Скетч показал error, помогите, где ошибка?
Втр, 18/10/2016 - 16:49
#include <SoftwareSerial.h> #include <String.h> #include <EEPROM.h> #include <Wire.h> #include <SPI.h> #include <Ethernet.h> #include <dht.h> // pins definition SoftwareSerial sim800l(7, 6); // actual RX, TX pins of SIM800l board const int TestButton = 10; // internal pull-up activated, button is wired to GND, LOW when pressed const int LEDPowerFailure = 9; const int LEDTemperatureFailure = 4; const int LEDLANFailure = 11; const int LEDDiagnostics = 13; // internal LED for diagnostics const int PowerSenseInput= A1; // from DC adapter via a voltage divider const int DHT11Pin = 12; // DHT11 onewire pin // failure definitions constants - bitwise const int StateOk = 0; const int StatePowerDownFailure = 1; const int StateLANFailure = 2; const int StateTemperatureFailure = 4; const int StateTest = 8; float TempSensorValue; // current temperature from sensor DHT11 float PowerSenseInputValue; // voltage after divider int PingFailure = 0; // flag int PingCountOk; // counter int TestButtonState; // pressed LOW int State = StateOk; // status of the net/temp/power/test // User configurable variables (via source recompile and upload to Arduino board again) // pinging byte useDhcp = true; byte useDns = true; byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // these valus must be changed IPAddress deviceIp(192, 168, 1, 100); // Only if useDhcp is false !!! IPAddress gatewayIp(192, 168, 1, 1); // Only if useDhcp is false !!! IPAddress dnsIp(192, 168, 1, 1); // Only if useDhcp is false !!! IPAddress subnet(255, 255, 255, 0); // Only if useDhcp is false !!! IPAddress serverIp(173, 230, 152, 173); // Only if useDns is false !!! char serverName[] = "server1.tu-plovdiv.bg"; // Only if useDns is true !!! // thresholds const int TemperatureAlarmValue = 36; // over 36C - alarm const int PingCountAlarmValue = 3; // over 3 lost packets - alarm const float DCPowerAlarmValue = 0.5; // under 0.5 volts after voltage diveider - alarm const float DCPowerVoltage = 9.0; // voltage of the power adaptor EthernetClient Client; // Declare client object dht DHT; // DHT object void setup() // initialise ports/values { pinMode(TestButton, INPUT_PULLUP); // LOW when pressed // LEDs - light on HIGH pinMode(LEDPowerFailure, OUTPUT); pinMode(LEDTemperatureFailure, OUTPUT); pinMode(LEDLANFailure, OUTPUT); pinMode(LEDDiagnostics, OUTPUT); // initialise Serial and SIM800l sim800l.begin(9600); // initialize SIM800l module at 9600 bps Serial.begin(9600); // debug messages to serial monitor of Arduino IDE delay(500); // wait for proper initialization of the SIM800l 500mS } void loop() { State = StateOk; // check TestButtonState = digitalRead(buttonPin); // if LOW - do diagnostic (Power failure simulation) if (TestButtonState == LOW) { // test diagnostic SMS and PowerLow LED simulation Serial.println("Diagnostics button pressed."); State = State | StateTest; } // check temperature int chk = DHT.read11(DHT11Pin); if (chk == DHTLIB_OK) { TempSensorValue = DHT.temperature; if (TempSensorValue > TemperatureAlarmValue) { State = State | StateTemperatureFailure; Serial.print("Temperature overflow "); Serial.println(TempSensorValue, 1); } } // check power down state, read twice after 500ms to avoid brownouts PowerSenseInputValue = analogRead(PowerSenseInput) * (DCPowerVoltage / 2.0) / 1024; if (PowerSenseInputValue < DCPowerAlarmValue) { delay(500); // wait for brownout 500mS PowerSenseInputValue = analogRead(PowerSenseInput) * (DCPowerVoltage / 2.0) / 1024; if (PowerSenseInputValue < DCPowerAlarmValue) { State = State | StatePowerDownFailure; Serial.println("Power down."); } } // check ping state of the server // .. if (PingFailure) { State = State | StatePowerDownFailure; Serial.println("Ping failed - server is down."); } // process state if (sim800l.available()){ // is SIM800l receive SMS or status - dump it back Serial.write(sim800l.read()); } } void SendTextMessage() { Serial.println("Sending Text Message..."); // sim800l.print("AT+CMGF=1\r"); // Set the shield to SMS mode delay(100); sim800l.print("AT+CMGS=\"+3591234567\"\r"); // put actual number here delay(200); // sim800l.print("Failure is: "); // ... by State... sim800l.print("\r"); //the content of the message delay(500); sim800l.print((char)26); //the ASCII code of the ctrl+z is 26 (required ^Z at end of SMS) delay(100); sim800l.println(); Serial.println("Text Message Sent."); delay(500); }
Ардуино Уно, SIM800L, DHT11, Ethernet shield HR911105A- для отслеживания температуры и вне установленного предела для отправки SMS.
Чего показал? Кому показал? Секреты кругом? Мож поделитесь?
Видите ли Вы на картинке серую кнопку с надписью "Copy error messages" ? Просто воспользуйтесь ей.
Arduino: 1.6.11 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\admin\Desktop\ServerGuard_Dona_with_SIM800l\ServerGuard_Dona_with_SIM800l.ino:7:17: fatal error: dht.h: No such file or directory
#include <dht.h>
Какое из этих пяти слов Вам непонятно?
ну, не нашёл он файла dht.h. Либо его нет, либо лежит не там, где его ожидают увидеть.
Скорее всего нет, т.к. тот что есть он у Вас наверняка DHT.h
Все ошибок :(
Ну, значит и такого нет. У Вас он вообще есть? либо его нет. либо лежит в неправильном месте. Поищите.
я запретил поиск.
Спасибо.
у вас нет библиотеки DHT, вот и ругается
Я прикрепила библиотеку
