлена плата расширения, мы рекомендуем использовать внешний источник питания напряжением от 7 до 12 В. Если вашему двигателю требуется напряжение более 9 В, мы рекомендуем вам разделить шины питания платы расширения и платы Arduino, на которой плата расширения установлена. Это возможно, если удалить перемычку "Vin Connect"на обратной стороне платы. Абсолютный предел напряжения Vin на зажимных контактах составляет 18 В.
http://arduino.ru/Hardware/ArduinoMotorShieldR3
vladk
vladk пишет:
так не подключай!!!
включай по последней схеме, но более мощным источником
