кто-нибудь делел перчатку "сонар для слепых"?
Втр, 29/10/2013 - 15:34
У меня возникла проблема при повторении проекта:
http://grathio.com/2011/08/meet-the-tacit-project-its-sonar-for-the-blind/
Правда я использовал не Parallax, а обычные дальномеры HC-SR04, объединив Echo и Trig через библиотеку
newping.h - ничего не получилось. Помогите, пожалуйста, корректно изменить скетч на HC-SR04.
Перчатка нужна слепому другу!
Код покажите.
// Tacit, Wrist mounted tactile feedback for the blind.
// By Steve Hoefer at Grathio Labs (http://grathio.com)
// Version 12.02.04
// Copyright (c) 2012 Steve Hoefer
// Permission is hereby granted, free of charge, to any person obtaining a copy of this software and
// associated documentation files (the "Software"), to deal in the Software without restriction,
// including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense,
// and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so,
// subject to the following conditions:
// The above copyright notice and this permission notice shall be included in all copies or substantial
// portions of the Software.
// THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT
// LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN
// NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
// WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
// SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
// Written for Arduino authoring environment version 0022 and a Arduino Mini Pro 5V but should work on any Arduino/Arduino compatible that provides 5 volts.
// This version supports the following hardware:
// Parallax PING))) ultrasonic sensors for range finding
// Connect the GND pin to ground, +5V pin to +5V, and SIG to pin 2 or 3.
// Just about any small hobby servo. (Specifically Turnigy TG9)
// Connect the ground to ground, +V to RAW and the signal to pins 7 or 8.
// Version history:
// 11.08.07 - original
// 11.08.14 - Added code so servos apply constant pressure even when readings are not changing.
// 11.10.11 - Added pause after each sensor reading to fix reported issue with left sensor occasionally giving garbage responses.
// 12.02.04 - Changed license from CC BY-NC-SA to the MIT license.
#include <Servo.h>
const int MaxSensors = 2; // The number of sensor/servo pairs.
const int ServoPins[MaxSensors] = {7, 8}; // The pins they're on
const int RangingPins[MaxSensors] = {3, 2}; // The pins they're on
const int ReadingsPerSensor = 5; // The number of historic readings to consider when determining position.
const int TimePerDegree = 9; // ms per degree rotation on the servo to prevent servo motor electrical noise from interfering with the ultrasonic sensor readings
const int MinimumTurnDistance = 3; // Minimum number of degrees that the servo will turn. Keeps the servos from being too twitchy.
// Variables
Servo ServoList[MaxSensors]; // Array of servo objects for manipulating easily.
int sensorReadings[MaxSensors][ReadingsPerSensor]; // Hold past readings for each sensor.
int calculatedSenorReadings[MaxSensors]; // The calculated distance for each sensor.
int latestReading = 0; // Current position in the array for the most recent reading.
int servoLocations[MaxSensors]; // The current position of each sensor.
int SenorClose = 500; // Closest value we detect with the PING sensor. (Soundwave travel time in milliseconds.)
int SensorFar = 14000; // Furthest distance we register on the PING sensor. (Soundwave travel time in milliseconds.)
int ServoClose[MaxSensors] = {0, 160}; // Angle the servo turns to when something is closest.
int ServoFar[MaxSensors] = {70,110}; // Angle the servo turns to when something is at its furthest.
//Serial.begin(115200); // Uncomment the Serial.foo lines for testing.
