Button box для игр (доп.кнопки)
SanSaySP
Есть код для Button box, вроде как рабочий,
//BUTTON BOX
//USE w ProMicro
//Tested in WIN10 + Assetto Corsa
//AMSTUDIO
//20.8.17
#include <Keypad.h>
#include <Joystick.h>
#define ENABLE_PULLUPS
#define NUMROTARIES 4
#define NUMBUTTONS 24
#define NUMROWS 5
#define NUMCOLS 5
byte buttons[NUMROWS][NUMCOLS] = {
  {0,1,2,3}, //0,1,2,3,4
  {5,6,7,8,9},
  {10,11,12,13,14},
  {15,16,17,18,19},
  {20,21,22,23,4}, //{20,21,22,23},
struct rotariesdef {
  byte pin1;
  byte pin2;
  int ccwchar;
  int cwchar;
  volatile unsigned char state;
rotariesdef rotaries[NUMROTARIES] {
  {0,1,24,25,0},   //0,1 - куда подключен энкодер; 24,25 - кнопки джойстика
  {2,3,26,27,0},
  {4,5,28,29,0},
  {6,7,30,31,0},
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
  // R_START (00)
  {R_START_M,            R_CW_BEGIN,     R_CCW_BEGIN,  R_START},
  // R_CCW_BEGIN
  {R_START_M | DIR_CCW, R_START,        R_CCW_BEGIN,  R_START},
  // R_CW_BEGIN
  {R_START_M | DIR_CW,  R_CW_BEGIN,     R_START,      R_START},
  // R_START_M (11)
  {R_START_M,            R_CCW_BEGIN_M,  R_CW_BEGIN_M, R_START},
  // R_CW_BEGIN_M
  {R_START_M,            R_START_M,      R_CW_BEGIN_M, R_START | DIR_CW},
  // R_CCW_BEGIN_M
  {R_START_M,            R_CCW_BEGIN_M,  R_START_M,    R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
  // R_START
  {R_START,    R_CW_BEGIN,  R_CCW_BEGIN, R_START},
  // R_CW_FINAL
  {R_CW_NEXT,  R_START,     R_CW_FINAL,  R_START | DIR_CW},
  // R_CW_BEGIN
  {R_CW_NEXT,  R_CW_BEGIN,  R_START,     R_START},
  // R_CW_NEXT
  {R_CW_NEXT,  R_CW_BEGIN,  R_CW_FINAL,  R_START},
  // R_CCW_BEGIN
  {R_CCW_NEXT, R_START,     R_CCW_BEGIN, R_START},
  // R_CCW_FINAL
  {R_CCW_NEXT, R_CCW_FINAL, R_START,     R_START | DIR_CCW},
  // R_CCW_NEXT
  {R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
byte rowPins[NUMROWS] = {19,18,17,16,15}; //19,18,17,16,15                 21,20,19,18,15
byte colPins[NUMCOLS] = {14,12,11,10,9}; //                                14,16,10,9,8
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
  JOYSTICK_TYPE_JOYSTICK, 32, 0,
  false, false, false, false, false, false,
  false, false, false, false, false);
  Joystick.begin();
  rotary_init();}
  CheckAllEncoders();
  CheckAllButtons();
void CheckAllButtons(void) {
      if (buttbx.getKeys())
       for (int i=0; i<LIST_MAX; i++)
           if ( buttbx.key[i].stateChanged )
            switch (buttbx.key[i].kstate) {
                    case PRESSED:
                    case HOLD:
                              Joystick.setButton(buttbx.key[i].kchar, 1);
                    case RELEASED:
                    case IDLE:
                              Joystick.setButton(buttbx.key[i].kchar, 0);
void rotary_init() {
  for (int i=0;i<NUMROTARIES;i++) {
    pinMode(rotaries[i].pin1, INPUT);
    pinMode(rotaries[i].pin2, INPUT);
    #ifdef ENABLE_PULLUPS
      digitalWrite(rotaries[i].pin1, HIGH);
      digitalWrite(rotaries[i].pin2, HIGH);
    #endif
unsigned char rotary_process(int _i) {
   unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
  rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
  return (rotaries[_i].state & 0x30);
void CheckAllEncoders(void) {
    unsigned char result = rotary_process(i);
    if (result == DIR_CCW) {
      Joystick.setButton(rotaries[i].ccwchar, 1); delay(50); Joystick.setButton(rotaries[i].ccwchar, 0);
    if (result == DIR_CW) {
      Joystick.setButton(rotaries[i].cwchar, 1); delay(50); Joystick.setButton(rotaries[i].cwchar, 0);
но у меня выдает ошибку:
ARDUINO_BUTTON_BOXV2:95: error: 'JOYSTICK_DEFAULT_REPORT_ID' was not declared in this scope
ARDUINO_BUTTON_BOXV2:96: error: 'JOYSTICK_TYPE_JOYSTICK' was not declared in this scope
exit status 1
при этом библиотека с этими... "переменными" подгружена и если просто закомментить код с ними, то программа по сути работает, но правда частично - часть кнопок работает, а часть нет, но это другой вопрос, пока хочу добиться, чтобы этой ошибки не было, может вся проблема в ней.
