OLED дисплей ардуино
Пт, 07/03/2014 - 14:04
Добрый день !
Поставил себе задачу выдергивать температуру с датчика Origon
В наличии имеется .
Arduino Leonardo
OLED дисплей 128x64
RF приемник
Погуглил и нашел вот такой скетч
// Oregon V2 decoder added - Dominique Pierre // Oregon V3 decoder revisited - Dominique Pierre // New code to decode OOK signals from weather sensors, etc. // 2010-04-11 <jcw@equi4.com> <a data-cke-saved-href="<a href="http://opensource.org/licenses/mit-license.php" rel="nofollow">http://opensource.org/licenses/mit-license.php</a>" href="<a href="http://opensource.org/licenses/mit-license.php" rel="nofollow">http://opensource.org/licenses/mit-license.php</a>" rel="nofollow"><a href="http://opensource.org/licenses/mit-license.php" rel="nofollow">http://opensource.org/licenses/mit-license.php</a></a> // $Id: ookDecoder.pde 5331 2010-04-17 10:45:17Z jcw $ class DecodeOOK { protected: byte total_bits, bits, flip, state, pos, data[25]; virtual char decode (word width) =0; public: enum { UNKNOWN, T0, T1, T2, T3, OK, DONE }; DecodeOOK () { resetDecoder(); } bool nextPulse (word width) { if (state != DONE) switch (decode(width)) { case -1: resetDecoder(); break; case 1: done(); break; } return isDone(); } bool isDone () const { return state == DONE; } const byte* getData (byte& count) const { count = pos; return data; } void resetDecoder () { total_bits = bits = pos = flip = 0; state = UNKNOWN; } // add one bit to the packet data buffer virtual void gotBit (char value) { total_bits++; byte *ptr = data + pos; *ptr = (*ptr >> 1) | (value << 7); if (++bits >= 8) { bits = 0; if (++pos >= sizeof data) { resetDecoder(); return; } } state = OK; } // store a bit using Manchester encoding void manchester (char value) { flip ^= value; // manchester code, long pulse flips the bit gotBit(flip); } // move bits to the front so that all the bits are aligned to the end void alignTail (byte max =0) { // align bits if (bits != 0) { data[pos] >>= 8 - bits; for (byte i = 0; i < pos; ++i) data[i] = (data[i] >> bits) | (data[i+1] << (8 - bits)); bits = 0; } // optionally shift bytes down if there are too many of 'em if (max > 0 && pos > max) { byte n = pos - max; pos = max; for (byte i = 0; i < pos; ++i) data[i] = data[i+n]; } } void reverseBits () { for (byte i = 0; i < pos; ++i) { byte b = data[i]; for (byte j = 0; j < 8; ++j) { data[i] = (data[i] << 1) | (b & 1); b >>= 1; } } } void reverseNibbles () { for (byte i = 0; i < pos; ++i) data[i] = (data[i] << 4) | (data[i] >> 4); } void done () { while (bits) gotBit(0); // padding state = DONE; } }; // 433 MHz decoders class OregonDecoderV2 : public DecodeOOK { public: OregonDecoderV2() {} // add one bit to the packet data buffer virtual void gotBit (char value) { if(!(total_bits & 0x01)) { data[pos] = (data[pos] >> 1) | (value ? 0x80 : 00); } total_bits++; pos = total_bits >> 4; if (pos >= sizeof data) { resetDecoder(); return; } state = OK; } virtual char decode (word width) { if (200 <= width && width < 1200) { byte w = width >= 700; switch (state) { case UNKNOWN: if (w != 0) { // Long pulse ++flip; } else if (32 <= flip) { // Short pulse, start bit flip = 0; state = T0; } else { // Reset decoder return -1; } break; case OK: if (w == 0) { // Short pulse state = T0; } else { // Long pulse manchester(1); } break; case T0: if (w == 0) { // Second short pulse manchester(0); } else { // Reset decoder return -1; } break; } } else { return -1; } return total_bits == 160 ? 1: 0; } }; class OregonDecoderV3 : public DecodeOOK { public: OregonDecoderV3() {} // add one bit to the packet data buffer virtual void gotBit (char value) { data[pos] = (data[pos] >> 1) | (value ? 0x80 : 00); total_bits++; pos = total_bits >> 3; if (pos >= sizeof data) { resetDecoder(); return; } state = OK; } virtual char decode (word width) { if (200 <= width && width < 1200) { byte w = width >= 700; switch (state) { case UNKNOWN: if (w == 0) ++flip; else if (32 <= flip) { flip = 1; manchester(1); } else return -1; break; case OK: if (w == 0) state = T0; else manchester(1); break; case T0: if (w == 0) manchester(0); else return -1; break; } } else { return -1; } return total_bits == 80 ? 