Помогите пожалуйста разобраться со скетчем
Ср, 12/06/2019 - 18:12
Прошу помощи у разбирающихся. В общем есть джойстик PS2, ардуино и мотор шилд. Нашел вот тут:https://github.com/kaisalem/Wirless-PS2X-Motors/blob/master/RC_Tank_Code.ino скетч.
#include <PS2X_lib.h> //for v1.6 #include <Servo.h> #include <Wire.h> #include <Adafruit_MotorShield.h> #include "utility/Adafruit_MS_PWMServoDriver.h" Adafruit_MotorShield AFMS = Adafruit_MotorShield(); Adafruit_StepperMotor *myStepper = AFMS.getStepper(200, 2); Adafruit_DCMotor *myMotor = AFMS.getMotor(1); Adafruit_DCMotor *myMotor2 = AFMS.getMotor(2); /****************************************************************** * set pins connected to PS2 controller: * - 1e column: original * - 2e colmun: Stef? * replace pin numbers by the ones you use ******************************************************************/ #define PS2_DAT 13 //14 #define PS2_CMD 11 //15 #define PS2_SEL 10 //16 #define PS2_CLK 12 //17 /****************************************************************** * select modes of PS2 controller: * - pressures = analog reading of push-butttons * - rumble = motor rumbling * uncomment 1 of the lines for each mode selection ******************************************************************/ //#define pressures true #define pressures false //#define rumble true #define rumble false PS2X ps2x; // create PS2 Controller Class //right now, the library does NOT support hot pluggable controllers, meaning //you must always either restart your Arduino after you connect the controller, //or call config_gamepad(pins) again after connecting the controller. int error = 0; byte type = 0; byte vibrate = 0; void setup(){ Serial.println("MMMMotor party!"); AFMS.begin(); myMotor->setSpeed(200); myMotor->run(RELEASE); myMotor2->setSpeed(200); myMotor2->run(RELEASE); myStepper->setSpeed(10); ps2x.config_gamepad(10,11,12,13, true, true); analogRead(A0); Serial.begin(57600); delay(300); //added delay to give wireless ps2 module some time to startup, before configuring it //CHANGES for v1.6 HERE!!! **************PAY ATTENTION************* //setup pins and settings: GamePad(clock, command, attention, data, Pressures?, Rumble?) check for error error = ps2x.config_gamepad(PS2_CLK, PS2_CMD, PS2_SEL, PS2_DAT, pressures, rumble); if(error == 0){ Serial.print("Found Controller, configured successful "); Serial.print("pressures = "); if (pressures) Serial.println("true "); else Serial.println("false"); Serial.print("rumble = "); if (rumble) Serial.println("true)"); else Serial.println("false"); Serial.println("Try out all the buttons, X will vibrate the controller, faster as you press harder;"); Serial.println("holding L1 or R1 will print out the analog stick values."); Serial.println("Note: Go to www.billporter.info for updates and to report bugs."); } else if(error == 1) Serial.println("No controller found, check wiring, see readme.txt to enable debug. visit www.billporter.info for troubleshooting tips"); else if(error == 2) Serial.println("Controller found but not accepting commands. see readme.txt to enable debug. Visit www.billporter.info for troubleshooting tips"); else if(error == 3) Serial.println("Controller refusing to enter Pressures mode, may not support it. "); // Serial.print(ps2x.Analog(1), HEX); type = ps2x.readType(); switch(type) { case 0: Serial.print("Unknown Controller type found "); break; case 1: Serial.print("DualShock Controller found "); break; case 2: Serial.print("GuitarHero Controller found "); break; case 3: Serial.print("Wireless Sony DualShock Controller found "); break; } } void loop() { /* You must Read Gamepad to get new values and set vibration values ps2x.read_gamepad(small motor on/off, larger motor strenght from 0-255) if you don't enable the rumble, use ps2x.read_gamepad(); with no values You should call this at least once a second */ if(error == 1) //skip loop if no controller