esp-01 http
fora983
создал сервер http считающий подключения.
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
/* Set these to your desired credentials. */
const char *ssid = "TST_19_04_2018";
const char *password = "11111111";
//WiFiServer server(80);
ESP8266WebServer server(80);
int i=0;
/* Just a little test message.  Go to http://192.168.4.1 in a web browser
 * connected to this access point to see it.
void handleRoot() {
// char c = server.read();
// Serial.println(c);
	server.send(200, "You are connected");
  Serial.print("connect: ");// Шлём в UART
  i=i+1;
  Serial.println(i);// Шлём в UART
  Serial.println();
  Serial.print("Configuring access point...");
  WiFi.softAP(ssid, password);
  IPAddress myIP = WiFi.softAPIP();
  Serial.print("AP IP address: ");
  Serial.println(myIP);
  server.on("/", handleRoot);
  server.begin();
  Serial.println("HTTP server started");
//  sensors.begin();
   //Serial.println("Diskonnected");
 server.handleClient() ;
 //Serial.println("NEW Client");// Шлём в UART
//    server.send(200, "text/plain", webString);            // send to someones browser when asked
при попытки подключить с телефона (google chrome) счетчик считает и выводит в uart . при подключении с esp-01 счет не идет. подскажите какой должен быть запрос
 *  This sketch sends data via HTTP GET requests to data.sparkfun.com service.
 *  You need to get streamId and privateKey at data.sparkfun.com and paste them
 *  below. Or just customize this script to talk to other HTTP servers.
const char* ssid     = "TST_19_04_2018";
const char* password = "11111111";
//const char* ssid     = "ASUS";
//const char* password = "12345678";
const char* host = "192.168.4.1";
//const char* streamId   = "....................";
//const char* privateKey = "....................";
  delay(10);
  // We start by connecting to a WiFi network
  Serial.println();
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(ssid);
  /* Explicitly set the ESP8266 to be a WiFi-client, otherwise, it by default,
     would try to act as both a client and an access-point and could cause
     network-issues with your other WiFi-devices on your WiFi-network. */
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  delay(3000);
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
int value = 0;
  delay(5000);
  Serial.print("connecting to ");
  Serial.println(host);
  // Use WiFiClient class to create TCP connections
  WiFiClient client;
  const int httpPort = 80;
  client.connect(host, httpPort) ;
String url = "";
url.trim();
client.print("GET http://" + host + (getWithoutPort? "" : (":" + host)) + doc + "&" + data + " HTTP/1.1\r\n" +
"Host: " + host + (getWithoutPort? "" : (":" + host)) + "\r\n" +
"Connection: Close\r\n" +
"\r\n");
 //client.print("GET " + url + " HTTP/1.1\r\nHost: " + host + "\r\n" + "Connection: close\r\n\r\n");
  client.flush();     // ждем отправки всех данных
  // This will send the request to the server
//  client.print(String("GET") + host + " HTTP/1.1\r\n" "Host: " + host + "\r\n" +  "Connection: close\r\n\r\n");
//  unsigned long timeout = millis();
//  while (client.available() == 0) {
   // if (millis() - timeout > 5000) {
     // Serial.println(">>> Client Timeout !");
     // return;
char c = client.read();
Serial.println(c);
client.stop();
Serial.println("closing connection");
  // Read all the lines of the reply from server and print them to Serial
//  while(client.available()){
//    String line = client.readStringUntil('\r');
//    Serial.print(line);
//  Serial.println();
//  Serial.println("closing connection");
к точке доступа подключается получает ip. но отправляет видимо неправильный запрос.
А он (телефон) не кеширует случаем? Может разок считал, а потом старое гонит?
fora983
страници не какой нет. просто считает подключения модуль и отключается связь с клиентом.
client.print("GET <a href="" title="http://"">http://"</a> + host + (getWithoutPort? "" : (":" + host)) + doc + "&" + data + " HTTP/1.1\r\n" +
67 "Host: " + host + (getWithoutPort? "" : (":" + host)) + "\r\n" +
68 "Connection: Close\r\n" +
69 "\r\n");
перепробовал уже разные запросы. и все не проходит
DIYMan
DIYMan аватар
В строку запроса добавь рандомный параметр, чтобы убедиться, что дело не в кешировании. Типа такого:
+ data + "&rnd=" + random(1000) + ...
