I2C: 2xMega2560, 1xUNO R3
Втр, 20/01/2015 - 15:35
подключил 3 девайса по I2C.
Master(ADR:1, PIN-20:SDA, PIN-21:SCL, GND) без какого резистора.
Slave1(ADR:2, PIN-20:SDA, PIN-21:SCL, GND)
Slave2(ADR:3, PIN-4:SDA, PIN-5:SCL, GND)
2 Мега общается и понимают друг друга. как только включаю UNO по I2C связь перерывается и ни что не общается.
вот код для Slave2-UNO:
#include <Wire.h> ///SLAVE Sender/// void setup() { Serial.begin(9600); Wire.begin(3); // join i2c bus with address #2 Wire.onRequest(requestEvent); // register event } void loop() { Wire.requestFrom(1, 20); // request 6 bytes from slave device #1 ///Receiving from Master ID1; Mega2560/// while(Wire.available()) // slave may send less than requested { char c = Wire.read(); // receive a byte as character Serial.print(c); // print the character } delay(500); } void requestEvent() { Wire.write("Hello my dear0000000 "); // respond with message of 6 bytes ///Sending to Master ID1; Mega2560/// // as expected by master }
и вот код Мастера Mega 2560:
#include <Wire.h> ///MASTER Receiver/// boolean in = LOW; void setup() { Wire.begin(1); // join i2c bus (address optional for master) Serial.begin(9600); // start serial for output Wire.onRequest(requestEvent); } void loop() { Wire.requestFrom(2, 20); // request 6 bytes from slave device #2 ////Receiving Slave ID2; Mega2560//// while(Wire.available()) // slave may send less than requested { char c = Wire.read(); // receive a byte as character Serial.print(c); // print the character } delay(500); Wire.requestFrom(3, 20); ///Receiving Slave ID3; Uno R3/// while(Wire.available()) // slave may send less than requested { char d = Wire.read(); // receive a byte as character Serial.print(d); // print the character } delay(500); } void requestEvent() { Wire.write("Amigo go home to fap "); // respond with message of 6 bytes ///Sending/// // as expected by master }
что здесь не так? как мне исправит общению
