Проблема отправки get запроса
Пнд, 18/02/2019 - 08:23
Приветствую.
Есть проблема отправки get запроса.
Вот скетч.
#include<SoftwareSerial.h> // rdm6300 #include <RDM6300.h> #include <ESP8266WiFi.h> #include <WiFiClient.h> #include <ESP8266WebServer.h> #include <ESP8266mDNS.h> const char* ssid = "OneProjectWifi";// const char* password = "Oneprojectwifi"; //WiFiClient client; char server[] = "192.168.10.155"; //eg: 192.168.0.222 #define No_Of_Card 3 unsigned long reconnect = 0; char var[8]; String inputString = ""; boolean stringComplete = false; String buff = ""; String url = ""; WiFiClient client; //WiFiServer server(80); SoftwareSerial RFID (4, 0); uint8_t Payload[6]; RDM6300 RDM6300(Payload); byte id[No_Of_Card][5]={ {44,153,22,219,22}, //RFID NO-1 {112,224,72,84, 24}, //RFID NO-2 {151,94,80,84,43} //RFID NO-3 }; byte id_temp[3][3]; byte i; int j=0; int Led = 2; void setup () { Serial.begin(9600); delay(10); RFID.begin(9600); pinMode(Led, OUTPUT); inputString.reserve(200); url.reserve(300); // Connect to WiFi network Serial.println(); Serial.println(); Serial.print("Connecting to "); Serial.println(ssid); WiFi.begin(ssid, password); while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); } Serial.println(""); Serial.println("WiFi connected"); // Start the server // server.begin(); Serial.println("Server started"); Serial.print(WiFi.localIP()); delay(1000); Serial.println("connecting..."); } void loop () { //if (RFID.available()) { while (RFID.available() > 0) { digitalWrite(Led, HIGH); uint8_t c = RFID.read(); if (RDM6300.decode(c)) { Serial.print("NEW CARD:"); boolean perm = 1; for (int i=0; i < 6; i++){ Serial.print(Payload[i], HEX); Serial.print(" "); //id_temp[0][i] = Payload[i]; } Serial.println(); String req = String(Payload[0], HEX) + String(Payload[1], HEX) + String(Payload[2], HEX) + String(Payload[3], HEX) + String(Payload[4], HEX) + String(Payload[5], HEX); Sending_To_DB(req); /* Serial.print("CHECK CARD:"); int j = 0; for (j = 0; j < No_Of_Card; j++) { for (int i = 0; i < 5; i++) { if (id_temp[0][i] == id[j][i]) { perm = 1; } else { perm = 0; } if (!perm) break; } } Serial.println();*/ } } digitalWrite(Led, LOW); } void Sending_To_DB (String ss) { //CONNECTING WITH MYSQL if (client.connect(server, 80)) { Serial.println("connected"); // Make a HTTP request: Serial.println("GET /rfid_read.php?allow=1&id="); //YOUR URL /rfid/rfid_read.php?allow client.print("GET /rfid_read.php?allow=1&id="); //YOUR URL /rfid/rfid_read.php?allow /var/www/html/rfid/rfid_read.php client.print(ss); client.print(" "); //SPACE BEFORE HTTP/1.1 client.print("HTTP/1.1"); client.print(" "); client.print("Host: "); client.println(server); //client.println("Host: 192.168.10.155");//eg: 192.168.0.222 client.println("Connection: close"); client.println(); } else { Serial.println("connection failed"); } client.stop(); } void rfid_read () { if (RFID.available()) { while (RFID.available() > 0) { digitalWrite(Led, HIGH); uint8_t c = RFID.read(); Serial.print(c,HEX); if (RDM6300.decode(c)) { for (int i=0; i < 5; i++){ Serial.print(Payload[i], HEX); Serial.print(" "); id_temp[0][i] = Payload[i]; } Serial.println(); } } digitalWrite(Led, LOW); delay(100); } else { return; } }
Запрос такой GET /rfid_read.php?allow=1&id=550b960911d HTTP/1.1
Когда делаю посылаю запрос через Браузер то получаю правильный ответ. т.е. в базу заносится данные
"GET /rfid_read.php?allow=1&id=550b960911d HTTP/1.1" 200 1 "-"
А через Arduino получаю вот так "GET /rfid_read.php?allow=1&id=550b960911d HTTP/1.1" 400 950 "
В чем ошибка? помогите пожалуйста
Неправильно строите http запрос, у вас на одной строке (на первой) запроса указан метод урло протокол и первый заголовок «Host:».
После протокола вместо пробела должен быть «возврат каретки» + «перевод строки»
П.С.
Много раз встречаю удивительный код.
Для передачи каких либо данных с iot устройств на http сервер, почемуто используется не POST запрос а GET и данные передаются в урле.
Загадка вообщем.
Гипотеза: отлаживать проще. А потом уже нафиг надо переделывать то, что работает.
А почему POST-то? Тогда уж, идеологически правильнее использовать PUT.
PUT - замени данные файла или ресурса по заданному uri
В общем имеет место словоблудие, то и другое сообщает серверу об изменении каких либо данных, в отличии от GET запроса, в котором мы запрашиваем что либо в зависимости от изменившихся данных на стороне клиента.
ничего не мешает в ответ на GET запрос тупо ничего не возвращать клиенту.
Типа наш сервер, что хотим то и делаем.
А когда клинтом для отладки будет броузер, будем удивляться что get запросы не долетают до сервера, а возвращаются кэшированные ответы.
Мы же сознательно не используем post запрос для которого:
Responses to this method are not cacheable, unless the response includes appropriate Cache-Control or Expires header fields. However, the 303 (See Other) response can be used to direct the user agent to retrieve cacheable resource.
П.С.
Загадка вообщем.
Подскажите как нужно, пожалуйста
Вам же привели пример запроса, только юзер агент не обязательно мозила, кип-элайф в коннекшен тоже лишний, зачем обманывать сервер (можете не добавлять этот заголовок или укажите честно Connection: close).
Извените, не увидел. Спасибо
