Grbl 0-8 не стыкуется с ардуино 1.8.6
Пнд, 05/02/2018 - 16:06
Проблема: установил библиотеку Grbl 0-8, на ардуино 1.8.6 при компиляции скетча выдал ошибку
Arduino: 1.8.6 Hourly Build 2018/01/03 03:33 (Windows 8), Плата:"Arduino Nano, ATmega328P"
In file included from C:\Users\Анастасия\Documents\Arduino\libraries\grbl-0_8/gcode.h:33:0,
from C:\Users\Анастасия\Downloads\CNC\CNC.ino:5:
C:\Users\Анастасия\Documents\Arduino\libraries\grbl-0_8/nuts_bolts.h:40:0: warning: "false" redefined
#define false 0
In file included from C:\Users\Анастасия\Desktop\arduino-nightly\hardware\arduino\avr\cores\arduino/Arduino.h:24:0,
from sketch\CNC.ino.cpp:1:
c:\users\анастасия\desktop\arduino-nightly\hardware\tools\avr\lib\gcc\avr\4.9.2\include\stdbool.h:42:0: note: this is the location of the previous definition
#define false false
C:\Users\Анастасия\Documents\Arduino\libraries\grbl-0_8/nuts_bolts.h:41:0: warning: "true" redefined
#define true 1
c:\users\анастасия\desktop\arduino-nightly\hardware\tools\avr\lib\gcc\avr\4.9.2\include\stdbool.h:43:0: note: this is the location of the previous definition
#define true true
C:\Users\Анастасия\Documents\Arduino\libraries\grbl-0_8/nuts_bolts.h:54:0: warning: "max" redefined
#define max(a,b) (((a) > (b)) ? (a) : (b))
In file included from sketch\CNC.ino.cpp:1:0:
C:\Users\Анастасия\Desktop\arduino-nightly\hardware\arduino\avr\cores\arduino/Arduino.h:93:0: note: this is the location of the previous definition
#define max(a,b) ((a)>(b)?(a):(b))
C:\Users\Анастасия\Documents\Arduino\libraries\grbl-0_8/nuts_bolts.h:55:0: warning: "min" redefined
#define min(a,b) (((a) < (b)) ? (a) : (b))
C:\Users\Анастасия\Desktop\arduino-nightly\hardware\arduino\avr\cores\arduino/Arduino.h:92:0: note: this is the location of the previous definition
#define min(a,b) ((a)<(b)?(a):(b))
C:\Users\Анастасия\Documents\Arduino\libraries\grbl-0_8/nuts_bolts.h:58:0: warning: "bit" redefined
#define bit(n) (1 << n)
C:\Users\Анастасия\Desktop\arduino-nightly\hardware\arduino\avr\cores\arduino/Arduino.h:123:0: note: this is the location of the previous definition
#define bit(b) (1UL << (b))
HardwareSerial0.cpp.o (symbol from plugin): In function `Serial':
(.text+0x0): multiple definition of `__vector_18'
libraries\grbl-0_8\serial.c.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `__vector_19'
collect2.exe: error: ld returned 1 exit status
Несколько библиотек найдено для "config.h"
Используется: C:\Users\Анастасия\Documents\Arduino\libraries\grbl-0_8
Не используется: C:\Users\Анастасия\Desktop\arduino-nightly\libraries\grbl-0_8
exit status 1
Ошибка компиляции для платы Arduino Nano.
