Регулировка частоты
Нет ответов
antonx
Здравствуйте
Программа генератора , частоту  можна менять в ручную меняя число SAMPLES
#include "LiquidCrystal.h"
LiquidCrystal lcd(PA0, PA1, PA2, PA3, PA4, PA5);
#define SAMPLES 88
#include <libmaple/dma.h>
dma_tube_config dma_cfg;
int flag1 = 0;
int out1 = PB7;
int val1[SAMPLES];
int amp = 50;
int cnt = 0;
int time_track = 0;
float stp = 6.2831 / SAMPLES;
int ret = 17;
timer_dev *dev1 = PIN_MAP[out1].timer_device;
uint8 cc_channel1 = PIN_MAP[out1].timer_channel;
void fun()
  flag1++;
void timer_conf()
  timer_dma_set_base_addr(dev1, TIMER_DMA_BASE_CCR2);
  timer_dma_set_burst_len(dev1, 1);
  timer_dma_enable_req(dev1, cc_channel1);
  timer_set_reload(dev1, 102);
  timer_set_prescaler(dev1, 0);
void dma_conf()
  dma_init(DMA1);
  /* T4C2 DMA C4 */
  dma_cfg.tube_dst = &(dev1->regs.gen->DMAR);
  dma_cfg.tube_dst_size = DMA_SIZE_32BITS;
  dma_cfg.tube_src = val1;
  dma_cfg.tube_src_size = DMA_SIZE_32BITS;
  dma_cfg.tube_nr_xfers = SAMPLES;
  dma_cfg.tube_flags = DMA_CFG_SRC_INC | DMA_CFG_CIRC | DMA_CFG_CMPLT_IE;
  dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH2;
  dma_cfg.target_data = 0;
  ret = dma_tube_cfg(DMA1, DMA_CH4, &dma_cfg);
void dma_start()
  dma_attach_interrupt(DMA1, DMA_CH4, fun);
  dma_enable(DMA1, DMA_CH4);
  timer_resume(dev1);
  dma_enable(DMA1, DMA_CH2);//
  //  timer_resume(dev2);
void init_wave()
  //int i;
  for (int i = 0; i < SAMPLES; i++)
    val1[i] = 50 + amp * sin(stp * i);
  lcd.begin(16, 2);
  int i;
  //int j;
  pinMode(out1, PWM);
  pinMode(PB13, INPUT_PULLDOWN);
  pinMode(PB12, INPUT_PULLDOWN);
  timer_conf();
  dma_conf();
  dma_start();
  init_wave();
  lcd.setCursor(0, 1);
  lcd.print("Samples = ");
 //lcd.print(Samples);
  delay(100);
пытаюсь сделать с  помощью  кнопок но на PB7 нет сигнала
#define MAX_SAMPLES 200
int Samples = 90;
int flag1 = 0;
int out1 = PB7;
int val1[MAX_SAMPLES];
int amp = 50;
int cnt = 0;
int time_track = 0;
float stp = 6.2831 / MAX_SAMPLES;
int ret = 17;
void fun()
  flag1++;
void timer_conf()
void dma_conf()
  dma_init(DMA1);
  /* T4C2 DMA C4 */
  dma_cfg.tube_nr_xfers =  MAX_SAMPLES;
void dma_start()
  timer_resume(dev1);
void init_wave()
  for (int i = 0; i < MAX_SAMPLES; i++)
  lcd.begin(16, 2);
  pinMode(out1, PWM);
  timer_conf();
  dma_conf();
  dma_start();
  init_wave();
  ReadButtons();
  dma_conf();  // Update the number of samples
  lcd.print(Samples);
 delay(100);
void ReadButtons()
  if (digitalRead(PB12) == HIGH)
    if (Samples < MAX_SAMPLES)
      Samples++;
  if (digitalRead(PB13) == HIGH)
    if (Samples > 0)
      Samples--;
