Не отрабатывает код
Нет ответов
AlexVapn
Здравствуйте! Помогите пожалуйста.
Есть код:
int stage=0;
int start=0;
// I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
//#include "MPU6050.h" // not necessary if using MotionApps include file
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    #include "Wire.h"
#endif
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for SparkFun breakout and InvenSense evaluation board)
// AD0 high = 0x69
MPU6050 mpu;
//MPU6050 mpu(0x69); // <-- use for AD0 high
   NOTE: In addition to connection 3.3v, GND, SDA, and SCL, this sketch
   depends on the MPU-6050's INT pin being connected to the Arduino's
   external interrupt #0 pin. On the Arduino Uno and Mega 2560, this is
   digital I/O pin 2.
   NOTE: Arduino v1.0.1 with the Leonardo board generates a compile error
   when using Serial.write(buf, len). The Teapot output uses this method.
   The solution requires a modification to the Arduino USBAPI.h file, which
   is fortunately simple, but annoying. This will be fixed in the next IDE
   release. For more info, see these links:
   http://arduino.cc/forum/index.php/topic,109987.0.html
   http://code.google.com/p/arduino/issues/detail?id=958
// uncomment "OUTPUT_READABLE_QUATERNION" if you want to see the actual
// quaternion components in a [w, x, y, z] format (not best for parsing
// on a remote host such as Processing or something though)
//#define OUTPUT_READABLE_QUATERNION
// uncomment "OUTPUT_READABLE_EULER" if you want to see Euler angles
// (in degrees) calculated from the quaternions coming from the FIFO.
// Note that Euler angles suffer from gimbal lock (for more info, see
// http://en.wikipedia.org/wiki/Gimbal_lock)
//#define OUTPUT_READABLE_EULER
// uncomment "OUTPUT_READABLE_YAWPITCHROLL" if you want to see the yaw/
// pitch/roll angles (in degrees) calculated from the quaternions coming
// from the FIFO. Note this also requires gravity vector calculations.
// Also note that yaw/pitch/roll angles suffer from gimbal lock (for
// more info, see: http://en.wikipedia.org/wiki/Gimbal_lock)
#define OUTPUT_READABLE_YAWPITCHROLL
// uncomment "OUTPUT_READABLE_REALACCEL" if you want to see acceleration
// components with gravity removed. This acceleration reference frame is
// not compensated for orientation, so +X is always +X according to the
// sensor, just without the effects of gravity. If you want acceleration
// compensated for orientation, us OUTPUT_READABLE_WORLDACCEL instead.
#define OUTPUT_READABLE_REALACCEL
// uncomment "OUTPUT_READABLE_WORLDACCEL" if you want to see acceleration
// components with gravity removed and adjusted for the world frame of
// reference (yaw is relative to initial orientation, since no magnetometer
// is present in this case). Could be quite handy in some cases.
//#define OUTPUT_READABLE_WORLDACCEL
// uncomment "OUTPUT_TEAPOT" if you want output that matches the
// format used for the InvenSense teapot demo
//#define OUTPUT_TEAPOT
#define INTERRUPT_PIN 2  // use pin 2 on Arduino Uno & most boards
#define LED_PIN 13 // (Arduino is 13, Teensy is 11, Teensy++ is 6)
bool blinkState = false;
// MPU control/status vars
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorInt16 aa;         // [x, y, z]            accel sensor measurements
VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
VectorFloat gravity;    // [x, y, z]            gravity vector
float euler[3];         // [psi, theta, phi]    Euler angle container
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
// packet structure for InvenSense teapot demo
uint8_t teapotPacket[14] = { '$', 0x02, 0,0, 0,0, 0,0, 0,0, 0x00, 0x00, '\r', '\n' };
// ===               INTERRUPT DETECTION ROUTINE                ===
volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
    mpuInterrupt = true;
// ===                      INITIAL SETUP                       ===
    // join I2C bus (I2Cdev library doesn't do this automatically)
        Wire.begin();
        Wire.setClock(400000); // 400kHz I2C clock. Comment this line if having compilation difficulties
    #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
        Fastwire::setup(400, true);
    #endif
    // initialize serial communication
    // (115200 chosen because it is required for Teapot Demo output, but it's
    // really up to you depending on your project)
    while (!Serial); // wait for Leonardo enumeration, others continue immediately
    // NOTE: 8MHz or slower host processors, like the Teensy @ 3.3v or Ardunio
    // Pro Mini running at 3.3v, cannot handle this baud rate reliably due to
    // the baud timing being too misaligned with processor ticks. You must use
    // 38400 or slower in these cases, or use some kind of external separate
    // crystal solution for the UART timer.