И где же эта библиотека? Давайте посмотрим - действительно ли есть ли существуют указанные выше макросы.
SanSaySP
sadman41 пишет:
Лежить по пути "C:\Users\1\Documents\Arduino\libraries"
в одноименной папке "Joystick"
в ней есть файл "Joystick.h" в котором есть................
ой дурак... накачал кучу библиотек с одинаковыми названиями файлов и думал они одинаковые, но оказывается у их файлов разный код и подгруженная библиотека действительно не содержала эти макросы. Черд. Спасибо!
GooGT
А сможет ли кто-нибудь помочь в скрещивании этого кода и ещё одного, с аналоговыми осями того же автора с ютуб AMSTUDIO?
вот он: https://www.youtube.com/watch?v=iKIrbF6GnZ0
Суть такова: собрал себе руль, для симрейсинга. Есть уже 3 разные версии. На последнем есть специальные лепестки, отвечающие за выжим сцепления, но в програмировании не силен, а у автора нет кода, где бы были хотя бы 2 аналоговые оси, 4 поворотных энкодера и несколько кнопок в одном.
Небольшая демонстрация моего изделия: https://youtu.be/sgsy6JPzt3E
SanSaySP
GooGT пишет:
А без аналоговых осей ты смог реализовать энкодеры и кнопки?
А то кнопки в виде матрицы я так и не смог сделать, чтобы заработали... планирую делать кнопки с резисторами (резистивно последовательное подключение), такой способ подключения кнопок уже более 2-х лет работает на моей самопальной КПП.
Там же есть и оси...
А собственно в чем проблема со скрещиванием скетчей? У того автора есть и скетч с осями, и есть скетч с энкодерами+кнопки.
GooGT
НУ сам я ничего не реализовывал. У автора есть кнопки+энкодер, на основе этого счетча и построен руль. Нужен скетч кнопки+энкодеры+оси. Не засовывать же 2 ардуины в 1 руль..
SanSaySP
Зачем 2 ардуины? )))
Берешь открываешь 2 скетча и из одного все вставляешь во второй... типо:
все что до "void setup()" во втором скетче вставляешь так же до "void setup()" в первый
все что внутри "void setup()" второго скетча так же вставляешь внутрь "void setup()" первого
все что внутри "void loop()" второго скетча так же вставляешь внутрь "void loop()" первого
ну и все что после "void loop()" - аналогично.
Только внимательно пины надо проверить, чтобы не пересекались.
Respekt
Всем привет! Не давно начал изучать Arduino, уже сделал себе ручку селектор с кнопками для ETS2 ATS на Logitech 27. Использую кнопки для повышенных\пониженных скоростей - нижний верхний ряды КПП. Залил код в pro micro, на три кнопки. Собираюсь делать buttonbox,  прикупил кнопки. Прежде чем делать корпус хочу разобраться с прошивкой. Пытаюсь заливать скетч как в первом после, добавил библиотеку, но появились ошибки:
buttsimpjoy:16:20: error: Keypad.h: No such file or directory
compilation terminated.
exit status 1
Тут используется два файла на сколько я понимаю: Keypad.h и Joystick.h. Оба они находятся в дирректории Arduino\libraries\ArduinoJoystickLibrary-master
Помогите исправить ошибку, пожалуйста.
Компилятор не согласен с Вашим утверждением.
Respekt
А как сделать, что бы он согласился?
В соответствии со стандартом языка C указать в #include имя файла заголовка.
Respekt
Так он указан. Быть может находится не в том месте? Как проверить правильные пути и ссылки?
