REMOTE XY помогите исправить код
Помогите исправить код чтобы при подаче питания на реле не подавалось питание
-- Насос вода --
This source code of graphical user interface
has been generated automatically by RemoteXY editor.
To compile this code using RemoteXY library 2.4.3 or later version
download by link http://remotexy.com/en/library/
To connect using RemoteXY mobile app by link http://remotexy.com/en/download/
- for ANDROID 4.5.1 or later version;
- for iOS 1.4.1 or later version;
This source code is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
// RemoteXY include library //
// определение режима соединения и подключение библиотеки RemoteXY
#define REMOTEXY_MODE__SOFTSERIAL
#include
#include
// настройки соединения
#define REMOTEXY_SERIAL_RX 2
#define REMOTEXY_SERIAL_TX 3
#define REMOTEXY_SERIAL_SPEED 9600
// конфигурация интерфейса
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] =
{ 255,2,0,0,0,118,0,10,13,0,
2,0,1,1,98,31,2,26,31,31,
208,157,208,144,208,161,208,158,208,161,
32,208,146,208,154,208,155,208,174,208,
167,208,149,208,157,0,208,146,208,171,
208,154,208,155,208,174,208,167,208,149,
208,157,0,2,0,1,33,98,29,204,
26,31,31,208,165,208,158,208,155,208,
158,208,148,208,157,208,144,208,175,32,
208,146,208,158,208,148,208,144,32,0,
208,146,208,158,208,148,208,144,32,208,
152,208,151,32,208,145,208,158,208,167,
208,154,208,152,0 };
// структура определяет все переменные и события вашего интерфейса управления
struct {
// input variables
uint8_t switch_1; // =1 если переключатель включен и =0 если отключен
uint8_t switch_2; // =1 если переключатель включен и =0 если отключен
// other variable
uint8_t connect_flag; // =1 if wire connected, else =0
} RemoteXY;
#pragma pack(pop)
// END RemoteXY include //
#define PIN_SWITCH_1 13
RemoteXY_Init ();
pinMode (PIN_SWITCH_1, OUTPUT);
// TODO you setup code
RemoteXY_Handler ();
digitalWrite(PIN_SWITCH_1, (RemoteXY.switch_1==0)?LOW:HIGH);
// TODO you loop code
// используйте структуру RemoteXY для передачи данных
// не используйте функцию delay()
Этот сайт использует Cookies, чтобы предоставить вам услуги лучшего качества Подробнее
Вставьте код по правилам или валите
я, наерна, такие темы, с невставленным, как следовает, кодом в первом сообщении, буду по тихому отправлять в dev\null, если админы не против.
Сейчас исправлю
Спасибо большое!
