Проблемы со скетчем
Haloween
Есть скетч:
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
//#include <math.h>
#include <Adafruit_GFX.h>
#include <Adafruit_PCD8544.h>
Adafruit_PCD8544 display = Adafruit_PCD8544(8,7,6,5,4);
#define DS1307_I2C_ADDRESS 0x68
byte tuch=0;
byte t[13]={};
byte tolshina[13]={6,9,12,14,15,17,18,19,20,21,24,27,30};
byte decToBcd(byte val)
  return ( (val/10*16) + (val%10) );
byte bcdToDec(byte val)
  return ( (val/16*10) + (val%16) );
void setDateDs1307(byte second,        // 0-59
                   byte minute,        // 0-59
                   byte hour,          // 1-23
                   byte dayOfWeek,     // 1-7
                   byte dayOfMonth,    // 1-28/29/30/31
                   byte month,         // 1-12
                   byte year)          // 0-99
   Wire.beginTransmission(DS1307_I2C_ADDRESS);
   Wire.write(0);
   Wire.write(decToBcd(second));
   Wire.write(decToBcd(minute));
   Wire.write(decToBcd(hour));
   Wire.write(decToBcd(dayOfWeek));
   Wire.write(decToBcd(dayOfMonth));
   Wire.write(decToBcd(month));
   Wire.write(decToBcd(year));
   Wire.endTransmission();
void getDateDs1307(byte *second,
          byte *minute,
          byte *hour,
          byte *dayOfWeek,
          byte *dayOfMonth,
          byte *month,
          byte *year)
  Wire.write(0);
  Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
  *second     = bcdToDec(Wire.read() & 0x7f);
  *minute     = bcdToDec(Wire.read());
  *hour       = bcdToDec(Wire.read() & 0x3f);
  *dayOfWeek  = bcdToDec(Wire.read());
  *dayOfMonth = bcdToDec(Wire.read());
  *month      = bcdToDec(Wire.read());
  *year       = bcdToDec(Wire.read());
  byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
  Wire.begin();
  second = 00;
  minute = 52;
  hour = 23;
  dayOfWeek = 7;
  dayOfMonth = 5;
  month = 11;
  year = 17;
 //setDateDs1307(second, minute, hour, dayOfWeek, dayOfMonth, month, year);
 byte i;
  if (!SD.begin(10)) {
    Serial.println(F("initialization failed!"));
    return;
  Serial.println(F("initialization done."));
 for (i=0; i<=11; i++)
  {t[i]=0;}
   display.begin();
//  display.cp437(true);
 display.setContrast(55);display.clearDisplay();display.fillScreen(WHITE);
                display.display();
                display.setTextSize(1);display.setCursor(0,0);display.print("W O R K");
 display.setTextSize(2);
     display.setCursor(0, 8);display.print(tolshina[0]);display.setCursor(27,8);display.print("x");
    display.display();
 //  Serial.begin(9600);
 /*  if (micros() - LastTime > 280000)
  { // a = analogRead (A0);//BS=digitalRead(*/
      if(digitalRead(15)==LOW)//если кнопка нажата ...(перемещение по пунктам)
  tuch++;
  if (tuch>=13){tuch=0;}
       display.setTextColor(WHITE,BLACK);
  display.setCursor(0,8); display.print("      ");display.display();
  display.setTextColor(BLACK,WHITE);
 display.setCursor(0,8);display.print(tolshina[tuch]);display.setCursor(27,8);display.print("x");
  display.setCursor(42,8);display.print(t[tuch]);display.display();
    if(digitalRead(16)==LOW)//если кнопка нажата ... (счет)
     display.setCursor(42,8);display.print("  ");display.display();
      t[tuch]++;
  display.setCursor(42,8); display.print("  ");display.display();
  display.display();display.setCursor(42,8);display.print(t[tuch]);display.display();
//     небольшая защита от "дребезга" контактов кнопки реализованна при помощи функции millis()
        if(digitalRead(2)==LOW)//если кнопка нажата ... (итог)
        {display.clearDisplay();
      //  if ((micros()-TimOfUpd)>4000000)
   if(digitalRead(14)==HIGH)//если кнопка нажата ...(конец смены)
 savdat();
     delay(250);
  /*  LastTime = micros();
 void savdat()
  File fdat;
 fdat = SD.open("DAT.CSV", FILE_WRITE);
  if (fdat) {
    digitalWrite(3,HIGH);
  getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year);
if (dayOfMonth < 10) {fdat.print("0");fdat.print(dayOfMonth, DEC);fdat.print("/");}
else {fdat.print(dayOfMonth, DEC);fdat.print("/");}
if (month < 10) {fdat.print("0");fdat.print(month, DEC);fdat.print("/");}
else {fdat.print(month, DEC);fdat.print("/");}
if (year < 10) {fdat.print("0"); fdat.print(year, DEC);}
else {fdat.print(year, DEC);}
fdat.print ("   ");
if (hour < 10) {fdat.print("0");fdat.print(hour);fdat.print(":");}
else {fdat.print(hour);fdat.print(":");}
if (minute < 10) {fdat.print("0");fdat.print(minute);fdat.print(":");}
else {fdat.print(minute);fdat.print(":");}
fdat.println ("");
    fdat.println("---------------------------------------------");
    for(byte u=0;u<13;u++) // бежим по элементам
      {if (t[u]>0){fdat.print(tolshina[u]);
     fdat.print("x");fdat.print(t[u]);fdat.print(" ; "); }
    fdat.println(" ");fdat.println("--------------------------------------------");
    // close the file:
    fdat.close();
    Serial.println("done.");
            delay(1000);digitalWrite(3,LOW);
 } else {
    // if the file didn't open, print an error:
    Serial.println(F("error opening dat.csv"));
  // re-open the file for reading:
  fdat = SD.open("dat.csv");
  if (fdat) {
    Serial.println(F("dat.csv:"));
    // read from the file until there's nothing else in it:
    while (fdat.available()) {
      Serial.write(fdat.read());
    // close the file:
    fdat.close();
  } else {
  }return;}
Необходимо его оптимизировать, чтобы переменные меньше места занимали в памяти (да и сам скетч занимает много места) и заставить работать по-человечьи, а то при попытке записи на карту вылетает ошибка открытия файла (хотя файл был перед этим создан этим же скетчем).
