Vcc & Temperature read & sleep
Ср, 07/02/2018 - 21:46
#in clude <avr/sleep.h> #include <avr/wdt.h> #define adc_disable() (ADCSRA &= ~(1<<ADEN)) // disable ADC #define adc_enable() (ADCSRA |= (1<<ADEN)) // re-enable ADC #define s025 0b000100 const byte SPLITTER = 200; const int DURATION_0 = 550; const int DURATION_1 = 150; void setup() { pinMode(13, OUTPUT); } void loop() { byte myvccInByte; long myvcc; int myTemp; adc_enable(); myvcc = readVcc(); myvccInByte = myvcc / 100; showSignal(myvccInByte); myWatchdogEnable(0b100000); //4 s adc_enable(); myTemp = readTemp(); if (myTemp < 0) { procMinus(); } showSignal(myTemp); myWatchdogEnable(0b100001); //8 s myWatchdogEnable(0b000111); //2 s } void myWatchdogEnable(const byte interval) { // sleep bit patterns: // 1 second: 0b000110 // 2 seconds: 0b000111 // 4 seconds: 0b100000 // 8 seconds: 0b100001 //0,25 seconds: 0b000100 adc_disable(); // clear various "reset" flags MCUSR = 0; // allow changes, disable reset WDTCSR = bit (WDCE) | bit (WDE); // set interrupt mode and an interval WDTCSR = 0b01000000 | interval;// set WDIE, and delay wdt_reset(); // pat the dog set_sleep_mode (SLEEP_MODE_PWR_DOWN); sleep_enable(); // turn off brown-out enable in software MCUCR = bit (BODS) | bit (BODSE); MCUCR = bit (BODS); sleep_cpu (); // cancel sleep as a precaution sleep_disable(); } ISR (WDT_vect) { wdt_disable(); // disable watchdog } long readVcc() { int Prior_ADMUX; Prior_ADMUX = ADMUX; // Read 1.1V reference against AVcc // set the reference to Vcc and the measurement to the internal 1.1V reference #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__) ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1); #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__) ADMUX = _BV(MUX5) | _BV(MUX0) ; #else ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1); #endif delay(75); // Wait for Vref to settle ADCSRA |= _BV(ADSC); // Start conversion while (bit_is_set(ADCSRA, ADSC)); // measuring uint8_t low = ADCL; // must read ADCL first - it then locks ADCH uint8_t high = ADCH; // unlocks both long result = (high << 8) | low; ADMUX = Prior_ADMUX; result = 1125300L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000 return result; // Vcc in millivolts } void send_d2RF(int d2RF) { switch (d2RF) { case 0: proc0(); break; case 1: proc1(); break; case 2: proc1(); myWatchdogEnable(s025); proc0(); break; case 3: proc1(); myWatchdogEnable(s025); proc1(); break; case 4: proc1(); myWatchdogEnable(s025); proc0(); myWatchdogEnable(s025); proc0(); break; case 5: proc1(); myWatchdogEnable(s025); proc0(); myWatchdogEnable(s025); proc1(); break; case 6: proc1(); myWatchdogEnable(s025); proc1(); myWatchdogEnable(s025); proc0(); break; case 7: proc1(); myWatchdogEnable(s025); proc1(); myWatchdogEnable(s025); proc1(); break; case 8: proc1(); myWatchdogEnable(s025); proc0(); myWatchdogEnable(s025); proc0(); myWatchdogEnable(s025); proc0(); break; case 9: proc1(); myWatchdogEnable(s025); proc0(); myWatchdogEnable(s025); proc0(); myWatchdogEnable(s025); proc1(); break; } } void procL() { digitalWrite(13, HIGH); delay(50); digitalWrite(13, LOW); } void procMinus() { digitalWrite(13, HIGH); delay(5000); digitalWrite(13, LOW); } void proc0() { digitalWrite(13, HIGH); delay(DURATION_0); digitalWrite(13, LOW); } void proc1() { digitalWrite(13, HIGH); delay(DURATION_1); digitalWrite(13, LOW); } void showSignal(byte ssgnl) { String beaconData = String(ssgnl); String oneStr = ""; int d2RF; for (int i = 0; i < beaconData.length(); i++ ) { d2RF = 0; oneStr += beaconData.charAt(i); d2RF = oneStr.toInt(); send_d2RF(d2RF); myWatchdogEnable(0b000110); oneStr = ""; } } int readTemp(void) { unsigned int wADC; double t; // The internal temperature has to be used // with the internal reference of 1.1V. // Channel 8 can not be selected with // the analogRead function yet. // Set the internal reference and mux. ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3)); ADCSRA |= _BV(ADEN); // enable the ADC delay(20); // wait for voltages to become stable. ADCSRA |= _BV(ADSC); // Start the ADC // Detect end-of-conversion while (bit_is_set(ADCSRA, ADSC)); // Reading register "ADCW" takes care of how to read ADCL and ADCH. wADC = ADCW; // The offset of 324.31 could be wrong. It is just an indication. t = (wADC - 324.31 ) / 1.22; // The returned temperature is in degrees Celsius. return (t); }
Полученные значения параметров промаргиваем светодиодом.
Автор, вы что сказать-то хотели?
Ничего больше, чем уже сказано. Возможно, кому пригодится для своих задач (я знаю минимум одного такого человека). Я потратил некоторое время на поиск рабочих кодов по данной теме, зачем его еще тратить?
Эти и другие нестандартные возможности Ардуин реализованы здесь: http://arduino.ru/forum/programmirovanie/sysinfo-arduino
Спасибо, буду изучать
