Проблема с первой же прошивки.
Чт, 09/02/2017 - 22:47
Всем привет. Купил себе ардуину(Arduino Pro Mini(AtMega 328 3.3v)), купил конвертер "USB Serial adapter CH340G", всё, естественно у китайцев. Скачал AdruinoIDE, попробовал загрузить код для мигания светодиода из примера и получил вот такой вывод:
Arduino: 1.8.0 (Linux), Плата:"Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)" /usr/share/arduino/arduino-builder -dump-prefs -logger=machine -hardware /usr/share/arduino/hardware -tools /usr/share/arduino/tools-builder -built-in-libraries /usr/share/arduino/libraries -libraries /root/Arduino/libraries -fqbn=archlinux-arduino:avr:pro:cpu=8MHzatmega328 -ide-version=10800 -build-path /tmp/arduino_build_545035 -warnings=none -prefs=build.warn_data_percentage=75 -verbose /usr/share/arduino/examples/01.Basics/Blink/Blink.ino /usr/share/arduino/arduino-builder -compile -logger=machine -hardware /usr/share/arduino/hardware -tools /usr/share/arduino/tools-builder -built-in-libraries /usr/share/arduino/libraries -libraries /root/Arduino/libraries -fqbn=archlinux-arduino:avr:pro:cpu=8MHzatmega328 -ide-version=10800 -build-path /tmp/arduino_build_545035 -warnings=none -prefs=build.warn_data_percentage=75 -verbose /usr/share/arduino/examples/01.Basics/Blink/Blink.ino Using board 'pro' from platform in folder: /usr/share/arduino/hardware/archlinux-arduino/avr Using core 'arduino' from platform in folder: /usr/share/arduino/hardware/archlinux-arduino/avr Detecting libraries used... "/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-devirtualize -fno-use-cxa-atexit -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10800 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/archlinux-arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/archlinux-arduino/avr/variants/eightanaloginputs" "/tmp/arduino_build_545035/sketch/Blink.ino.cpp" -o "/dev/null" Generating function prototypes... "/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-devirtualize -fno-use-cxa-atexit -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10800 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/archlinux-arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/archlinux-arduino/avr/variants/eightanaloginputs" "/tmp/arduino_build_545035/sketch/Blink.ino.cpp" -o "/tmp/arduino_build_545035/preproc/ctags_target_for_gcc_minus_e.cpp" "/usr/bin/arduino-ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/tmp/arduino_build_545035/preproc/ctags_target_for_gcc_minus_e.cpp" Компиляция скетча... "/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -fno-devirtualize -fno-use-cxa-atexit -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10800 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/archlinux-arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/archlinux-arduino/avr/variants/eightanaloginputs" "/tmp/arduino_build_545035/sketch/Blink.ino.cpp" -o "/tmp/arduino_build_545035/sketch/Blink.ino.cpp.o" Compiling libraries... Compiling core... Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/wiring_pulse.S.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/WInterrupts.c.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/hooks.c.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/wiring.c.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/wiring_analog.c.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/wiring_digital.c.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/wiring_pulse.c.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/wiring_shift.c.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/CDC.cpp.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/HardwareSerial.cpp.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/HardwareSerial0.cpp.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/HardwareSerial1.cpp.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/HardwareSerial2.cpp.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/HardwareSerial3.cpp.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/IPAddress.cpp.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/PluggableUSB.cpp.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/Print.cpp.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/Stream.cpp.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/Tone.cpp.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/USBCore.cpp.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/WMath.cpp.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/WString.cpp.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/abi.cpp.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/main.cpp.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/new.cpp.o Используем предварительно скомпилированный файл: /tmp/arduino_build_545035/core/core.a Linking everything together... "/usr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "/tmp/arduino_build_545035/Blink.ino.elf" "/tmp/arduino_build_545035/sketch/Blink.ino.cpp.o" "/tmp/arduino_build_545035/core/core.a" "-L/tmp/arduino_build_545035" -lm "/usr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "/tmp/arduino_build_545035/Blink.ino.elf" "/tmp/arduino_build_545035/Blink.ino.eep" "/usr/bin/avr-objcopy" -O ihex -R .eeprom "/tmp/arduino_build_545035/Blink.ino.elf" "/tmp/arduino_build_545035/Blink.ino.hex" Скетч использует 918 байт (2%) памяти устройства. Всего доступно 30720 байт. Глобальные переменные используют 9 байт (0%) динамической памяти, оставляя 2039 байт для локальных переменных. Максимум: 2048 байт. //bin/avrdude -C//etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b57600 -D -Uflash:w:/tmp/arduino_build_545035/Blink.ino.hex:i avrdude: Version 6.3, compiled on Nov 6 2016 at 21:45:03 Copyright (c) 2000-2005 Brian Dean, [url]http://www.bdmicro.com/[/url] Copyright (c) 2007-2014 Joerg Wunsch System wide configuration file is "//etc/avrdude.conf" User configuration file is "/root/.avrduderc" User configuration file does not exist or is not a regular file, skipping Using Port : /dev/ttyUSB0 Using Programmer : arduino Overriding Baud Rate : 57600 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00 avrdude done. Thank you. Проблема загрузки в плату. Помощь по загрузке: [url]http://www.arduino.cc/en/Guide/Troubleshooting#upload[/url] .
Подключал платку к конвертеру:
GND - GND
VCC - 3V3
RXI - TX
TXO - RX
RST - DTR(пробовал подключать и к RST, и вообще не задействовать этот выход, но результат тот же).
Подскажите, пожалуйста, что делать и как с этим бороться. В "Инструменты" всё выставил правильно(как в мануале).
Где-то читал, что для китайских ардуин нужен свой отдельный драйвер и так же читал, что для тех у кого Linux он не нужен. У меня же ArchLinux.