Помогите, пожалуйста, а то все мозги уже сломал...
Haloween пишет:
Сколько занимают сейчас и сколько надо?
Haloween пишет:
Вы забыли написать что именно этот скетч должен делать. Откуда мне знать, может он создавался как раз для того, чтобы "выдавать ошибку открытия файла"?
Haloween
Это устройство считает нажатия на кнопки и пишет результат в файл. Пересчет происходит при нажатии на кнопку"счет", а запись - по нажатию на кнопку "конец смены".
при  компиляции выходит вот что:
Скетч использует 18690 байт (60%) памяти устройства. Всего доступно 30720 байт.
Глобальные переменные используют 1764 байт (86%) динамической памяти, оставляя 284 байт для локальных переменных. Максимум: 2048 байт.
Недостаточно памяти, программа может работать нестабильно.
Устройство имеет автономное питание (аккумулятор 18650), по-этому выбрана плата "PRO MINI".
Библиотеку дисплея надо менять - в этой предусмотрен буфер, который сжирает всю память, ищите без буфера или пишите сами.
Haloween
Как их распознать-то? Я в С не знаток, а в названиях ничего не указано...
Может подскажете, где взять?
DetSimen
DetSimen аватар
SD тоже немало жреть
DIYMan
DIYMan аватар
Сходу  по оптимизации - все строки во флеш загнать, либо макросом F, либо, что будет лучше - PROGMEM.
Haloween
Какие именно строки? Те, где происходит вывод в серпорт и на экран?
в Serial - все, что длиннее 3-5-ти символов. Выиграяете, навскидку, порядка 100 байт оперативки.
DIYMan
DIYMan аватар
Haloween пишет:
У вас  строки "DAT.CSV", "W O R K", "done.", "--------------------------------------------" не обрамлены F(), остальное, вроде, норм.
Haloween
Какие именно строки (номера)? И как быть с ошибкой открытия файла?
DIYMan
DIYMan аватар
195, 187, 184, 176, 157, 97. Ещё можно 116 и 118.
Haloween
Спасибо, сделал. теперь результат вот какой:
Скетч использует 19540 байт (63%) памяти устройства. Всего доступно 30720 байт.
Глобальные переменные используют 1682 байт (82%) динамической памяти, оставляя 366 байт для локальных переменных. Максимум: 2048 байт.
И осталась проблема ошибки открытия файла.
что-то мало выиграли, должны были байтов 100-150. Покажите, что получилось.
Ну и повторю - чтобы изменить ситуацию кардинально, скетч надо полностью переписывать. Библиотека Adafruit_PCD8544.h по умолчанию создает буфер размером примерно 500-600 байтов, пока вы от него не избавитесь - работать не будет. Ошибка открытия файла, скорее всего, тоже связана с недостатком памяти.
Haloween
Получилос вот что:
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
//#include <math.h>
byte tuch=0;
byte t[13]={};
                   byte hour,          // 1-23
                   byte month,         // 1-12
                   byte year)          // 0-99
   Wire.write(0);
          byte *minute,
          byte *hour,
          byte *dayOfWeek,
          byte *dayOfMonth,
          byte *month,
          byte *year)
  Wire.write(0);
  Wire.begin();
  second = 00;
  minute = 52;
  hour = 23;
  dayOfWeek = 7;
  dayOfMonth = 5;
  month = 11;
  year = 17;
 byte i;
    return;
  {t[i]=0;}
   display.begin();
                display.display();
                display.setTextSize(1);display.setCursor(0,0);display.print(F("W O R K"));
    display.display();
  tuch++;
  display.setCursor(0,8); display.print(F("      "));display.display();
      t[tuch]++;
 savdat();
     delay(250);
 void savdat()
  File fdat;
 fdat = SD.open(F("DAT.CSV"), FILE_WRITE);
  if (fdat) {
fdat.print ("   ");
fdat.println ("");
    fdat.println(F("---------------------------------------------"));
     fdat.print("x");fdat.print(t[u]);fdat.print(F(" ; ")); }
    fdat.println(" ");fdat.println(F("--------------------------------------------"));
    // close the file:
    fdat.close();
    Serial.println(F("done."));
 } else {
  fdat = SD.open(F("dat.csv"));
  if (fdat) {
    // close the file:
    fdat.close();
  } else {
  }return;}
После компиляции сами видели, что вышло...