    // initialize device
    Serial.println(F("Initializing I2C devices..."));
    mpu.initialize();
    pinMode(INTERRUPT_PIN, INPUT);
    // verify connection
    Serial.println(F("Testing device connections..."));
    Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
//    // wait for ready
//    Serial.println(F("\nSend any character to begin DMP programming and demo: "));
//    while (Serial.available() && Serial.read()); // empty buffer
//    while (!Serial.available());                 // wait for data
//    while (Serial.available() && Serial.read()); // empty buffer again
    // load and configure the DMP
    Serial.println(F("Initializing DMP..."));
    devStatus = mpu.dmpInitialize();
    // supply your own gyro offsets here, scaled for min sensitivity
    mpu.setXGyroOffset(220);
    mpu.setYGyroOffset(76);
    mpu.setZGyroOffset(-85);
    mpu.setZAccelOffset(1788); // 1688 factory default for my test chip
    // make sure it worked (returns 0 if so)
    if (devStatus == 0) {
        // turn on the DMP, now that it's ready
        Serial.println(F("Enabling DMP..."));
        mpu.setDMPEnabled(true);
        // enable Arduino interrupt detection
        Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
        attachInterrupt(digitalPinToInterrupt(INTERRUPT_PIN), dmpDataReady, RISING);
        mpuIntStatus = mpu.getIntStatus();
        // set our DMP Ready flag so the main loop() function knows it's okay to use it
        Serial.println(F("DMP ready! Waiting for first interrupt..."));
        dmpReady = true;
        // get expected DMP packet size for later comparison
        packetSize = mpu.dmpGetFIFOPacketSize();
    } else {
        // ERROR!
        // 1 = initial memory load failed
        // 2 = DMP configuration updates failed
        // (if it's going to break, usually the code will be 1)
        Serial.print(F("DMP Initialization failed (code "));
        Serial.print(devStatus);
        Serial.println(F(")"));
    // configure LED for output
    pinMode(LED_PIN, OUTPUT);
    pinMode(6,  OUTPUT);
    pinMode(7,  OUTPUT);
    pinMode(8,  OUTPUT);
    pinMode(9,  OUTPUT);
    digitalWrite(6, LOW);
    digitalWrite(7, LOW);
    digitalWrite(8, LOW);
    digitalWrite(9, LOW);
    Serial.println(F("Prepare for deployment"));
    delay(1000); //
// ===                    MAIN PROGRAM LOOP                     ===
    // if programming failed, don't try to do anything
    if (!dmpReady) return;
    // wait for MPU interrupt or extra packet(s) available
    while (!mpuInterrupt && fifoCount < packetSize) {
      if (stage==0 && start>0)
        digitalWrite(6, HIGH);
        digitalWrite(7, HIGH);
        digitalWrite(8, HIGH);
        digitalWrite(9, HIGH);
        if (aaReal.z>1600 || aaReal.z<150)  // здесь экспериментально надо подобрать значения сравнения для ускорения по оси Z
        {                                   // пока опускаются поршни должна успеть произойти калибровка датчика (секунд 30-60 нужно на это)
          digitalWrite(6, LOW);             // нужно чтобы цилиндпы выдвигались не очень быстро, плавно и останавливались четкоа по сигналу (его отсутствию)
          stage=4;
          start=0;
          Serial.println(F("Supports Ready"));
          delay(2000);
      if (stage==4 && start>0) // ось Х
        if (ypr[2] * 180/M_PI < 0)
        if (ypr[2] * 180/M_PI > 0)
        if (ypr[2] * 180/M_PI < 0.50 && ypr[2] * 180/M_PI > -0.50) // для уравновешивания осей экспериментально подобрать оптимальный промежуток для нуля (четко нуля добиться нереально, поэтому нужно учитывать отклонения допустимые +- 0,5 град здесь)
          stage=5;
          start=0;
          Serial.println(F("X leveling Ready"));
          delay(2000);
      if (stage==5 && start>0) // ось У
        if (ypr[1] * 180/M_PI < 0)
        if (ypr[1] * 180/M_PI > 0)
        if (ypr[1] * 180/M_PI < 0.50 && ypr[1] * 180/M_PI > -0.50) // аналогично для этой оси
          stage=6;
          start=0;
          Serial.println(F("Y leveling Ready"));
          Serial.println(F("Leveling complete!"));
          delay(2000);
    // reset interrupt flag and get INT_STATUS byte
    // get current FIFO count
    fifoCount = mpu.getFIFOCount();
    // check for overflow (this should never happen unless our code is too inefficient)
    if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
        // reset so we can continue cleanly
        mpu.resetFIFO();
