Двухканальный генератор
Ср, 19/06/2019 - 14:50
всем привет
Пытаюсь добавить второй канал , выход пин ПА 10, пака на этом пине ничего нетъ , где ошибка ?
Вот программа
#define SAMPLES 100 #define DEBOUNCE_DELAY 10 #define DEBOUNCE_IDLE 0 #define DEBOUNCE_ACTIVE 1 #include <libmaple/dma.h> struct debounce_info { int start, state; int16 shift; } up, down; dma_tube_config dma_cfg, dma_cfg2; int flag1 = 0; int flag2 = 0; ///////////////////////////// int out1 = PA10; int out2 = PA8; ///////////////////////////// int val1[SAMPLES]; int val2[SAMPLES]; int ampp = PB9; int ampn = PB6; int16 shift = 0; int amp = 35; int cnt = 0; int time_track = 0; float stp = 6.2831 / SAMPLES; int ret = 17; ////////////////////////////////////////////////// timer_dev *dev1 = PIN_MAP[out1].timer_device; uint8 cc_channel1 = PIN_MAP[out1].timer_channel; ////////////////////////////////////////////////////////// timer_dev *dev2 = PIN_MAP[out2].timer_device; uint8 cc_channel2 = PIN_MAP[out2].timer_channel; void fun() { flag1++; } void fun2() { flag2++; } void timer_conf() { /////////////////// timer_dma_set_base_addr(dev1, TIMER_DMA_BASE_CCR2); timer_dma_set_burst_len(dev1, 1); timer_dma_enable_req(dev1, cc_channel1); timer_set_reload(dev1, 102); timer_set_prescaler(dev1, 0); ////////////////////// timer_dma_set_base_addr(dev2, TIMER_DMA_BASE_CCR1); timer_dma_set_burst_len(dev2, 1); timer_dma_enable_req(dev2, cc_channel2); timer_set_reload(dev2, 102); timer_set_prescaler(dev2, 0); } void dma_conf() { dma_init(DMA1); ////////////////////////////////////////////////////////////////////////////////// /* T1C3 DMA C4 */ dma_cfg.tube_dst = &(dev1->regs.gen->DMAR); dma_cfg.tube_dst_size = DMA_SIZE_32BITS; dma_cfg.tube_src = val1; dma_cfg.tube_src_size = DMA_SIZE_32BITS; dma_cfg.tube_nr_xfers = SAMPLES; dma_cfg.tube_flags = DMA_CFG_SRC_INC | DMA_CFG_CIRC | DMA_CFG_CMPLT_IE; dma_cfg.tube_req_src = DMA_REQ_SRC_TIM1_CH3; //T1C3, PA10 dma_cfg.target_data = 0; ret = dma_tube_cfg(DMA1, DMA_CH4, &dma_cfg); /////////////////////////////////////////////////////////////////////////////////// // ampl /* T1C1 DMA C2 */ dma_cfg.tube_dst = &(dev2->regs.gen->DMAR); dma_cfg.tube_dst_size = DMA_SIZE_32BITS; dma_cfg.tube_src = val2; dma_cfg.tube_src_size = DMA_SIZE_32BITS; dma_cfg.tube_nr_xfers = SAMPLES; dma_cfg.tube_flags = DMA_CFG_SRC_INC | DMA_CFG_CIRC | DMA_CFG_CMPLT_IE; dma_cfg.tube_req_src = DMA_REQ_SRC_TIM1_CH1; // T1C1,PA8 dma_cfg.target_data = 0; ret = dma_tube_cfg(DMA1, DMA_CH2, &dma_cfg); } void dma_start() { ///////////////////////// dma_attach_interrupt(DMA1, DMA_CH4, fun); dma_enable(DMA1, DMA_CH4); timer_resume(dev1); //////////////////////// dma_attach_interrupt(DMA1, DMA_CH2, fun2); //PA8 dma_enable(DMA1, DMA_CH2); timer_resume(dev2); } ///////////////////////////////////////////////////////////////// void init_wave() { int i; for (i = 0; i < SAMPLES; i++) { val1[i] = 50 + amp * sin(stp * i); val2[i] = val1[i]; } } ///////////////////////////////////////////////////////////////// void get_wave(int16 shift) { int i; for (i = 0; i < SAMPLES; i++) { val2[i] = 50 + amp * sin( stp * i + shift * 0.1 * 6.2831 / 360); } } void setup() { pinMode(out1, PWM); pinMode(out2, PWM); pinMode(ampp, INPUT_PULLDOWN); pinMode(ampn, INPUT_PULLDOWN); memset(&up, 0, sizeof(debounce_info)); memset(&down, 0, sizeof(debounce_info)); up.shift = 1; down.shift = -1; Serial.begin(9600); timer_conf(); dma_conf(); dma_start(); init_wave(); get_wave(shift); } void loop() { process_key_amp(digitalRead(ampp), &up); process_key_amp(digitalRead(ampn), &down); } void process_key_amp(int val, struct debounce_info *k) { switch (k->state) { case DEBOUNCE_IDLE: if (val == HIGH) { k->state = DEBOUNCE_ACTIVE; k->start = millis(); } break; case DEBOUNCE_ACTIVE: if (val == HIGH) { if (millis() - k->start > DEBOUNCE_DELAY) { amp += (int)k->shift; get_wave(shift); } } else k->state = DEBOUNCE_IDLE; break; } Serial.println(amp); }
А кто Вам сказал, что в этой программе есть ошибка?
Просмотрел программу. Только в сетапе нашёл команду ардуино pinMode с нестандартными параметрами. Казалось бы - причём здесь ардуино?
gena321, программа всегда работает так, как она написана (но не всегда так, как ее хотели написать).
Ошибка в Вашем случае - это откнение реальной работы программы от ожидаемой.
Но никто кроме Вас не знает, чего именно Вы хотите от программы.
Поэтому подобные вопросы крайне желательно излагать по схеме:
1. Что должна делать программа.
2. Что она на самом деле делает.
3. Чем второе отличается от первого.
