Aeyrwbz getKeys
maksmkv
Всем привет. Есть кусок кода - чтение клавиш:
/** Read keydata block from PT6961
  *  @param  *keydata Ptr to Array of PT6961_KEY_MEM (=5) bytes for keydata
  *  @return bool keypress True when at least one key was pressed
  * Note: Due to the hardware configuration the PT6961 key matrix scanner will detect multiple keys pressed at same time,
  *       but this may also result in some spurious keys being set in keypress data array.
  *       It may be best to ignore all keys in those situations. That option is implemented in this method depending on #define setting.
bool PT6961::getKeys(KeyData_t *keydata) {
  int keypress = 0;
  char data;
  // Read keys
  _cs=0;
  wait_us(1);
  // Enable Key Read mode
  _spi.write(_flip(PT6961_DATA_SET_CMD | PT6961_KEY_RD | PT6961_ADDR_INC | PT6961_MODE_NORM)); // Data set cmd, normal mode, auto incr, read data
  for (int idx=0; idx < PT6961_KEY_MEM; idx++) {
    data = _flip(_spi.write(0xFF));    // read keys and correct bitorder
    data = data & PT6961_KEY_MSK; // Mask valid bits
    if (data != 0) {  // Check for any pressed key
      for (int bit=0; bit < 8; bit++) {
        if (data & (1 << bit)) {keypress++;} // Test all significant bits
    (*keydata)[idx] = data;            // Store keydata after correcting bitorder
  wait_us(1);
  _cs=1;
  // Restore Data Write mode
  _writeCmd(PT6961_DATA_SET_CMD, PT6961_DATA_WR | PT6961_ADDR_INC | PT6961_MODE_NORM); // Data set cmd, normal mode, auto incr, write data
#if(1)
// Dismiss multiple keypresses at same time
  return (keypress == 1);
#else
// Allow multiple keypress and accept possible spurious keys
  return (keypress > 0);
#endif
/** Helper to reverse all command or databits. The PT6961 expects LSB first, whereas SPI is MSB first
  *  @param  char data
  *  @return bitreversed data
char PT6961::_flip(char data) {
 char value=0;
 if (data & 0x01) {value |= 0x80;} ;
 if (data & 0x02) {value |= 0x40;} ;
 if (data & 0x04) {value |= 0x20;} ;
 if (data & 0x08) {value |= 0x10;} ;
 if (data & 0x10) {value |= 0x08;} ;
 if (data & 0x20) {value |= 0x04;} ;
 if (data & 0x40) {value |= 0x02;} ;
 if (data & 0x80) {value |= 0x01;} ;
 return value;
/** Write command and parameter to PT6961
  *  @param  int cmd Command byte
  *  &Param  int data Parameters for command
  *  @return none
void PT6961::_writeCmd(int cmd, int data){
  _cs=0;
  wait_us(1);
//  _spi.write(_flip( (cmd & 0xF0) | (data & 0x0F)));
  _spi.write(_flip( (cmd & PT6961_CMD_MSK) | (data & ~PT6961_CMD_MSK)));
  wait_us(1);
  _cs=1;
Используется так:
 *   while (1) {
 *    // Check and read keydata
 *    if (pt6961.getKeys(&keydata)) {
 *      pc.printf("Keydata 0..4 = 0x%02x 0x%02x 0x%02x 0x%02x 0x%02x\r\n", keydata[0], keydata[1], keydata[2], keydata[3], keydata[4]);
 *      if (keydata[0] == 0x10) { //sw2
 *        pt6961.cls();
 *        pt6961.writeData(all_str);
Помогите  переписать его под arduino?
mixail844
помочь не равно написать за вас ,
начните сами , и если будут проблемы ,спрашивайте . или обратитесь в раздел "ищу исполнителя"
maksmkv
Начал делать сам. Основываясь на различных похожих кодах. Почему мой код не работает - пишу по командам согласно datasheet???
https://github.com/maksmkv/PT6961/blob/main/test.ino
Спасибо.
Онлайн
В чем выражается " не работает"? Код хотя бы компилируется?
mkvmaks
Код компилируется, но на дисплее ни чего не отображается. Делаю не через аппаратный spi.
DetSimen
DetSimen аватар
Онлайн
Мошт, ты пока этот код забросишь, и просто попытаешся вывести чонить на дисплей. И не через аппаратный SPI.
mkvmaks
Это не аппаратный spi. Есть библиотеки, которые отображат символы и работают, но не используют кнопки. Я просто пытаюсь сам сделать все как мануале, но потом добавив кнопки. Правиль но в shiftout подавать char в аиде 0х00 или надо через for задвигать биты?