//        Serial.println(F("FIFO overflow!"));
    // otherwise, check for DMP data ready interrupt (this should happen frequently)
    } else if (mpuIntStatus & 0x02) {
        // wait for correct available data length, should be a VERY short wait
        while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
        // read a packet from FIFO
        mpu.getFIFOBytes(fifoBuffer, packetSize);
        // track FIFO count here in case there is > 1 packet available
        // (this lets us immediately read more without waiting for an interrupt)
        fifoCount -= packetSize;
        #ifdef OUTPUT_READABLE_YAWPITCHROLL
            // display Euler angles in degrees
            mpu.dmpGetQuaternion(&q, fifoBuffer);
            mpu.dmpGetGravity(&gravity, &q);
            mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
//            Serial.print("ypr\t");
//            Serial.print(ypr[0] * 180/M_PI);
//            Serial.print("\t");
//            Serial.print(ypr[1] * 180/M_PI);
//            Serial.println(ypr[2] * 180/M_PI);
        #endif
        #ifdef OUTPUT_READABLE_REALACCEL
            // display real acceleration, adjusted to remove gravity
            mpu.dmpGetAccel(&aa, fifoBuffer);
            mpu.dmpGetLinearAccel(&aaReal, &aa, &gravity);
//            Serial.print("areal\t");
//            Serial.print(aaReal.x);
//            Serial.print(aaReal.y);
//            Serial.println(aaReal.z);
        #endif
if (stage==6){
            Serial.print("\t");
            Serial.print("\t");
        // blink LED to indicate activity
        blinkState = !blinkState;
        digitalWrite(LED_PIN, blinkState);
        start++;
Отрабатывает полностью, но когда я хочу сделать его как подпрограмму, он не работает, может кто подскажет, что я делаю не так?
#include <SoftwareSerial.h>
#include "I2Cdev.h"
int stage = 0;
int start = 1;
int star = 0;
int b_1;
int b_2; int b_3; int b_4; int b_5; int b_6; int b_7; int b_8;
SoftwareSerial Serial100(11, 12);
#include "Wire.h"
#endif
MPU6050 mpu;
uint8_t teapotPacket[14] = { '$', 0x02, 0, 0, 0, 0, 0, 0, 0, 0, 0x00, 0x00, '\r', '\n' };
  Wire.begin();
#endif
  Serial100.begin(9600);
  while (!Serial);
  mpu.initialize();
    dmpReady = true;
  } else {
    // ERROR!
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  delay(1000); //
  if (Serial100.available()) { //если получили данные по bluetooth
        b_1 = Serial100.read(); //читаем первый байт данных
        while  (!Serial100.available());//ожидаем следующий байт
        b_2 = Serial100.read(); //читаем второй байт данных
        b_3 = Serial100.read(); //читаем третий байт данных
        b_4 = Serial100.read(); //читаем третий байт данных
        b_5 = Serial100.read(); //читаем третий байт данных
        b_6 = Serial100.read(); //читаем третий байт данных
        b_7 = Serial100.read(); //читаем третий байт данных
        b_8 = Serial100.read(); //читаем третий байт данных
        Serial100.flush();//очищаем буфер, т.к. больше ничего мы не передаем
    if (b_6 == 1) {
    } else if (b_6 == 2) {
//      if (star == 0) {
      gyr();
 //   star++;
    else {
void gyr()
         if (stage == 0 && start > 0)
            if (aaReal.z > 1600 || aaReal.z < 150) // здесь экспериментально надо подобрать значения сравнения для ускорения по оси Z
              stage = 4;
              start = 0;
              delay(2000);
          if (stage == 4 && start > 0) // ось Х
            if (ypr[2] * 180 / M_PI < 0)
            if (ypr[2] * 180 / M_PI > 0)
            if (ypr[2] * 180 / M_PI < 0.50 && ypr[2] * 180 / M_PI > -0.50) // для уравновешивания осей экспериментально подобрать оптимальный промежуток для нуля (четко нуля добиться нереально, поэтому нужно учитывать отклонения допустимые +- 0,5 град здесь)
              stage = 5;
              start = 0;
              delay(2000);
          if (stage == 5 && start > 0) // ось У
            if (ypr[1] * 180 / M_PI < 0)
            if (ypr[1] * 180 / M_PI > 0)
            if (ypr[1] * 180 / M_PI < 0.50 && ypr[1] * 180 / M_PI > -0.50) // аналогично для этой оси
              stage = 6;
              start = 0;
              delay(2000);
          mpu.resetFIFO();
#endif
#endif
          if (stage == 6) {
            Serial.print(ypr[0] * 180 / M_PI);
            Serial.print("\t");
            Serial.print(ypr[1] * 180 / M_PI);
            Serial.print("\t");
            Serial.println(ypr[2] * 180 / M_PI);
          start++;
