Не могу понять, в чем проблема
T3mag
   А вот ошибки:
delta_manipulation__DONT_DELEATE_\delta_manipulation__DONT_DELEATE_.ino: In function 'void Cam()':
delta_manipulation__DONT_DELEATE_:38:25: error: 'DXL_ID_CR' was not declared in this scope
delta_manipulation__DONT_DELEATE_:43:5: error: 'Sent3' was not declared in this scope
C:\Users\Учитель\Desktop\delta_manipulation__DONT_DELEATE_\delta_manipulation__DONT_DELEATE_.ino: In function 'void find_angle(float, float, float)':
delta_manipulation__DONT_DELEATE_:66:19: error: expected unqualified-id before numeric constant
delta_manipulation__DONT_DELEATE_:68:22: error: 'Y' was not declared in this scope
delta_manipulation__DONT_DELEATE_:68:39: error: 'C2' was not declared in this scope
delta_manipulation__DONT_DELEATE_:70:47: error: expected ')' before ';' token
delta_manipulation__DONT_DELEATE_:75:7: error: expected ';' before 'float'
delta_manipulation__DONT_DELEATE_:76:24: error: 'yj' was not declared in this scope
delta_manipulation__DONT_DELEATE_:78:7: error: 'theta' was not declared in this scope
delta_manipulation__DONT_DELEATE_:78:15: error: 'angle' was not declared in this scope
C:\Users\Учитель\Desktop\delta_manipulation__DONT_DELEATE_\delta_manipulation__DONT_DELEATE_.ino: In function 'void full(float, float, float)':
delta_manipulation__DONT_DELEATE_:97:18: error: 'theta' was not declared in this scope
C:\Users\Учитель\Desktop\delta_manipulation__DONT_DELEATE_\delta_manipulation__DONT_DELEATE_.ino: In function 'void setup()':
delta_manipulation__DONT_DELEATE_:119:19: error: 'DEVICE_NAME' was not declared in this scope
delta_manipulation__DONT_DELEATE_:119:32: error: 'BAUFRATE' was not declared in this scope
exit status 1
И я не могу понять, в чем проблема.
Помогите пожалуйста
DetSimen
DetSimen аватар
Проблема, виима, в ДНК спрашивающего.  Удосужься сначала правила почитать и вставить код как надо. А потом еще и вопрос правильно сформулировать
Kakmyc
У автора кода почему не спросишь ?
T3mag
Я бы спросил, но я пишу с книги.
Можете обьяснить, по какой причине появились эти ошибки и как их можно исправить
DetSimen
DetSimen аватар
Пока правильно не вставишь код, никто его обсуждать не будет.  Если за час  не исправишь, тему удалю
T3mag пишет:
И что, в книге не приведён e-mail автора?
T3mag пишет:
Можете обьяснить,
Не можем пока код не будет вставлен по правилам форума, и пока Вы не зададите нормальные вопросы. В Вашем посте вопросов нет. Есть утверждение
T3mag пишет:
Что Вам на это ответить? Принято к сведению! Когда и если у Вас появятся вопросы - спрашивайте.
GarryC
Евгений, Вы очень суровы, хотя я тоже не могу понять, что можно ответить человеку, не способному перевести сообщение компилятора об ошибке, кроме как порекомендовать учебник по С.
GarryC пишет:
я покопался в коде ТС и у меня есть что сказать. прежде чем отправлять его в учебники... Но полностью поддерживаю недовольство Деда и Евгения и подожду. рока ТС вставит код правильно
Суров? Хорошо исправляюсь.
T3mag, поясняю про второе сообщение об ошибке (из Вашего списка)
В коде, в строке № ХЗ у Вас используется переменная Sent3, которая нигде не определена. Скорее всего, Вы допустили опечатку в определении этой переменной в строке № ХЗ или в её использовании в строке № ХЗ, когда вручную перепечатывали код из книжки (вместо того, чтобы найти и скачать примеры или хотя бы отсканировать и оцифровать их).
T3mag Вам стало понятнее?
ЕвгенийП пишет:
 Вы допустили когда вручную перепечатывали код из книжки (вместо того, чтобы найти и скачать примеры или хотя бы отсканировать и оцифровать их).
Евгений, ну вот, вы уже все сказали, что я собирался.
ТС - надо же быть таким идиотом, чтобы вручную перепечатывать код. когда примеры лежат на гитхабе там же, где вы скачивали библиотеку....
DetSimen
DetSimen аватар
Ну, я предупреждал.
DetSimen пишет:
T3mag
Да
Да, может, человеку 10 лет. Чего днк-то сразу? Накинулись!
T3mag
Спасибо за информацию.
Попробую с нуля все переписать.
GarryC
Конечно, я только рад, что Ардуино снизила порог вхождения, но иногда складывается ощущение, что она его снизила до недопустимых значений.
T3mag
Это мой первый код. Естественно я ошибся много, но это же не повод налетать с оскорблениями типа: проверь своё ДНК итд.
Каждый в начале допускает много ошибок.
T3mag пишет:
ты правда идиот?
T3mag пишет:
почему не повод-то?  Твое решение "переписать все заново" подтверждает этот вывод.
T3mag
Естественно я буду сканировать текст фото.
Моя цель не тупо все скопировать, а разобраться как работает.
T3mag пишет:
Это не повод. А вот то, что Вы начали постить на форуме не прочитав специальной, для таких как Вы, темы "ПЕСОЧНИЦА. НОВИЧОК, ПРОЧТИ!" - во общем-то, повод. Так что, вместо качания прав, лучше прочитайте её и ведите себя нормально.
GarryC
Вот такой подход "разобраться, как работает" можно только приветствовать, но для этого Вам надо изучить язык С.
T3mag пишет:
Моя цель ... разобраться как работает.
Код такого размера и сложности? С нулевыми знаниями? Цель недостижима. Сначала нужно хоть на каком-то уровне изучить язык программирования. Так что начинайте с этого и с более простых примеров.
BOOM
BOOM аватар
... например, диодиком поморгать для начала )))
