Сглаживание fft
gena321
Добрый день
В предыдущем посте с Вашей помощью сделал первый шаг изучения fft, возникла проблема шумов, пытаюсь устронить их с помощью функций smooth но она пука не работает.
Вот что я сделал.
#include "arduinoFFT.h"
#include <LiquidCrystal.h>
LiquidCrystal lcd(PA0, PA1, PA2, PA3, PA4, PA5);
#define SAMPLES 128 //Must be a power of 2, # of bins = samples/by 2 = 64
#define SAMPLING_FREQUENCY 1000 //Hz, must be less than 10000 due to ADC
const int numReadings = 10;
int readings[numReadings];      // the readings from the analog input
int readIndex = 0;              // the index of the current reading
int total = 0;                  // the running total
int average = 0;                // the average
int i;
arduinoFFT FFT = arduinoFFT();
unsigned int sampling_period_us;
unsigned long microseconds;
double vReal[SAMPLES];
double vImag[SAMPLES];
  Serial.begin(115200);
  lcd.begin(16, 2);
  sampling_period_us = round(1000000 * (1.0 / SAMPLING_FREQUENCY));
  for (int thisReading = 0; thisReading < numReadings; thisReading++) {
    readings[thisReading] = 0;
    /*SAMPLING*/
    for (int i = 0; i < SAMPLES; i++)
      microseconds = micros();    //Overflows after around 70 minutes!
      // vReal[i] = analogRead(0);
      vReal[i] = analogRead(PA7);
      vImag[i] = 0;
      while (micros() < (microseconds + sampling_period_us)) {
    /*FFT*/
    FFT.Windowing(vReal, SAMPLES, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
    FFT.Compute(vReal, vImag, SAMPLES, FFT_FORWARD);
    FFT.ComplexToMagnitude(vReal, vImag, SAMPLES);
    double peak = FFT.MajorPeak(vReal, SAMPLES, SAMPLING_FREQUENCY);
    /*PRINT RESULTS*/
    // Serial.println(peak);     //Print out what frequency is the most dominant.
    //for (int i = 0; i < (SAMPLES / 2); i++)
    //   for (int i = 0; i < (36); i++)
      /*View all these three lines in serial terminal to see which frequencies has which amplitudes*/
      //Serial.print((i * 1.0 * SAMPLING_FREQUENCY) / SAMPLES, 1);
      //Serial.print(" ");
     // Serial.println(vReal[35], 1);    //View only this line in serial plotter to visualize the bins
 // subtract the last reading:
  total = total - readings[readIndex];
  // read from the sensor:
  //readings[readIndex] = analogRead(inputPin);
   readings[readIndex] = (vReal[35], 1);
  // add the reading to the total:
  total = total + readings[readIndex];
  // advance to the next position in the array:
  readIndex = readIndex + 1;
  // if we're at the end of the array...
  if (readIndex >= numReadings) {
    // ...wrap around to the beginning:
    readIndex = 0;
  // calculate the average:
  average = total / numReadings;
  // send it to the computer as ASCII digits
  Serial.println(average);
  delay(1);        // delay in between reads for stability
    //delay(1000);  //Repeat the process every second OR:
    // while(1);       //Run code once
    lcd.setCursor(0, 0);
    lcd.print("V");
    lcd.setCursor(3, 0);
    lcd.print(vReal[35], 1); //
    lcd.setCursor(0, 1);
    lcd.print(peak); // frequency
Шумов нет, прямая линия бесь шумов  на уровне 1В, но она не реагирует на подачу сигнала.
Где ошибка ?
Вам сказали, "изучите книгу, и пока не изучите - не возвращайтесь". Вы игнорируете, ну дело Ваше.
gena321 пишет:
Где ошибка ?
В Вашем подходе к делу, в Ваших мозгах. Исправите её, остальные - не проблема.
Совершенно прав был коллега, писавший Вам
andriano пишет:
Невозможно научить танцевать человека, который не то что ходить, а еще ползать не научился.
Здесь форум, а не школа. Заявки типа "хочу научиться танцевать" принимаются только от людей, которые уже умеют ходить.
gena321
Строки, 72, 73, 88.
gena321 пишет:
Строки, 72, 73, 88.
Я даже не спрашиваю Вас, что именно написано в строке 73
т.к. один хрен Вы этого не знаете.
Изучите язык хотя бы на уровне школьника. И пока не изучите, Вам здесь нечего делать, поверьте.
gena321
Онлайн
Нет уважения к другим. Такие комментарии бесполезные.
А чем Вы, простите, заслужили уважение? Тем что ни хрена не знаете и отказываетесь читать литературу? Или тем, что врёте на прямой вопрос?
Действительно - можно уважать начинающего, который старается что-то узнать. А к человеку, который отказывается узнавать, а просто нагло клянчит халяву - никакого уважения нет и быть не может.
gena321 - тут не комменты бесполезные, а ваши сообщения на форуме. У вас в коде написана откровенная чушь - а с FFT взялись работать.
gena321
Критиковать легче чем дать ответ по теме.
gena321 пишет:
каких, нафик, советов по теме можно дать человеку, который не знаеткак буква "а" выговаривается? Ваша строчка 73 всегда возврашщает единицу! - достаточно по теме или все еще недостаточно разжевано для лентяев ?
gena321
Это я и сказал раньше, а  должна средное значение бина #35
Онлайн
gena321 пишет:
Вы так думаете?
Для того, чтобы дать Вам ответ, который бы ВЫ смогли понять, нужно пересказать учебник. Но даже это, думаю, без толку, т.к. у Вас все равно не хватит терпения дочитать такой ответ до конца.
gena321 пишет:
должна? - бить пробовали?
Хотя нет - вы ж иронию не понимаете. Напишу тупо и "по теме" - чтобы строчка что-то делала, программист должен это запрограммировать.
gena321
Работает, сам разобрался.
Продолжайте свои...............
gena321 пишет:
Кому это, интерсено, она так задолжала?
Я Вам уже говорил, не хотите выглядеть идиотом и клоуном - учите язык. Хотите - у Вас получается
