RC-Switch Webserver - заставить работать
Пнд, 18/08/2014 - 13:39
Думаю большинству знакома библиотека RC-Switch. В примерах есть скетч под названием webserver
/* A simple RCSwitch/Ethernet/Webserver demo http://code.google.com/p/rc-switch/ */ #include <SPI.h> #include <Ethernet.h> #include <RCSwitch.h> // Ethernet configuration byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // MAC Address byte ip[] = { 192,168,0, 2 }; // IP Address EthernetServer server(80); // Server Port 80 // RCSwitch configuration RCSwitch mySwitch = RCSwitch(); int RCTransmissionPin = 7; // More to do... // You should also modify the processCommand() and // httpResponseHome() functions to fit your needs. /** * Setup */ void setup() { Ethernet.begin(mac, ip); server.begin(); mySwitch.enableTransmit( RCTransmissionPin ); } /** * Loop */ void loop() { char* command = httpServer(); } /** * Command dispatcher */ void processCommand(char* command) { if (strcmp(command, "1-on") == 0) { mySwitch.switchOn(1,1); } else if (strcmp(command, "1-off") == 0) { mySwitch.switchOff(1,1); } else if (strcmp(command, "2-on") == 0) { mySwitch.switchOn(1,2); } else if (strcmp(command, "2-off") == 0) { mySwitch.switchOff(1,2); } } /** * HTTP Response with homepage */ void httpResponseHome(EthernetClient c) { c.println("HTTP/1.1 200 OK"); c.println("Content-Type: text/html"); c.println(); c.println("<html>"); c.println("<head>"); c.println( "<title>RCSwitch Webserver Demo</title>"); c.println( "<style>"); c.println( "body { font-family: Arial, sans-serif; font-size:12px; }"); c.println( "</style>"); c.println("</head>"); c.println("<body>"); c.println( "<h1>RCSwitch Webserver Demo</h1>"); c.println( "<ul>"); c.println( "<li><a href=\"./?1-on\">Switch #1 on</a></li>"); c.println( "<li><a href=\"./?1-off\">Switch #1 off</a></li>"); c.println( "</ul>"); c.println( "<ul>"); c.println( "<li><a href=\"./?2-on\">Switch #2 on</a></li>"); c.println( "<li><a href=\"./?2-off\">Switch #2 off</a></li>"); c.println( "</ul>"); c.println( "<hr>"); c.println( "<a href=\"http://code.google.com/p/rc-switch/\">http://code.google.com/p/rc-switch/</a>"); c.println("</body>"); c.println("</html>"); } /** * HTTP Redirect to homepage */ void httpResponseRedirect(EthernetClient c) { c.println("HTTP/1.1 301 Found"); c.println("Location: /"); c.println(); } /** * HTTP Response 414 error * Command must not be longer than 30 characters **/ void httpResponse414(EthernetClient c) { c.println("HTTP/1.1 414 Request URI too long"); c.println("Content-Type: text/plain"); c.println(); c.println("414 Request URI too long"); } /** * Process HTTP requests, parse first request header line and * call processCommand with GET query string (everything after * the ? question mark in the URL). */ char* httpServer() { EthernetClient client = server.available(); if (client) { char sReturnCommand[32]; int nCommandPos=-1; sReturnCommand[0] = '\0'; while (client.connected()) { if (client.available()) { char c = client.read(); if ((c == '\n') || (c == ' ' && nCommandPos>-1)) { sReturnCommand[nCommandPos] = '\0'; if (strcmp(sReturnCommand, "\0") == 0) { httpResponseHome(client); } else { processCommand(sReturnCommand); httpResponseRedirect(client); } break; } if (nCommandPos>-1) { sReturnCommand[nCommandPos++] = c; } if (c == '?' && nCommandPos == -1) { nCommandPos = 0; } } if (nCommandPos > 30) { httpResponse414(client); sReturnCommand[0] = '\0'; break; } } if (nCommandPos!=-1) { sReturnCommand[nCommandPos] = '\0'; } // give the web browser time to receive the data delay(1); client.stop(); return sReturnCommand; } return '\0'; }
Но мне никак не удается его запустить. Комплируется и выгружается. В браузере отображается. Но на приемнике команды поймать не могу. Кому-то приходилось с данным примером работать ?
А без сервера команды ловятся?
В смысле от другого источника ? Да, сам приемник достаточно хорошим получился и все ловит (и пульты и датчики).
Где-то на форуме прочитал, а сейчас не могу найти. Что в браузере хром и ИЕ реакция разныя. Проверил в ИЕ - несколько раз код сработал (конечно строки 046-053 заменил на свои). Но сработало с огромными тормозами. Пробывал на и UNO и на MEGA. Не напомните как ethernet shild 5100 лечится от тормозов ?
