Bluetooth-модуль HC-05 мониторинг
Ср, 21/05/2014 - 17:37
Eсть модуль BT HC-05. Возможно мониторить какой код посылается с андройда на ардуино?
char dataIn = 'S'; //Character/Data coming from the phone.
int pinForwardBack = 13; //Pin that controls the car's Forward-Back motor.
int pinLeftRight = 12; //Pin that controls the car's Left-Right motor.
int pinBrakeLeftRight = 9; //Pin that enables/disables Left-Right motor.
int pinBrakeForwardBack = 8; //Pin that enables/disables Forward-Back motor.
int pinLeftRightSpeed = 3; //Pin that sets the speed for the Left-Right motor.
int pinForwardBackSpeed = 11; //Pin that sets the speed for the Forward-Back motor.
int pinfrontLights = 4; //Pin that activates the Front lights.
int pinbackLights = 7; //Pin that activates the Back lights.
int pinextra = 10; //Pin that activates the Front lights.
int pinhorn = 5; //Pin that activates the Back lights.
char determinant; //Used in the check function, stores the character received from the phone.
char det; //Used in the loop function, stores the character received from the phone.
int velocity = 0; //Stores the speed based on the character sent by the phone.
//*************NOTE: If using Bluetooth Mate Silver use 115200 btu
// If using MDFLY Bluetooth Module use 9600 btu
Serial.begin(38400); //Initialize serial communication with Bluetooth module at 115200 btu.
pinMode(pinForwardBack, OUTPUT);
pinMode(pinLeftRight, OUTPUT);
pinMode(pinBrakeLeftRight, OUTPUT);
pinMode(pinBrakeForwardBack, OUTPUT);
pinMode(pinLeftRightSpeed , OUTPUT);
pinMode(pinForwardBackSpeed , OUTPUT);
pinMode(pinfrontLights , OUTPUT);
pinMode(pinbackLights , OUTPUT);
pinMode(pinhorn , OUTPUT);
pinMode(pinextra , OUTPUT);
det = check();
while (det == 'F') //if incoming data is a F, move forward
digitalWrite(pinForwardBack, LOW);
digitalWrite(pinBrakeForwardBack, LOW);
analogWrite(pinForwardBackSpeed,velocity);
analogWrite(pinLeftRightSpeed,0); //To make the Left/Right Motor not move, you just need to make its speed 0.
det = check();
while (det == 'B') //if incoming data is a B, move back
digitalWrite(pinForwardBack, HIGH);
det = check();
while (det == 'L') //if incoming data is a L, move wheels left
digitalWrite(pinLeftRight, HIGH);
digitalWrite(pinBrakeLeftRight, LOW);
analogWrite(pinForwardBackSpeed,0); //To make the Forward/Back Motor not move, you just need to make its speed 0.
analogWrite(pinLeftRightSpeed,255);
det = check();
while (det == 'R') //if incoming data is a R, move wheels right
digitalWrite(pinLeftRight, LOW);
det = check();
while (det == 'I') //if incoming data is a I, turn right forward
det = check();
while (det == 'J') //if incoming data is a J, turn right back
det = check();
while (det == 'G') //if incoming data is a G, turn left forward
det = check();
while (det == 'H') //if incoming data is a H, turn left back
det = check();
while (det == 'S') //if incoming data is a S, stop
det = check();
while (det == 'X') //if incoming data is a U, turn ON front lights
digitalWrite(pinextra, HIGH);
det = check();
while (det == 'x') //if incoming data is a u, turn OFF front lights
digitalWrite(pinextra, LOW);
det = check();
while (det == 'U') //if incoming data is a U, turn ON front lights
digitalWrite(pinfrontLights, HIGH);
det = check();
while (det == 'u') //if incoming data is a u, turn OFF front lights
digitalWrite(pinfrontLights, LOW);
det = check();
while (det == 'V') //if incoming data is a U, turn ON front lights
digitalWrite(pinhorn, HIGH);
det = check();
while (det == 'v') //if incoming data is a u, turn OFF front lights
digitalWrite(pinhorn, LOW);
det = check();
while (det == 'W') //if incoming data is a W, turn ON back lights
digitalWrite(pinbackLights, HIGH);
det = check();
while (det == 'w') //if incoming data is a w, turn OFF back lights
digitalWrite(pinbackLights, LOW);
det = check();
int check()
if (Serial.available() > 0) //Check for data on the serial lines.
dataIn = Serial.read(); //Get the character sent by the phone and store it in 'dataIn'.
if (dataIn == 'F')
determinant = 'F';
else if (dataIn == 'B')
determinant = 'B';
else if (dataIn == 'L')
determinant = 'L';
else if (dataIn == 'R')
determinant = 'R';
else if (dataIn == 'I')
determinant = 'I';
else if (dataIn == 'J')
determinant = 'J';
else if (dataIn == 'G')
determinant = 'G';
else if (dataIn == 'H')
determinant = 'H';
else if (dataIn == 'S')
determinant = 'S';
else if (dataIn == '0')
velocity = 0; //"velocity" does not need to be returned.
else if (dataIn == '1')
velocity = 25;
else if (dataIn == '2')
velocity = 50;
else if (dataIn == '3')
velocity = 75;
else if (dataIn == '4')
velocity = 100;
else if (dataIn == '5')
velocity = 125;
else if (dataIn == '6')
velocity = 150;
else if (dataIn == '7')
velocity = 175;
else if (dataIn == '8')
velocity = 200;
else if (dataIn == '9')
velocity = 225;
else if (dataIn == 'q')
velocity = 255;
else if (dataIn == 'U')
determinant = 'U';
else if (dataIn == 'u')
determinant = 'u';
else if (dataIn == 'W')
determinant = 'W';
else if (dataIn == 'w')
determinant = 'w';
else if (dataIn == 'V')
determinant = 'V';
else if (dataIn == 'v')
determinant = 'v';
else if (dataIn == 'X')
determinant = 'X';
else if (dataIn == 'x')
determinant = 'x';
return determinant;