DetSimen
DetSimen аватар
Онлайн
Я и говорю, ты попробуй сначала просто дисплей заставить работать и выводить в него хоть чонить. А потом строй вокруг этого всё остальное
maksmkv
Все зажег  первые 8 знаков )))
#include <Arduino.h>
//    const static char _DISPLAY_6X12 = 0x02;
//    const static char _DISPLAY_7X11 = 0x03;
//    const static char _AUTO_INCREMENT = 0x40;
//    const static char _FIXED_ADDRESS = 0x44;
//    const static char _DISPLAY_OFF = 0x80;
//    const static char _DISPLAY_1_16 = 0x88;
//    const static char _DISPLAY_2_16 = 0x89;
//    const static char _DISPLAY_4_16 = 0x8A;
//    const static char _DISPLAY_10_16 = 0x8B;
//    const static char _DISPLAY_11_16 = 0x8C;
//    const static char _DISPLAY_12_16 = 0x8D;
//    const static char _DISPLAY_13_16 = 0x8E;
//    const static char _DISPLAY_14_16 = 0x8F;
uint8_t DIN = 4; //DIN
uint8_t CLK = 3; //CLK
uint8_t CS = 2; //CS
void command1() //set display to 6x12 segments
    digitalWrite(CS, LOW);  //
    digitalWrite(CLK, LOW);
    digitalWrite(DIN, LOW);
      shiftOut(DIN, CLK, LSBFIRST, 0b00000011); // SET COMMAND 1
    digitalWrite(CS, HIGH);  //
    digitalWrite(CLK, HIGH);
    digitalWrite(DIN, HIGH);
    Serial.print("command1\n");
void command2() {
    shiftOut(DIN, CLK, LSBFIRST, 0b01000000); // SET COMMAND 2 write
    Serial.print("command2\n");
void command3() // Заполнение RAM нулями SET COMMAND 2
    shiftOut(DIN, CLK, LSBFIRST, 0b11000000);
      for(int i=0; i<8; i++)
        shiftOut(DIN, CLK, LSBFIRST, 0b00000000);
    Serial.print("command3\n");
void command4() //display on, max brightness
    shiftOut(DIN, CLK, LSBFIRST, 0b10001111); // SET COMMAND 4
    Serial.print("command4\n");
  pinMode(DIN, OUTPUT);
  pinMode(CLK, OUTPUT);
  pinMode(CS, OUTPUT);
  command2();
  command3();
  command1();
  command4();
  digitalWrite(CS,LOW);
  shiftOut(DIN, CLK, LSBFIRST, byte(0xC0));
  shiftOut(DIN, CLK, LSBFIRST, 0b11111111);
  Serial.print("Code ON\n");
  digitalWrite(CS,HIGH);
Онлайн
maksmkv пишет:
ну. удачи... с такими скиллами программирования она вам понадобится...
Не пришло в голову. что процедуры command1, 2 и 4 - практически одинаковые и их можно записать как-то по-приличнее. чем тупо копировать три раза?
maksmkv
Согласен, пока что делаю в тупую, далее переделаю.
Не буду создавать новую тему, может подскажите:   есть код от TM168 (единственное различие между мои PT6961 - это у первого совместный вход/выход DIO, а у меня это раздельные порты).
Почему использую код из http://arduino.ru/forum/proekty/korpus-ot-drs-8300-v-arduino-proektakh   - чтения клавиш:
#define KEY_1   0x0800
#define KEY_2   0x0100
#define KEY_3   0x0008
#define KEY_4   0x0001
//  Чтение состояния кнопок с TM1668
	void readKeyData(uint16_t * data) {
	    digitalWrite(PIN_STB, LOW);
	    shiftOut(PIN_DIO, PIN_CLK, LSBFIRST, 0x42);  // чтение данных
	    pinMode(PIN_DIO, INPUT_PULLUP);
	    delayMicroseconds(1);
	    * data = shiftIn(PIN_DIO, PIN_CLK, LSBFIRST) + (shiftIn(PIN_DIO, PIN_CLK, LSBFIRST) << 8);
	    pinMode(PIN_DIO, OUTPUT);
	    digitalWrite(PIN_STB, HIGH);
void loop(){
	//	Читаем состояние кнопок
	// и отрабатываем команды
	static uint16_t keys = 0;
	uint16_t newKeys;
	readKeyData(& newKeys);
	if (keys != newKeys) {
		keys = newKeys;
		if (keys & KEY_1) {	// уменьшить яркость
			decreaseBrightness();
		if (keys & KEY_2) {	// увеличить яркость
			increaseBrightness();
		if (keys & KEY_3)	{	// включить следующий доп. символ
			swicthExtraSymbol();
			haveToUpdate = true;
		if (keys & KEY_4)  {	// сбросить время в 0
			m = 0;
			s = 0;
			showClock(m, s);
			oldMillis = currMillis;
Переделал под свою PT6961:
uint8_t DOUT = 5;
     shiftOut(DOUT, CLK, LSBFIRST, 0x42);  // чтение данных
     pinMode(DOUT, INPUT);
     * data = shiftIn(DOUT, CLK, LSBFIRST) + (shiftIn(DOUT, CLK, LSBFIRST) << 8);
  uint16_t newKeys; // 2 байта
    keys = newKeys;
    if (keys & KEY_1)
        Serial.println("Key1");
    if (keys & KEY_2)
      Serial.println("Key2");
    if (keys & KEY_3)
      Serial.println("Key3");
В консоль выходит:
Key1
Key2
Key3
Хотя, должно выводит в зпависимости от нажатой кнопки
DetSimen
DetSimen аватар
Онлайн
Ты не поверишь, выводит он именно то, что должен.  Если это не совпадает с виденьем программиста, то это проблема программиста.  Никак не твоя. Забей.
