fatal error: queue.h: No such file or directory
Нет ответов
Heres_M
Уважаемые коллеги, помогите чайнику. При компиляции скетча пишет ошибку =>>>
Arduino: 1.6.12 (Windows 7), Плата:"Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\1\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10612 -build-path C:\Users\1\AppData\Local\Temp\arduino_build_300895 -warnings=more -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\libraries\ESP8266WebServer\examples\WebUpdate\WebUpdate.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\1\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10612 -build-path C:\Users\1\AppData\Local\Temp\arduino_build_300895 -warnings=more -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\libraries\ESP8266WebServer\examples\WebUpdate\WebUpdate.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\1\AppData\Local\Temp\arduino_build_300895\sketch\WebUpdate.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\ESP8266WiFi\src" "C:\Users\1\AppData\Local\Temp\arduino_build_300895\sketch\WebUpdate.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\ESP8266WiFi\src" "C:\Users\1\AppData\Local\Temp\arduino_build_300895\sketch\WebUpdate.ino.cpp" -o "C:\Users\1\AppData\Local\Temp\arduino_build_300895\preproc\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Program Files (x86)\Arduino\libraries\ESP8266WiFi\src/ESP8266WiFi.h:33:0,
                 from C:\Program Files (x86)\Arduino\libraries\ESP8266WebServer\examples\WebUpdate\WebUpdate.ino:5:
C:\Program Files (x86)\Arduino\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:26:19: fatal error: queue.h: No such file or directory
 #include <queue.h>
compilation terminated.
Используем библиотеку ESP8266WiFi версии 1.0 из папки: C:\Program Files (x86)\Arduino\libraries\ESP8266WiFi
exit status 1
Ошибка компиляции для платы Arduino/Genuino Uno.
_________________________________________________________________________________________
Скетч такой
  To upload through terminal you can use: curl -F "image=@firmware.bin" esp8266-webupdate.local/update
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
const char* host = "esp8266-webupdate";
const char* ssid = "........";
const char* password = "........";
ESP8266WebServer server(80);
const char* serverIndex = "<form method='POST' action='/update' enctype='multipart/form-data'><input type='file' name='update'><input type='submit' value='Update'></form>";
void setup(void){
  Serial.begin(115200);
  Serial.println();
  Serial.println("Booting Sketch...");
  WiFi.mode(WIFI_AP_STA);
  WiFi.begin(ssid, password);
  if(WiFi.waitForConnectResult() == WL_CONNECTED){
    MDNS.begin(host);
    server.on("/", HTTP_GET, [](){
      server.sendHeader("Connection", "close");
      server.send(200, "text/html", serverIndex);
    server.on("/update", HTTP_POST, [](){
      server.send(200, "text/plain", (Update.hasError())?"FAIL":"OK");
      ESP.restart();
      HTTPUpload& upload = server.upload();
      if(upload.status == UPLOAD_FILE_START){
        Serial.setDebugOutput(true);
        WiFiUDP::stopAll();
        Serial.printf("Update: %s\n", upload.filename.c_str());
        uint32_t maxSketchSpace = (ESP.getFreeSketchSpace() - 0x1000) & 0xFFFFF000;
        if(!Update.begin(maxSketchSpace)){//start with max available size
          Update.printError(Serial);
      } else if(upload.status == UPLOAD_FILE_WRITE){
        if(Update.write(upload.buf, upload.currentSize) != upload.currentSize){
      } else if(upload.status == UPLOAD_FILE_END){
        if(Update.end(true)){ //true to set the size to the current progress
          Serial.printf("Update Success: %u\nRebooting...\n", upload.totalSize);
        } else {
        Serial.setDebugOutput(false);
      yield();
    server.begin();
    MDNS.addService("http", "tcp", 80);
    Serial.printf("Ready! Open http://%s.local in your browser\n", host);
  } else {
    Serial.println("WiFi Failed");
void loop(void){
  server.handleClient();
  delay(1);
__________________________________________________________________________________________
Что такое queue.h и куда кго закидывать, если в нем проблема
