первый проект(esp8266_deauther) ,ищу помощи
Чт, 20/06/2019 - 19:18
здравствуйте. помогите исправить ошибки.
первый проект делаю , не знаю куда смотреть.
проект https://github.com/akarsh98/esp8266_deauther
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Плата:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200" In file included from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_CircuitPlayground.h:3:0, from sketch\A_config.h:1, from sketch\LED.h:9, from sketch\LED.cpp:1: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_Circuit_Playground.h:100:3: error: 'Adafruit_CPlay_FreeTouch' does not name a type Adafruit_CPlay_FreeTouch cap[7]; ///< the array of capacitive touch sensors ^ In file included from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_CircuitPlayground.h:3:0, from sketch\A_config.h:1, from sketch\DisplayUI.h:5, from sketch\DisplayUI.cpp:1: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_Circuit_Playground.h:100:3: error: 'Adafruit_CPlay_FreeTouch' does not name a type Adafruit_CPlay_FreeTouch cap[7]; ///< the array of capacitive touch sensors ^ In file included from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_CircuitPlayground.h:3:0, from sketch\A_config.h:1, from sketch\Settings.h:11, from sketch\Settings.cpp:1: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_Circuit_Playground.h:100:3: error: 'Adafruit_CPlay_FreeTouch' does not name a type Adafruit_CPlay_FreeTouch cap[7]; ///< the array of capacitive touch sensors ^ Несколько библиотек найдено для "ArduinoJson.h" Используется: C:\Users\1\Documents\Arduino\libraries\ArduinoJson Не используется: C:\Users\1\Documents\Arduino\libraries\ArduinoJson-6.x Несколько библиотек найдено для "SH1106Wire.h" Используется: C:\Users\1\Documents\Arduino\libraries\esp8266-oled-ssd1306-master Не используется: C:\Users\1\Documents\Arduino\libraries\ESP8266_and_ESP32_Oled_Driver_for_SSD1306_display In file included from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_CircuitPlayground.h:3:0, from sketch\A_config.h:1, from sketch\Settings.h:11, from sketch\SSIDs.h:13, from sketch\SSIDs.cpp:1: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_Circuit_Playground.h:100:3: error: 'Adafruit_CPlay_FreeTouch' does not name a type Adafruit_CPlay_FreeTouch cap[7]; ///< the array of capacitive touch sensors ^ In file included from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_CircuitPlayground.h:3:0, from sketch\A_config.h:1, from sketch\Settings.h:11, from sketch\SSIDs.h:13, from sketch\Attack.h:12, from sketch\Attack.cpp:1: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_Circuit_Playground.h:100:3: error: 'Adafruit_CPlay_FreeTouch' does not name a type Adafruit_CPlay_FreeTouch cap[7]; ///< the array of capacitive touch sensors ^ exit status 1 In file included from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_CircuitPlayground.h:3:0, from sketch\A_config.h:1, from sketch\CLI.h:11, from sketch\CLI.cpp:1: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_Circuit_Playground.h:100:3: error: 'Adafruit_CPlay_FreeTouch' does not name a type Adafruit_CPlay_FreeTouch cap[7]; ///< the array of capacitive touch sensors ^ In file included from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_CircuitPlayground.h:3:0, from sketch\A_config.h:1, from sketch\Settings.h:11, from sketch\SSIDs.h:13, from sketch\Scan.h:8, from sketch\Scan.cpp:1: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_Circuit_Playground.h:100:3: error: 'Adafruit_CPlay_FreeTouch' does not name a type Adafruit_CPlay_FreeTouch cap[7]; ///< the array of capacitive touch sensors ^ In file included from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_CircuitPlayground.h:3:0, from sketch\A_config.h:1, from sketch\Settings.h:11, from D:\arduino\esp8266_deauther-master\esp8266_deauther\esp8266_deauther.ino:27: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_Circuit_Playground.h:100:3: error: 'Adafruit_CPlay_FreeTouch' does not name a type Adafruit_CPlay_FreeTouch cap[7]; ///< the array of capacitive touch sensors ^ In file included from sketch\wifi.h:16:0, from D:\arduino\esp8266_deauther-master\esp8266_deauther\esp8266_deauther.ino:51: C:\Users\1\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h: In member function 'virtual size_t ESP8266WebServer::_currentClientWrite_P(const char*, size_t)': C:\Users\1\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:142:83: error: 'class WiFiClient' has no member named 'write_P' virtual size_t _currentClientWrite_P(PGM_P b, size_t l) { return _currentClient.write_P( b, l ); } ^ In file included from C:\Users\1\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266mDNS\src/ESP8266mDNS.h:45:0, from sketch\wifi.h:18, from D:\arduino\esp8266_deauther-master\esp8266_deauther\esp8266_deauther.ino:51: C:\Users\1\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266mDNS\src/ESP8266mDNS_Legacy.h: At global scope: C:\Users\1\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266mDNS\src/ESP8266mDNS_Legacy.h:131:3: error: 'WiFiEventHandler' does not name a type WiFiEventHandler _disconnectedHandler; ^ C:\Users\1\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266mDNS\src/ESP8266mDNS_Legacy.h:132:3: error: 'WiFiEventHandler' does not name a type WiFiEventHandler _gotIPHandler; ^ In file included from C:\Users\1\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266mDNS\src/ESP8266mDNS.h:46:0, from sketch\wifi.h:18, from D:\arduino\esp8266_deauther-master\esp8266_deauther\esp8266_deauther.ino:51: C:\Users\1\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266mDNS\src/LEAmDNS.h:1153:5: error: 'WiFiEventHandler' does not name a type WiFiEventHandler m_DisconnectedHandler; ^ C:\Users\1\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266mDNS\src/LEAmDNS.h:1154:5: error: 'WiFiEventHandler' does not name a type WiFiEventHandler m_GotIPHandler; ^ In file included from D:\arduino\esp8266_deauther-master\esp8266_deauther\esp8266_deauther.ino:51:0: sketch\wifi.h: In function 'void stopAP()': wifi.h:86:14: error: 'class WiFiClass' has no member named 'persistent' WiFi.persistent(false); ^ wifi.h:87:29: error: no matching function for call to 'WiFiClass::disconnect(bool)' WiFi.disconnect(true); ^ sketch\wifi.h:87:29: note: candidate is: In file included from sketch\A_config.h:4:0, from sketch\Settings.h:11, from D:\arduino\esp8266_deauther-master\esp8266_deauther\esp8266_deauther.ino:27: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\WiFi\src/WiFi.h:130:9: note: int WiFiClass::disconnect() int disconnect(void); ^ C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\WiFi\src/WiFi.h:130:9: note: candidate expects 0 arguments, 1 provided In file included from D:\arduino\esp8266_deauther-master\esp8266_deauther\esp8266_deauther.ino:51:0: sketch\wifi.h: In function 'void startAP(String, String, String, uint8_t, bool, bool)': wifi.h:227:10: error: 'class WiFiClass' has no member named 'softAPConfig' WiFi.softAPConfig(apIP, apIP, netMsk); ^ wifi.h:228:10: error: 'class WiFiClass' has no member named 'softAP' WiFi.softAP(ssid.c_str(), password.c_str(), wifi_channel, hidden); ^ sketch\wifi.h: In function 'void resumeAP()': wifi.h:413:14: error: 'class WiFiClass' has no member named 'softAPConfig' WiFi.softAPConfig(apIP, apIP, netMsk); ^ wifi.h:414:14: error: 'class WiFiClass' has no member named 'softAP' WiFi.softAP(wifi_config_ssid.c_str(), wifi_config_password.c_str(), wifi_channel, wifi_config_hidden); ^ D:\arduino\esp8266_deauther-master\esp8266_deauther\esp8266_deauther.ino: In function 'void setup()': esp8266_deauther:95:10: error: 'class WiFiClass' has no member named 'mode' WiFi.mode(WIFI_OFF); ^ esp8266_deauther:95:15: error: 'WIFI_OFF' was not declared in this scope WiFi.mode(WIFI_OFF); ^ 'class WiFiClass' has no member named 'persistent' Этот отчёт будет иметь больше информации с включенной опцией Файл -> Настройки -> "Показать подробный вывод во время компиляции"
Для первого проекта это слишком сложно. Начните с чего-нибудь попроще.
Помочь Вам невозможно, можно только сделать за Вас.
В первую очередь смотреть в уголовный кодекс, вот сюда:
http://www.consultant.ru/document/cons_doc_LAW_10699/a4d58c1af8677d94b4fc8987c71b131f10476a76/
и сюда
http://www.consultant.ru/document/cons_doc_LAW_10699/b5a4306016ca24a588367791e004fe4b14b0b6c9/
+100500