//Serial.println("Begin...");
// Initialize the servo location and move them through a full range of motion so we know they work.
for (int i = 0; i < MaxSensors; i++){
ServoList[i].attach(ServoPins[i]);
delay(10);
ServoList[i].write(ServoClose[i]);
delay(500);
ServoList[i].write(ServoFar[i]);
delay(500);
ServoList[i].detach();
delay(100);
void loop(){
int i, j, oldLocation;
unsigned long delayTime;
// Loop through each range sensor
for (i = 0; i < MaxSensors; i++){
// Get the current sensor's range.
sensorReadings[i][latestReading] = getDistance(i);
// Figure out an averaged/smoothed readings based on this and past data.
calculatedSenorReadings[i] = calculateNewDistace(i);
// Set the servo to the correct angle.
oldLocation = servoLocations[i];
servoLocations[i] = map(calculatedSenorReadings[i], 0, 100, ServoClose[i], ServoFar[i]);
if (latestReading >= ReadingsPerSensor-1){ // Don't do anything until we have enough data to trend.
if (abs(servoLocations[i]-oldLocation) >= MinimumTurnDistance){ // Only try to turn it if we have somewhere to go.
delay(10);
ServoList[i].write(servoLocations[i]);
delayTime = (TimePerDegree * (abs(servoLocations[i]-oldLocation))+20); // Set a delay for the next reading so motor noise doesn't interfere with senor readings.
if (abs(delayTime)>500){ // If it can't do it in this amount of time // It's based on how far it has to turn to keep the delay to a minimum, response time at a maximum.
delayTime=500; // we'll get it next time. Keep it responsive.
delay(delayTime);
} else { // Otherwise if the reading hasn't changed enough write the old value to
ServoList[i].attach(ServoPins[i]); // the servo so that it will hold in place if it's applying pressure.
delay(10);
ServoList[i].write(oldLocation);
delay(50);
servoLocations[i]=oldLocation;
delay(20); // Added to fix left sensor misbehavior reported by Rob.
latestReading++; // Increment the reading counter so we know where we're at.
if (latestReading >= ReadingsPerSensor){ // Make sure we don't record more readings than we have space to hold.
latestReading = ReadingsPerSensor-1;
// Pop the oldest reading off the list.
for (j=0; j < ReadingsPerSensor-1; j++){
sensorReadings[i][j] = sensorReadings[i][j+1];
// function: calculateNewDistace(sensorNumber: Which sensor's data to process): Calculated distance in 0-100 range.
// Apply some averaging and smoothing to the recorded distance readings
// to take care of noisy data.
int calculateNewDistace(int sensorNumber){
int output = SensorFar; // Default value is the furthest distance.
float weightingFactor = 0.5; // How fast the reading's importance tapers off in time. (1= no taper, 0 = divide by zero error.)
float flickerFactor = 30; // When the change is greater than this, ignore it unless its two in a row. (It's probably noise.)
if (latestReading >= ReadingsPerSensor-1) { // Only do this if we have a full set of readings to sample.
int total = 0; // Average them with a weighting.
float currentWeight = 1; // New readings count more than older readings.
float percentagePossible = 0;
boolean flickered = false;
for (int i=ReadingsPerSensor-1; i >=0 ;i--){ // Check for flicker (This reduces jitter with something right on the threshold.)
flickered = false;
if (i==ReadingsPerSensor-1){
if ((abs(sensorReadings[sensorNumber][i])-abs(sensorReadings[sensorNumber][i-1]) > flickerFactor) &&
(abs(sensorReadings[sensorNumber][i-1])-abs(sensorReadings[sensorNumber][i-2]) > flickerFactor)){
flickered = true;
if (flickered==false){
total += (sensorReadings[sensorNumber][i] * currentWeight);
percentagePossible += currentWeight;
currentWeight *= weightingFactor;
output = total / percentagePossible;
return output;
// function: getDistance
// Take a sensor number (not pin number) and returns an int in the 0-100 range
// 0 = closest, 100= furthest. (It's a percentage of the distance that the software
// Note: Function is designed to be generic so that it can be swapped out for
// different kinds of ranging sensors.
