Не заливается скетч
chiffa
Всем привет. Пытаю сделать читалку карт через nfs, заливаю скетч:
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_PN532.h>
// If using the breakout with SPI, define the pins for SPI communication.
#define PN532_SCK  (2)
#define PN532_MOSI (3)
#define PN532_SS   (4)
#define PN532_MISO (5)
// If using the breakout or shield with I2C, define just the pins connected
// to the IRQ and reset lines.  Use the values below (2, 3) for the shield!
#define PN532_IRQ   (2)
#define PN532_RESET (3)  // Not connected by default on the NFC Shield
// Uncomment just _one_ line below depending on how your breakout or shield
// is connected to the Arduino:
// Use this line for a breakout with a software SPI connection (recommended):
Adafruit_PN532 nfc(PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS);
// Use this line for a breakout with a hardware SPI connection.  Note that
// the PN532 SCK, MOSI, and MISO pins need to be connected to the Arduino's
// hardware SPI SCK, MOSI, and MISO pins.  On an Arduino Uno these are
// SCK = 13, MOSI = 11, MISO = 12.  The SS line can be any digital IO pin.
//Adafruit_PN532 nfc(PN532_SS);
// Or use this line for a breakout or shield with an I2C connection:
//Adafruit_PN532 nfc(PN532_IRQ, PN532_RESET);
#if defined(ARDUINO_ARCH_SAMD)
// for Zero, output on USB Serial console, remove line below if using programming port to program the Zero!
// also change #define in Adafruit_PN532.cpp library file
   #define Serial SerialUSB
#endif
void setup(void) {
  #ifndef ESP8266
    while (!Serial); // for Leonardo/Micro/Zero
  #endif
  Serial.begin(115200);
  Serial.println("Hello!");
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.print("Didn't find PN53x board");
    while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
  // configure board to read RFID tags
  nfc.SAMConfig();
  Serial.println("Waiting for an ISO14443A Card ...");
  bool success;
  // set shield to inListPassiveTarget
  success = nfc.inListPassiveTarget();
  if(success) {
    Serial.println("CARD FOUND");
    uint8_t selectApdu[] = {0x00, /* CLA */
                            0xA4, /* INS */
                            0x04, /* P1 ) */
                            0x00, /* P2  */
                            0x0E, /* Lc  */
                            0x32, 0x50, 0x41, 0x59, 0x2E, 0x53, 0x59, 0x53, 0x2E, 0x44, 0x44, 0x46, 0x30, 0x31, /* Data = Lc*/
                            0x00  /* Le */ };
    uint8_t response[255];
    memset(response, 0, sizeof(response));
    uint8_t responseLength = sizeof(response);
    success = nfc.inDataExchange(selectApdu, sizeof(selectApdu), response, &responseLength);
    if(success) {
      Serial.print("responseLength: "); Serial.println(responseLength);
      nfc.PrintHexChar(response, responseLength);
    uint8_t selectApdu_1[] = {0x00, 0xA4, 0x04, 0x00, 0x07, 0xA0, 0x00, 0x00, 0x00, 0x04, 0x10, 0x10 };
    uint8_t response_1[255];
    memset(response_1, 0, sizeof(response_1));
    uint8_t responseLength_1 = sizeof(response_1);
    success = nfc.inDataExchange(selectApdu_1, sizeof(selectApdu_1), response_1, &responseLength_1);
    if(success) {
      Serial.print("responseLength: "); Serial.println(responseLength_1);
      nfc.PrintHexChar(response_1, responseLength_1);
если просто компилить код, то все ок. при попытке аплоуда получаю ошибку:
In function 'global constructors keyed to 65535_0_readMifare.ino.cpp.o':
lto1.exe: internal compiler error: Segmentation fault
Please submit a full bug report,
выявил, что такое происходит из-за повторного использования "nfc.PrintHexChar", если одну из них закомитить - получается нормально.
Подскажите, как правильно реализовать обращение к смарт карте несколько раз в одном цикле. Спасибо!
chiffa
сабж можно закрывать. вопрос решился апдейтом ИДЕ