SanSaySP
Respekt пишет:
Здорова, тоже играю в ЕТС, для нее сделал КПП и баттонбокс, по твоей проблеме - думаю эти файлы должны находиться по пути "D:\Мои документы\Arduino\libraries\Joystick", а не "ArduinoJoystickLibrary-master"
Respekt
пробовал... не идет, та же ошибка. buttonbox у тебя собран на этом же скетче с библиотекой?
SanSaySP
А где у тебя вообще лежит папка "Arduino\libraries"?
Взят за основу этот скетч, но я там долго мудохался, чет там переписывал, переделывал и как писал выше - так и не смог сделать чтобы кнопки заработали через матрицу и переделал на резистивно последовательное подключение.
Respekt пишет:
По предоставленной Вами информации однозначно можно заключить только одно: компилятор не находит файла. Телепаты сейчас все картоху пропалывают, так что придется включить свою голову и подумать, какая информация была бы полезна для решения этого ребуса.
Respekt
https://github.com/MHeironimus/ArduinoJoystickLibrary  библиотека
https://github.com/OpenSimHardware/Buttsimp Скетчи (именно joy пытаюсь)
Счачав два архива, пытаюсь разобраться в прошивке. В итоге ошибка описанная мною выше.
SanSaySP
Respekt пишет:
Ты так и не написал полный путь, где у тебя лежат файлы Keypad.h и Joystick.h
Respekt
C:\Users\username\Documents\Arduino\libraries\ArduinoJoystickLibrary-master\Joystick\src\Joystick.h
Keypad.h вообще нигде не вижу. Он и не нужен я так понимаю, раз идет эмуляция джойстика. Keypad.h убирал из скейча, толку нет. Проверил как видет Arduino IDE библиотеку путем загрузки: фаил-примеры- тут я не увидел подгруженную библиотеку. Скопировал папку Joystick из архива с библиотекой, снова иду по пути фаил-примеры-Joystick и вижу примеры, загружаю, проверяю - все работает без ошибок.
Проверяю скетч из архива:    в итоге вижу ошибку которой еще не было ;) Ругается на клавиатуру по всей вероятности....
buttsimpjoy:87:1: error: 'Keypad' does not name a type
C:\Users\username\Desktop\sc\buttsimpjoy\buttsimpjoy.ino: In function 'void setup()':
buttsimpjoy:92:3: error: 'Joystick' was not declared in this scope
   Joystick.begin();
C:\Users\username\Desktop\sc\buttsimpjoy\buttsimpjoy.ino: In function 'void CheckAllButtons()':
buttsimpjoy:108:14: error: 'buttbx' was not declared in this scope
   char key = buttbx.getKey();
buttsimpjoy:109:14: error: 'NO_KEY' was not declared in this scope
   if (key != NO_KEY)  {
buttsimpjoy:110:5: error: 'Joystick' was not declared in this scope
     Joystick.setButton(key, 1); delay(50); Joystick.setButton(key, 0);
C:\Users\username\Desktop\sc\buttsimpjoy\buttsimpjoy.ino: In function 'void CheckAllEncoders()':
buttsimpjoy:143:7: error: 'Joystick' was not declared in this scope
buttsimpjoy:146:7: error: 'Joystick' was not declared in this scope
exit status 1
SanSaySP
Respekt пишет:
Я ж тебе писал, что путь у тя походу не верный... нужно
Keypad.h тоже нужен, да и у тебя ошибки же выходят.
Вобщем, ошибки тут две:
1) Лишний уровень вложенности в библиотеке. The deploy.bat file can be executed to install the Joystick folder on Microsoft Windows machines (assuming a default Arduino installation) => смотрим deploy.bat и видим xcopy /E /I Joystick\*.* "%HOMEDRIVE%%HOMEPATH%\Documents\Arduino\libraries\Joystick"
2) Автор buttsimpjoy.ino забыл объявить объект Joystick:
//initialize an Joystick with 34 buttons;
                   JOYSTICK_TYPE_JOYSTICK, 34, 0,
После правок :
Using library Keypad in folder: C:\Users\xxx\Documents\Arduino\libraries\Keypad (legacy)
Using library Joystick at version 2.0.5 in folder: C:\Users\xxx\Documents\Arduino\libraries\Joystick
Sketch uses 9242 bytes (32%) of program storage space. Maximum is 28672 bytes.
Global variables use 487 bytes (19%) of dynamic memory, leaving 2073 bytes for local variables. Maximum is 2560 bytes.
Respekt
Оказывается, у меня в принцепе не было библиотеки keypad. https://github.com/Chris--A/Keypad   скачал-скопировал-скетч компилируется, без ошибок. Пробую дальше.
