Таймер обратного отсчёта. Помогите пожалуйста.
Александр2048
//ОШИБКА - Arduino: 1.8.13 Hourly Build 2020/02/19 03:33 (Windows 7), Плата:"Arduino Uno"
C:\Users\Админ\Documents\Arduino\sketch_jul30a\sketch_jul30a.ino: In function 'void setup()':
sketch_jul30a:26:11: error: 'LEDpin' was not declared in this scope
sketch_jul30a:26:18: error: 'i' was not declared in this scope
exit status 1
// LED pins
int aPin = 9;
int bPin = 2;
int cPin = 3;
int dPin = 4;
int ePin = 5;
int fPin = 6;
int gPin = 7;
int dpPin = 8;
// digits pins
int y1 = 10;
int y2 = 11;
int y3 = 12;
int y4 = 13;
// pins arrays
int ledArray[] = {aPin, bPin, cPin, dPin, ePin, fPin, gPin, dpPin};
int yArray[] = {y1, y2, y3, y4};
// timer value
int test = 20;
  pinMode(LEDPin, OUTPUT);
  // pinMode OUTPUT for all LED pins
  for (int i = 0; i < 8; i++) {
    pinMode(ledArray[i], OUTPUT);
  // pinMode OUTPUT for pins that control digits
  for (int i = 0; i < 4; i++) {
    pinMode(yArray[i], OUTPUT);
  int thousand = test/1000;
  int hundred = (test - thousand*1000)/100;
  int ten = (test - thousand*1000 - hundred*100)/10;
  int one = test - thousand*1000 - hundred*100 - ten*10;
  // OFF all digit pins at start
  for (int y = 0; y < 4; y++) {
    digitalWrite(yArray[y], HIGH);
  // check that number to display is not zero
  if (test > 0) {
    // loop for display digits
    for (int i = 0; i < 50; i++) {
      // display first digit
      if (thousand != 0) {
        digitalWrite(yArray[0], LOW);
        LEDDisplay(thousand);
        delay (5);
        digitalWrite(yArray[0], HIGH);
      } else {
        LEDDisplay(0);
        delay (5);
      // display second digit
      if (hundred != 0) {
        digitalWrite(yArray[1], LOW);
        LEDDisplay(hundred);
        delay (5);
        digitalWrite(yArray[1], HIGH);
      } else {
        LEDDisplay(0);
        delay (5);
      // display third digit
      if (ten != 0) {
        digitalWrite(yArray[2], LOW);
        LEDDisplay(ten);
        delay (5);
        digitalWrite(yArray[2], HIGH);
      } else {
        LEDDisplay(0);
        delay (5);
      // display last digit
      if (one != 0) {
        digitalWrite(yArray[3], LOW);
        LEDDisplay(one);
        delay (5);
        digitalWrite(yArray[3], HIGH);
      } else {
        LEDDisplay(0);
        delay (5);
    // close for loop
    // decriment number for count down
    test = test - 1;
  } else {
    digitalWrite(dpPin, HIGH); // use this dpPin for LED
void LEDDisplay(int x) {
  switch(x) {
    case 0:
      digitalWrite(aPin, HIGH);
      digitalWrite(bPin, HIGH);
      digitalWrite(cPin, HIGH);
      digitalWrite(dPin, HIGH);
      digitalWrite(ePin, HIGH);
      digitalWrite(fPin, HIGH);
      digitalWrite(gPin, LOW);
      digitalWrite(dpPin, LOW);
    case 1:
      digitalWrite(aPin, LOW);
      digitalWrite(dPin, LOW);
      digitalWrite(ePin, LOW);
      digitalWrite(fPin, LOW);
    case 2:
      digitalWrite(cPin, LOW);
      digitalWrite(gPin, HIGH);
    case 3:
    case 4:
    case 5:
      digitalWrite(bPin, LOW);
    case 6:
    case 7:
    case 8:
    case 9:
    default:
void dp () {
//      digitalWrite(aPin, LOW);
//      digitalWrite(bPin, LOW);
//      digitalWrite(cPin, LOW);
//      digitalWrite(dPin, LOW);
//      digitalWrite(ePin, LOW);
//      digitalWrite(fPin, LOW);
//      digitalWrite(gPin, LOW);
Sonologist
Sonologist аватар
Ну вот, и я дорос до того, чтобы поучать новичков :) Дружище, введите Ваш код так, как на форуме положено (http://arduino.ru/forum/obshchii/vstavka-programmnogo-koda-v-temukomment...). В противном случае никто помогать не будет. Это связано с тем (в первую очередь), что Ваши строки не пронумерованы и указывать на ошибки очень трудно и муторно. Навскидку - у Вас не объявлены переменные "Ледпин" и "и". Об этом компилятор и сообщает. Постарайтесь найти ошибку самостоятельно.