found return; if(type == 2){ //Guitar Hero Controller ps2x.read_gamepad(); //read controller if(ps2x.ButtonPressed(GREEN_FRET)) Serial.println("Green Fret Pressed"); if(ps2x.ButtonPressed(RED_FRET)) Serial.println("Red Fret Pressed"); if(ps2x.ButtonPressed(YELLOW_FRET)) Serial.println("Yellow Fret Pressed"); if(ps2x.ButtonPressed(BLUE_FRET)) Serial.println("Blue Fret Pressed"); if(ps2x.ButtonPressed(ORANGE_FRET)) Serial.println("Orange Fret Pressed"); if(ps2x.ButtonPressed(STAR_POWER)) Serial.println("Star Power Command"); if(ps2x.Button(UP_STRUM)) //will be TRUE as long as button is pressed Serial.println("Up Strum"); if(ps2x.Button(DOWN_STRUM)) Serial.println("DOWN Strum"); if(ps2x.Button(PSB_START)) //will be TRUE as long as button is pressed Serial.println("Start is being held"); if(ps2x.Button(PSB_SELECT)) Serial.println("Select is being held"); if(ps2x.Button(ORANGE_FRET)) { // print stick value IF TRUE Serial.print("Wammy Bar Position:"); Serial.println(ps2x.Analog(WHAMMY_BAR), DEC); } } else { //DualShock Controller ps2x.read_gamepad(false, vibrate); //read controller and set large motor to spin at 'vibrate' speed if(ps2x.Button(PSB_START)) //will be TRUE as long as button is pressed Serial.println("Start is being held"); if(ps2x.Button(PSB_SELECT)) Serial.println("Select is being held"); if(ps2x.Button(PSB_PAD_UP)) { //will be TRUE as long as button is pressed Serial.print("Up held this hard: "); Serial.println(ps2x.Analog(PSAB_PAD_UP), DEC); myMotor->run(FORWARD); myMotor->setSpeed(235); myMotor2->run(FORWARD); myMotor2->setSpeed(240); } if(ps2x.Button(PSB_PAD_RIGHT)){ Serial.print("Right held this hard: "); Serial.println(ps2x.Analog(PSAB_PAD_RIGHT), DEC); myMotor->run(FORWARD); myMotor->setSpeed(235); } if(ps2x.Button(PSB_PAD_LEFT)){ Serial.print("LEFT held this hard: "); Serial.println(ps2x.Analog(PSAB_PAD_LEFT), DEC); myMotor2->run(FORWARD); myMotor2->setSpeed(220); } if(ps2x.Button(PSB_PAD_DOWN)){ Serial.print("DOWN held this hard: "); Serial.println(ps2x.Analog(PSAB_PAD_DOWN), DEC); myMotor->run(BACKWARD); myMotor->setSpeed(0); myMotor2->run(BACKWARD); myMotor2->setSpeed(0); } vibrate = ps2x.Analog(PSAB_CROSS); //this will set the large motor vibrate speed based on how hard you press the blue (X) button if (ps2x.NewButtonState()) { //will be TRUE if any button changes state (on to off, or off to on) if(ps2x.Button(PSB_L3)) Serial.println("L3 pressed"); if(ps2x.Button(PSB_R3)) Serial.println("R3 pressed"); if(ps2x.Button(PSB_L2)) Serial.println("L2 pressed"); if(ps2x.Button(PSB_R2)) Serial.println("R2 pressed"); if(ps2x.Button(PSB_TRIANGLE)) Serial.println("Triangle pressed"); } if(ps2x.ButtonPressed(PSB_CIRCLE)) //will be TRUE if button was JUST pressed Serial.println("Circle just pressed"); if(ps2x.NewButtonState(PSB_CROSS)) //will be TRUE if button was JUST pressed OR released Serial.println("X just changed"); if(ps2x.ButtonReleased(PSB_SQUARE)) //will be TRUE if button was JUST released Serial.println("Square just released"); if(ps2x.Button(PSB_L1) || ps2x.Button(PSB_R1)) { //print stick values if either is TRUE Serial.print("Stick Values:"); Serial.print(ps2x.Analog(PSS_LY), DEC); //Left stick, Y axis. Other options: LX, RY, RX Serial.print(","); Serial.print(ps2x.Analog(PSS_LX), DEC); Serial.print(","); Serial.print(ps2x.Analog(PSS_RY), DEC); Serial.print(","); Serial.println(ps2x.Analog(PSS_RX), DEC); } } delay(50); }
Но при загрузке ругается на эти строки:
Библиотеку устанавливал, но она подписана вот так:
#include <AFMotor.h>
Это ж она и есть, правильно я понимаю? Изменения в коде вносил под название этой библиотеки, результата нет.
Вообще-то, текст ругани надо приводить.
Но, скорее всего, а Вас просто нет библиотеки Adafruit_MotorShield, которую требует Ваш скетч. То, что Вы устанавливали какую-то другую, его нисколько не волнует, мало ли какие там ещё библиотеки у Вас есть. Ему нужна та, которая ему нужна.
