получение данных от ардуино по запросу
Ср, 04/04/2012 - 15:52
помогите пожалуйста подправить код, не соображу как это провернуть, есть код:
#include <OneWire.h> // OneWire DS18S20, DS18B20, DS1822 Temperature Example // // http://www.pjrc.com/teensy/td_libs_OneWire.html // // The DallasTemperature library can do all this work for you! // http://milesburton.com/Dallas_Temperatu ... ol_Library OneWire ds(10); // on pin 10 void setup(void) { Serial.begin(9600); } void loop(void) { byte i; byte present = 0; byte type_s; byte data[12]; byte addr[8]; float celsius, fahrenheit; if ( !ds.search(addr)) { Serial.println("No more addresses."); Serial.println(); ds.reset_search(); delay(250); return; } Serial.print("ROM ="); for( i = 0; i < 8; i++) { Serial.write(' '); Serial.print(addr[i], HEX); } if (OneWire::crc8(addr, 7) != addr[7]) { Serial.println("CRC is not valid!"); return; } Serial.println(); // the first ROM byte indicates which chip switch (addr[0]) { case 0x10: Serial.println(" Chip = DS18S20"); // or old DS1820 type_s = 1; break; case 0x28: Serial.println(" Chip = DS18B20"); type_s = 0; break; case 0x22: Serial.println(" Chip = DS1822"); type_s = 0; break; default: Serial.println("Device is not a DS18x20 family device."); return; } ds.reset(); ds.select(addr); ds.write(0x44,1); // start conversion, with parasite power on at the end delay(1000); // maybe 750ms is enough, maybe not // we might do a ds.depower() here, but the reset will take care of it. present = ds.reset(); ds.select(addr); ds.write(0xBE); // Read Scratchpad Serial.print(" Data = "); Serial.print(present,HEX); Serial.print(" "); for ( i = 0; i < 9; i++) { // we need 9 bytes data[i] = ds.read(); Serial.print(data[i], HEX); Serial.print(" "); } Serial.print(" CRC="); Serial.print(OneWire::crc8(data, 8), HEX); Serial.println(); // convert the data to actual temperature unsigned int raw = (data[1] << 8) | data[0]; if (type_s) { raw = raw << 3; // 9 bit resolution default if (data[7] == 0x10) { // count remain gives full 12 bit resolution raw = (raw & 0xFFF0) + 12 - data[6]; } } else { byte cfg = (data[4] & 0x60); if (cfg == 0x00) raw = raw << 3; // 9 bit resolution, 93.75 ms else if (cfg == 0x20) raw = raw << 2; // 10 bit res, 187.5 ms else if (cfg == 0x40) raw = raw << 1; // 11 bit res, 375 ms // default is 12 bit resolution, 750 ms conversion time } celsius = (float)raw / 16.0; fahrenheit = celsius * 1.8 + 32.0; Serial.print(" Temperature = "); Serial.print(celsius); Serial.print(" Celsius, "); Serial.print(fahrenheit); Serial.println(" Fahrenheit"); }
выдает следующее:
ROM = 28 44 EE DB 2 0 0 15
Chip = DS18B20
Data = 1 37 0 4B 46 7F FF 9 10 1B CRC=1B
Temperature = 3.44 Celsius, 38.19 Fahrenheit
No more addresses.
нужно привести результат к следующему виду: [адрес датчика]=[значение] например: (2844EEDB20016=26.20) данное преобразование неоходимо для добавления данных в базу данных MySQL + добавить запрос, например ПК шлет ардуине строку get_temp в ответ ардуина передает ему состояние датчика в ввиде строки [адрес датчика]=[значение] например: (2844EEDB20016=26.20) , заранее всем большое б[адрес датчика]=[значение] например: (2844EEDB20016=26.20) ольшое спасибо
я так понял, заинтересованных ненашлось?
лови, если еще актуально
Спасибо, тоже как раз задался задачей подключения нескольких 18б20, пригодилось решение)
Возник вопрос в выводе значений с двух датчиков, только в формате "какое то имя датчика:температура"
Я так понимаю контроллер просто последовательно опрашивает все найденые датчики?
Т.е. этот цикл
просто последовательно выдает адресса датчиков
Придумал костыль вроде
но выдает совсем не то :)
if (addr[1]=0x4C){
Вы тут проверили "отличаются ли от нуля цифры 0x4C и 0x4D?" (естественно они не равны нулю) и записали 0x4D в addr[1] (потерев то значение что было там раньше).
А еще, судя по тому как у вас приблудились номера строк в коде, почитайте более внимательно прикрепленную ветку http://arduino.ru/forum/obshchii/vstavka-programmnogo-koda-v-temukommentarii там, в сообщении #2 показано как правильно забирать себе код, без мусора в виде нумерации строк.
