EtherCard : multipacketSD
Втр, 21/06/2016 - 13:12
Здравствуйте.
Никак не могу подружить эти две библиотеки.
https://codebender.cc/example/EtherCard/multipacketSD#multipacketSD.ino
// works only with tinyfat library
// with SD library packets lost will occurs
// don't know why !
// tested with arduino mega 1280 and uno
// send 240 Megabyte file without packet loss
// at 100 kbyte/s
// tinyfat read a block of 512 bytes on SD card ,
// so the buffer must be 512 + 60 bytes
// on the arduino mega with bigger buffer you can adjust
// if (cur>=512) { // 512 to 1024 with 1100 bytes buffer
#include <EtherCard.h>
#include <tinyFAT.h>
#include <avr/pgmspace.h>
#define TCP_FLAGS_FIN_V 1 //as declared in net.h
#define TCP_FLAGS_ACK_V 16 //as declared in net.h
static byte myip[] = { 192,168,0,66 };
static byte gwip[] = { 192,168,0,250 };
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x39 };
byte Ethernet::buffer[700]; // tcp/ip send and receive buffer
unsigned long cur;
unsigned long pos;
byte res;
// Initialize serial communication at 115200 baud
Serial.begin(115200);
// Initialize tinyFAT
// You might need to select a lower speed than the default SPISPEED_HIGH
file.setSSpin(4);
res=file.initFAT(0);
if (res==NO_ERROR) Serial.println("SD started");
ether.begin(sizeof Ethernet::buffer, mymac , 10); //53 on mega ethernet shield 10 on others
ether.staticSetup(myip, gwip);
Serial.println("ETH started");
wait:
pos = ether.packetLoop(ether.packetReceive());// check if valid tcp data is received
if (pos) {
char* data = (char *) Ethernet::buffer + pos;
cur=0;
if (strncmp("GET / ", data, 6) == 0) {// nothing specified
sendfiles("index.htm");
goto wait;
if (strncmp("GET /", data, 5) == 0) { // serve anything on sd card
int i =0;
char temp[15]=""; // here will be the name of requested file
while (data[i+5]!=32) {temp[i]=data[i+5];i++;}//search the end
sendfiles((char*) temp);
goto wait;
not_found();
void not_found() { //content not found
cur=0;
streamfile ("404.hea",TCP_FLAGS_FIN_V);
// Serial.println("not found");
byte streamfile (char* name , byte lastflag) { //send a file to the buffer
if (!file.exists(name)) {return 0;}
res=file.openFile(name, FILEMODE_BINARY);
int car=512;
while (car==512) {
car=file.readBinary();
for(int i=0;i<car;i++) {
cur++;
Ethernet::buffer[cur+53]=file.buffer[i];
if (cur>=512) {
ether.httpServerReply_with_flags(cur,TCP_FLAGS_ACK_V);
cur=0;
} else {
if (lastflag==TCP_FLAGS_FIN_V) {
ether.httpServerReply_with_flags(cur,TCP_FLAGS_ACK_V+TCP_FLAGS_FIN_V);
file.closeFile();
return 1;
byte sendfiles(char* name) { // function to find the correct header and send a file
ether.httpServerReplyAck();
int i =0;
char dtype[13]="";
while (name[i]!=0) {
i++;
}//search the end
int b=i-1;
while ((name[b]!=46)&&(b>0)) {
b--;
}//search the point
int a=b+1;
while (a<i) {
dtype[a-b-1]=name[a];
a++;
dtype[a-b-1]='.';
dtype[a-b]='h';
dtype[a-b+1]='e';
dtype[a-b+2]='a';
//Serial.println(dtype); // print the requested header file
if (streamfile ((char *)dtype,0)==0) {
streamfile ("txt.hea",0);
//Serial.println(name); // print the requested file
if (streamfile ((char *)name,TCP_FLAGS_FIN_V)==0) {
cur=0;
not_found();
/* uncomment this if you want to have printed the ip of the target browser
Serial.print("content send to ");
for(int i=30; i<34; i++) {
Serial.print(Ethernet::buffer[i]);
if (i<33) Serial.print(".");
Serial.println(" ");
Всё что я вижу в порту, это Serial.println("ETH started");
Почему SD не запускается?
