Одна логическая ошибка
ua6em
ua6em аватар
Случайно обнаружил одну логическую ошибку в коде примера блинк без делея, я один её вижу или ГУРУ тоже о ней знают? )))
  Blink without Delay
  Turns on and off a light emitting diode (LED) connected to a digital pin,
  without using the delay() function. This means that other code can run at the
  same time without being interrupted by the LED code.
  The circuit:
  - Use the onboard LED.
  - Note: Most Arduinos have an on-board LED you can control. On the UNO, MEGA
    and ZERO it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN
    is set to the correct LED pin independent of which board is used.
    If you want to know what pin the on-board LED is connected to on your
    Arduino model, check the Technical Specs of your board at:
    https://www.arduino.cc/en/Main/Products
  created 2005
  by David A. Mellis
  modified 8 Feb 2010
  by Paul Stoffregen
  modified 11 Nov 2013
  by Scott Fitzgerald
  modified 9 Jan 2017
  by Arturo Guadalupi
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
// constants won't change. Used here to set a pin number:
const int ledPin =  LED_BUILTIN;// the number of the LED pin
// Variables will change:
int ledState = LOW;             // ledState used to set the LED
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0;        // will store last time LED was updated
// constants won't change:
const long interval = 1000;           // interval at which to blink (milliseconds)
  // set the digital pin as output:
  pinMode(ledPin, OUTPUT);
  // here is where you'd put code that needs to be running all the time.
  // check to see if it's time to blink the LED; that is, if the difference
  // between the current time and last time you blinked the LED is bigger than
  // the interval at which you want to blink the LED.
  if (currentMillis - previousMillis >= interval) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW) {
      ledState = HIGH;
    } else {
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(ledPin, ledState);
andycat
andycat аватар
42 строка не тот тип - оно?
DetSimen
DetSimen аватар
нинаю, что ты нашол, я всегда пишу
unsigned long previousMillis = 0 - interval -1;
и в сетапе после pinmode, ставлю начальные условия
иначе первую секунду состояние неопределено.
ua6em
ua6em аватар
DetSimen пишет:
этого я не знал, поэтому previousMillis инициирую последней строкой в setup, не, не оно и не тип данных, я жеж сказал - ЛОГИЧЕСКАЯ )))
ЛОГИЧЕСКОЙ не вижу
rkit
Онлайн
Не могу назвать великой ошибкой, но правильнее так:
previousMillis += interval;
По-моему rkit сливает карму на второй космической скорости. С EEPROM лажает по-полной, да и тут ещё... Или опять "просто пример" привёл?
sadman41 пишет:
колееги, имхо, зря наезжаете на rkit. Я б не назвал это "логической ошибкой", но поправка реально полезная.
Поясню на примере. Положим, интервал у вас один час и проверяете вы его с точностью в 10 минут. Тогда в исходном коде 10 отсчитанных интервалов займут неопределенное время от 10 до почти 12 часов. а с поправкой rkit длительность 10 периодов не отклонится от 10 часов более чем на 10 минут
ua6em
ua6em аватар
rkit пишет:
да, это оно )))
То-есть, строкой выше программист ещё помнил, что интервал может быть больше, а строкой ниже - забыл.
Этот тот самый когнитивный диссонанс...
"Какой мерой меряете..."
Потеря мерности однако и, если этот интервал использовать в долгую ошибка будет накапливаться
DetSimen
DetSimen аватар
а если currentMillis станет вдруг больше previous больше чем на 2+ интервала (всякое буваеть), то условие сработает 2+ раза подряд через время выполнения loop, а не через interval.  для опроса даччиков это может быть ошибка
Но в данном случае - пофик.
DetSimen пишет:
а если currentMillis станет вдруг больше previous больше чем на 2 интервала (всякое буваеть), то условие сработает 2+ раза подряд через время выполнения loop, а не через interval.  для опроса даччиков это может быть ошибка
это уже зависит от того, что нам важнее - точный интервал или среднее количество срабатываний за период.
ua6em
ua6em аватар
DetSimen пишет:
при правильно спроектированной программе джиттер будет в пределах 1 миллисекунды
Logik
b707 пишет:
DetSimen пишет:
Истину гутариш.
Присвоение интервала повышает точность формирования каждого но вносит небольшую систематическую погрешность. Потому точность N интервалов снижается. Добавление интервала - строго наоборот.
Обсуждалось не раз.
wdrakula
wdrakula аватар
Logik пишет:
Обсуждалось не раз.
В кои-то веки  соглашусь ;)). Эта тема, примерно как "переполнение миллис"!
Что важнее: интервал между событиями или распределение событий. Тут уж кому поп, а кому - панимашь - свиной хрящик! ;)) в том смысле, что задачи разные бывают.
Хотя в обычном, "десктопном" программировании под "интервал 10мс" понимают "интервал НЕ МЕНЬШЕ 10 мс". Что означает конструкцию: <previousMillis> = <currentMillis>.
ua6em
ua6em аватар
так в том то и дело, что сталкивался с применением этой конструкции в простых часах, то-есть в них  изначально запрограммирована накапливающаяся ошибка и она за сутки весьма значительна
Запрос миллиса, выполненный в удачный момент может сбить ход этого миллиса. Селяви. Если кому-то пришло в голову делать stratum1 на миллисе, то извините.
Ворота
Ворота аватар
Блин, ну и темы у нас ...
negavoid
От присоединяюсь к воротам, ну и темы у вас :) я вообще сегодня просыпаюсь, открываю тему про int-float, а там уже горите в аду, ботаны-переростки :))) всё проспал, всё )))
Ворота
Ворота аватар
negavoid пишет:
тему про int-float
Чё за тема? Почему без меня? Дай ссылочку, пожалуйста.
negavoid
Что-то мне не найти, наверное снесли уже; в общем, пришёл новичок, объявил переменную, как int, и спрашивает, а чего это у меня дробная часть не выводится, ну потом 20 постов срача (с правильным ответом в первой пятерке разумеется), а потом он таки нашёл линк на типы данных и послал всех местных ботанов гореть в аду :)
Logik
Чего ж никто ему про работу с фиксированной точкой не рассказал. Слабо?
ua6em
ua6em аватар
Ворота пишет:
после вчерашнего для отдыха мозгов, вполне жеж тема
ты лучше скажи, что творится в мозгу программиста этот алгоритм написавшего...
За такие не логические поступки я бы сержанта включил конкретно (бег 10 километров, отжимания час и т.д.)
astwo
Так для программистов устава не написали. Точнее написали, но находятся деятели, что считают что устав написан для слабаков, а вытаскивания из жопы мира хватит форума в интернете.
nik182
negavoid пишет:
Жаль что тему снесли. Очень показательная была. Заблокировали бы лучше да новичкам показывали как не надо себя вести.
Logik
Спакуха! Считай восстановили http://arduino.ru/forum/programmirovanie/kak-zapisat-long-kak-byte
nik182
Не, здесь человек никуда никого не посылает, не интересно.