// This version of the function is made for Parallax PING))) sensors
// For more info see http://arduino.cc/en/Tutorial/Ping
// and http://www.parallax.com/tabid/768/ProductID/92/Default.aspx
int getDistance(int sensorNumber){
long duration; // How long it takes a sonic pulse to reflect back.
int out; // The value we send back from the function
// Initialize the sensor and tell it to send out a ping.
pinMode(RangingPins[sensorNumber], OUTPUT);
digitalWrite(RangingPins[sensorNumber], LOW);
delayMicroseconds(2);
digitalWrite(RangingPins[sensorNumber], HIGH);
delayMicroseconds(5);
// Read the time in milliseconds until the value comes back.
pinMode(RangingPins[sensorNumber], INPUT);
duration = pulseIn(RangingPins[sensorNumber], HIGH);
// Trim the data into minimums and maximums and map it to the 0-100 output range.
duration = constrain(duration, SenorClose, SensorFar);
out = map(duration, SenorClose, SensorFar, 0, 100);
return out;
Вставка программного кода в тему/комментарий
Зачем вы выложили код из статьи, который работает?
Где код с этим:
#include <Servo.h>
#include <NewPing.h>
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
const int MaxSensors=2;
unsigned long pingTimer[MaxSensors];
unsigned int cm[MaxSensors];
uint8_t currentSensor = 0;
const int ServoPins[MaxSensors]={7, 8};
NewPing RangingPins[MaxSensors]={
NewPing(2, 2, MAX_DISTANCE),
NewPing(3, 3, MAX_DISTANCE)
const int ReadingsPerSensor = 5; // количество сохраняемых чтений для определегия положения
const int TimePerDegree = 9; // ms на 1 градус поворота сервопривода для предотвращения влияния сенсора
const int MinimumTurnDistance = 3; // минимальный угол поворота сервопривода для избежания дребезга
// Переменные
Servo ServoList[MaxSensors]; // массив сервопривода
int sensorReadings[MaxSensors][ReadingsPerSensor]; // сохранение предыдущего состояния сенсора
int calculatedSenorReadings[MaxSensors]; // расчётное расстояние для каждого сенсора
int latestReading = 0; // текущее состояние после считывания
int servoLocations[MaxSensors]; // текущее состояние каждого сенсора
int SenorClose = 500; // минимальное значение времени на одно перемещение - полсекунды
int SensorFar = 14000; // максимальное время на перемещение - 14 секунд
int ServoClose[MaxSensors] = {0, 160}; // угол поворота сервопривода при приближении
int ServoFar[MaxSensors] = {70,110}; // угол поворота при отдалении
//Serial.begin(115200); // открываем порт для теста
// инициализация сервоприводов
delay(10);
delay(500);
delay(500);
delay(100);
void loop(){
// цикл по каждому диапазону сенсора
delay(10);
delay(delayTime);
delay(10);
delay(50);
flickered = false;
flickered = true;
return output;
unsigned int duration; // How long it takes a sonic pulse to reflect back.
duration = RangingPins[sensorNumber].ping();
return out;
А человек упертый. все равно делает как ему хочется)))
Прочитайте еще раз сообщение #3, особенно 1 предложение и отредактируйте свое сообщение с кодом.
Это не заработает:
Как вы думаете зачем у датчика 2 отдельных вывода Echo и Trig? Вам не кажется алогичным соединять их в один и подключать к одному выводу дуины?
В библиотеке newping.h выводы arduino специально перепрограммируются сначала как выход, а потом на ожидание сигнала - как вход.
Вот ссылка:
http://code.google.com/p/arduino-new-ping/
С вставкой кода - принято, исправлюсь
Если ваши датчики могут работать с замкнутыми Echo и Trig, то код из статьи должен работать и с этими датчиками.
Спасибо за отклики - но в реале не работает пока, как надо...
И ещё я хотел бы поключить вместе с сервой и моторчик-вибратор с мобильника (4,7 В) - на ШИМ выход.
Сигнал на вибратор(analogWrite) должен быть обратно пропорциональный приблежению к препятствию.
У вас получилось с датчиками hc-sr04 если да,то как?
скажите, у вас уже получился образец?
хотел бы заказать у вас пару устройств или профинансировать разработку.
как с вами связаться? мой email: ivannmitrofanov@gmail.com