Как я уже говорпил, я не знаток С и переписать библиотеку вряд лои смогу.
Может подскажете, как избавиться от буфера?
Я бы еще поэкспериментировал со vsnprintf_P(). Возможно это и не даст сильного выигрыша по RAM, но кашу в 163-173 ликвидирует.
Serial еще можно не инициализировать и 16  байт, как минимум, выиграть ))
Haloween пишет:
Библиотека, не использующая буфер - https://oscarliang.com/arduino-oled-display-library/
А вот здесь коллега описал как её надо подправить и запустить - http://arduino.ru/forum/apparatnye-voprosy/preodolenie-problem-s-ekranom-096-128x64-oled-lcd-i2c-ssd1306
DetSimen
DetSimen аватар
sadman41 пишет:
У Serial 128 байт буфер по умолчанию, а у SD, кабы не 512 аш.  Могу ошибаться, надо читать
Haloween
У меня и схема и корпус под экран 5110
DetSimen
DetSimen аватар
опщем, на Мегу переходи.
Haloween пишет:
Ну, так и надо было говорить. Зайдите в гугл с запросом "библиотека для 5110 без буфера" - там столько вывалится. Или просто почитайте его (5110) даташит, там собственно делать нечего и безо всякой библиотеки.
DetSimen пишет:
Всё более запутанно в этом hardware serial:
#if !defined(SERIAL_TX_BUFFER_SIZE)
#if ((RAMEND - RAMSTART) < 1023)
#define SERIAL_TX_BUFFER_SIZE 16
#else
#define SERIAL_TX_BUFFER_SIZE 64
#endif
#endif
#if !defined(SERIAL_RX_BUFFER_SIZE)
#define SERIAL_RX_BUFFER_SIZE 16
#else
#define SERIAL_RX_BUFFER_SIZE 64
#endif
#endif
DetSimen
DetSimen аватар
и чо там?  я вижу, если памяти больше 1 килобайта, 64 байта приемный буфер и 64 байта передающий. в сумме 128.
Всё правильно посчитал. Но я так понимаю, что  можно задефайнить буфер сайз и тогда Serial будет не 128 байт жрать, а поменее.  Ну, и если принимать ничего не надо, то можно RX вообще крепко порезать. На arduino.cc это обсуждалось.
Грязный хак, конечно, но если экономить на спичках надо...
DetSimen
DetSimen аватар
я в таких случаях просто Serial не инициализирую и не использую.
экранчик тем более есть, для вывода
NeProf
добрый день форумчане. Решил не создавать новую тему , а задать вопрос в этой. В фрагменте кода (взят из скетча работы с модулем ov0706 (объектив) в связке с SD  и Ethernet) выдается ошибка. Как я не экспериментировал с библиотеками (вроде скачаны последние SD-master и SdFat-master), но ошибку устранить не могу. Натолкните, в чем здесь дело, пожалуйста
#include <Adafruit_VC0706.h>
#include <SPI.h>
#include <SdFat.h>
#include <SdFatUtil.h>
#include <Ethernet.h>
#include <SoftwareSerial.h>
SdFat SD;
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
выдается ошибка:
NeProf
 No such file or directory
DetSimen
DetSimen аватар
а гугло-транлэйт чо говорит?
NeProf
перелопатил весь гугл, но пока ответа не нашел. Видел подобный код и .... вроде работает, т.е. там другие проблемы. Возможно конфликт библиотек SD-SdFat- и еще чего то, не пойму ))
Но Вы же сами привели текст сообщения в посте №26! А на вопрос, заданный Вам в посте №27 Вы ответили (сами себе)?
NeProf пишет:
Нафига лопатили? Переводчик искали, чтобы фразу "No such file or directory" перевести?
NeProf пишет:
Да, чего его искать - вот он!
Neprofi
Спасибо за исчерпывающий комментарий, но перевод я и без гугла знаю.
Ну, тогда я вообще не понимаю Ваших проблем. Вам прямо сказали, что нету такого файла, а Вы уже неделю не знаете что Вам делать? А какие у Вас идеи? Или и идей никаких?
Клапауций 112
Клапауций 112 аватар
чей туфля?
yarus
ЕвгенийП,  Евгений, а как использовать сию либу?
описание применения и команд там есть?
Ведь обычно с либами ОЛЕД обязательно подключаются либы от адафрута, а, как раз они-то и жрут оперативу...
Какую "сию либу"?
andycat
andycat аватар
yarus пишет:
почти со всеми библиотеками идут папки Example, и при чем хдесь жор оперативки? берите другую библиотекуу поменьше если эти не устраивают
