'Ethernet' is not a class, namespace, or enumeration
sergiocharm
Заливаю скетч мне пишет 'Ethernet' is not a class, namespace, or enumeration
Что это?
  Web Server
 A simple web server that shows the value of the analog input pins.
 using an Arduino Wiznet Ethernet shield.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 * Analog inputs attached to pins A0 through A5 (optional)
 created 18 Dec 2009
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
 modified 02 Sept 2015
 by Arturo Guadalupi
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 177);
byte Ethernet::buffer[500];
BufferFiller bfill;
void setup () {
  if (ether.begin(sizeof Ethernet::buffer, mac) == 0)
    Serial.println(F("Failed to access Ethernet controller"));
  ether.staticSetup(myip);
static word homePage() {
  long t = millis() / 1000;
  word h = t / 3600;
  byte m = (t / 60) % 60;
  byte s = t % 60;
  bfill = ether.tcpOffset();
  bfill.emit_p(PSTR(
    "HTTP/1.0 200 OK\r\n"
    "Content-Type: text/html\r\n"
    "Pragma: no-cache\r\n"
    "\r\n"
    "<meta http-equiv='refresh' content='1'/>"
    "<title>RBBB server</title>"
    "<h1>$D$D:$D$D:$D$D</h1>"),
      h/10, h%10, m/10, m%10, s/10, s%10);
  return bfill.position();
void loop () {
  word len = ether.packetReceive();
  word pos = ether.packetLoop(len);
  if (pos)  // check if valid tcp data is received
    ether.httpServerReply(homePage()); // send web page data
sergiocharm
Первый переделанный. Вот этот скетч я пытаюсь заливать но по данному айпи ничего не выходит.
// This is a demo of the RBBB running as webserver with the Ether Card
// 2010-05-28 <jc@wippler.nl> http://opensource.org/licenses/mit-license.php
#include <EtherCard.h>
// ethernet interface mac address, must be unique on the LAN
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
static byte myip[] = { 192,168,1,203 };
BufferFiller bfill;
void setup () {
  if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
  word h = t / 3600;
  byte s = t % 60;
  bfill.emit_p(PSTR(
    "\r\n"
void loop () {
