Esp32 + ADS1256
Вс, 13/02/2022 - 00:30
#include <Arduino.h>
#include <Ads1256.h>
#define PIN_CS 5
#define PIN_DRDY 17
volatile bool ready = false;
void IRAM_ATTR readyIsr() {
ready = true;
Ads1256::Time dly;
Ads1256::Spi spi(PIN_CS);
Ads1256 ads(spi, dly, ready);
uint8_t chan = 0;
void resetAds() {
Serial.print("Reset Ads1256 ");
ads.reset();
if( ads.wait() ) {
Serial.print("done, init ");
uint8_t cmd = 0b11110000; // IO -> all output, all GND
if( ads.clock_out(Ads1256::CO_OFF) // dont drive external clock out
&& ads.wreg(Ads1256::IO, &cmd, 1) // save power for open pins
&& ads.sps(Ads1256::SPS_30K) // fast read
&& ads.mux(0) // 0->gnd
&& ads.standby() ) { // standby
Serial.println("done: standby");
else {
Serial.println("failed");
else {
void printRegs() {
uint8_t data[Ads1256::FSC2 + 1] = {0};
ads.rreg(Ads1256::STATUS, data, sizeof(data));
Serial.print("(ST MU AD DR IO OFFSET FULL)=(");
for(size_t i = 0; i < 5; i++) {
Serial.printf("%02x ", data[i]);
Ads1256::value_t o, f;
o.lo = data[5];
o.mid = data[6];
o.hi = data[7];
f.lo = data[8];
f.mid = data[9];
f.hi = data[10];
Serial.printf("%8d %8d) - ", Ads1256::to_int(o), Ads1256::to_int(f));
void check24bit() {
typedef struct val2uvolt { Ads1256::value_t val; int32_t uvolt[7]; } val2uvolt_t;
val2uvolt_t vu[] = { // selected value_t values to print out
{{ 0, 0, 0 }},
{{ 0, 0, 1 }},
{{ 0, 1, 0 }},
{{ 1, 0, 0 }},
{{ 0, 0, 0xff }},
{{ 0, 0xff, 0 }},
{{ 0x7f, 0, 0 }},
{{ 0x7f, 0xff, 0xff }},
{{ (int8_t)0xff, 0, 0 }},
{{ (int8_t)0xff, 0xff, 0xff }},
{{ (int8_t)0x80, 0, 0 }} };
Serial.printf("%30s -> %11d %11d %11d %11d %11d %11d %11d gains\n", "u, i, raw", 0, 1, 2, 3, 4, 5, 6);
for( uint32_t u=0; u<=0xffffff; u++) { // possible values from sensor as uint32_t
int32_t i = (int32_t)(u | ((u & 0x800000) ? 0xff000000 : 0)); // possible values from sensor as int32_t
Ads1256::value_t value; // possible values from sensor as value_t
value.hi = (int8_t)(u >> 16);
value.mid = (u >> 8) & 0xff;
value.lo = u & 0xff;
int32_t raw = Ads1256::to_int(value); // calculated value as int32_t
bool isExample = false;
for( size_t v=0; v < sizeof(vu)/sizeof(*vu); v++ ) {
if( value.hi == vu[v].val.hi && value.mid == vu[v].val.mid && value.lo == vu[v].val.lo ) {
isExample = true;
Serial.printf("0x%06x => %8d == %8d -> ", u, i, raw);
for( size_t g=0; g < sizeof(vu[0].uvolt)/sizeof(vu[0].uvolt[0]); g++) {
vu[v].uvolt[g] = Ads1256::to_microvolts(raw, g, 2500000);
Serial.printf("%11d %11d %11d %11d %11d %11d %11d µV\n", vu[v].uvolt[0], vu[v].uvolt[1],
vu[v].uvolt[2], vu[v].uvolt[3], vu[v].uvolt[4], vu[v].uvolt[5], vu[v].uvolt[6]);
if( !isExample && i != raw ) {
Serial.printf("0x%06x => %8d != %8d -> error\n", u, i, raw);
Serial.begin(115200);
// delay(1500);
Serial.println("\nADS1256 swipe " __FILE__ " " __TIMESTAMP__);
// check24bit();
attachInterrupt(PIN_DRDY, readyIsr, FALLING);
ads.begin(); // start spi
// after ESP reset we dont know the ads state -> reset
// then ads is calibrated, idle, single read mode for channel 0-1 mux, no gain
resetAds(); // reset ads and set some basic config (SPS, mux, clock out, standby)
if( ads.wakeup() && ads.wait() ) {
printRegs();
Serial.println("init done");
else {
Serial.println("init failed");
bool first = true;
uint8_t swipeAins[] = { 0, 1, 2, 3, 4, 5, 6, 7 };
uint8_t *swipeAouts = 0; // measure ain -> gnd
Ads1256::value_t swipeValues[sizeof(swipeAins)];
size_t swipeRepeats = 1000;
uint32_t start = millis();
size_t count = sizeof(swipeAins);
if( ads.read_swipe(swipeValues, swipeAins, swipeAouts, count, first) ) {
first = false;
// some more swipes to get an average SPS
for( size_t repeat = 0; repeat < swipeRepeats; repeat++ ) {
ads.read_swipe(swipeValues, swipeAins, swipeAouts, count, first);
uint32_t elapsed = millis() - start;
Serial.printf("Swipe SPS = %u: ", count*swipeRepeats*1000/elapsed);
for( size_t i = 0; i < count; i++ ) {
int32_t uv = Ads1256::to_microvolts(Ads1256::to_int(swipeValues[i]));
Serial.printf("%u = %d, ", swipeAins[i], uv);
Serial.println();
else {
Serial.println("swipe read failed");
Подсажите как получить данные на один необходимый канал и использовать их в дальнейшем?