1: 0; } }; class CrestaDecoder : public DecodeOOK { public: CrestaDecoder () {} virtual char decode (word width) { if (200 <= width && width < 1300) { byte w = width >= 750; switch (state) { case UNKNOWN: if (w == 1) ++flip; else if (2 <= flip && flip <= 10) state = T0; else return -1; break; case OK: if (w == 0) state = T0; else gotBit(1); break; case T0: if (w == 0) gotBit(0); else return -1; break; } } else if (width >= 2500 && pos >= 7) return 1; else return -1; return 0; } }; class KakuDecoder : public DecodeOOK { public: KakuDecoder () {} virtual char decode (word width) { if (180 <= width && width < 450 || 950 <= width && width < 1250) { byte w = width >= 700; switch (state) { case UNKNOWN: case OK: if (w == 0) state = T0; else return -1; break; case T0: if (w) state = T1; else return -1; break; case T1: state += w + 1; break; case T2: if (w) gotBit(0); else return -1; break; case T3: if (w == 0) gotBit(1); else return -1; break; } } else if (width >= 2500 && 8 * pos + bits == 12) { for (byte i = 0; i < 4; ++i) gotBit(0); alignTail(2); return 1; } else return -1; return 0; } }; class XrfDecoder : public DecodeOOK { public: XrfDecoder () {} // see also <a data-cke-saved-href="<a href="http://davehouston.net/rf.htm" rel="nofollow">http://davehouston.net/rf.htm</a>" href="<a href="http://davehouston.net/rf.htm" rel="nofollow">http://davehouston.net/rf.htm</a>" rel="nofollow"><a href="http://davehouston.net/rf.htm" rel="nofollow">http://davehouston.net/rf.htm</a></a> virtual char decode (word width) { if (width > 2000 && pos >= 4) return 1; if (width > 5000) return -1; if (width > 4000 && state == UNKNOWN) state = OK; else if (350 <= width && width < 1800) { byte w = width >= 720; switch (state) { case OK: if (w == 0) state = T0; else return -1; break; case T0: gotBit(w); break; } } else return -1; return 0; } }; class HezDecoder : public DecodeOOK { public: HezDecoder () {} // see also <a data-cke-saved-href="<a href="http://homeeasyhacking.wikia.com/wiki/Home_Easy_Hacking_Wiki" rel="nofollow">http://homeeasyhacking.wikia.com/wiki/Home_Easy_Hacking_Wiki</a>" href="<a href="http://homeeasyhacking.wikia.com/wiki/Home_Easy_Hacking_Wiki" rel="nofollow">http://homeeasyhacking.wikia.com/wiki/Home_Easy_Hacking_Wiki</a>" rel="nofollow"><a href="http://homeeasyhacking.wikia.com/wiki/Home_Easy_Hacking_Wiki" rel="nofollow">http://homeeasyhacking.wikia.com/wiki/Home_Easy_Hacking_Wiki</a></a> virtual char decode (word width) { if (200 <= width && width < 1200) { byte w = width >= 600; gotBit(w); } else if (width >= 5000 && pos >= 5 /*&& 8 * pos + bits == 50*/) { for (byte i = 0; i < 6; ++i) gotBit(0); alignTail(7); // keep last 56 bits return 1; } else return -1; return 0; } }; // 868 MHz decoders class VisonicDecoder : public DecodeOOK { public: VisonicDecoder () {} virtual char decode (word width) { if (200 <= width && width < 1000) { byte w = width >= 600; switch (state) { case UNKNOWN: case OK: state = w == 0 ? T0 : T1; break; case T0: gotBit(!w); if (w) return 0; break; case T1: gotBit(!w); if (!w) return 0; break; } // sync error, flip all the preceding bits to resync for (byte i = 0; i <= pos; ++i) data[i] ^= 0xFF; } else if (width >= 2500 && 8 * pos + bits >= 36 && state == OK) { for (byte i = 0; i < 4; ++i) gotBit(0); alignTail(5); // keep last 40 bits // only report valid packets byte b = data[0] ^ data[1] ^ data[2] ^ data[3] ^ data[4]; if ((b & 0xF) == (b >> 4)) return 1; } else return -1; return 0; } }; class EMxDecoder : public DecodeOOK { public: EMxDecoder () {} // see also <a data-cke-saved-href="<a href="http://fhz4linux.info/tiki-index.php?page=EM+Protocol" rel="nofollow">http://fhz4linux.info/tiki-index.php?page=EM+Protocol</a>" href="<a href="http://fhz4linux.info/tiki-index.php?page=EM+Protocol" rel="nofollow">http://fhz4linux.info/tiki-index.php?page=EM+Protocol</a>" rel="nofollow"><a href="http://fhz4linux.info/tiki-index.php?page=EM+Protocol" rel="nofollow">http://fhz4linux.info/tiki-index.php?page=EM+Protocol</a></a> virtual char decode (word width) { if (200 <= width && width < 1000) { byte w = width >= 600; switch (state) { case UNKNOWN: if (w == 0) ++flip; else if (flip > 20) state = OK; else return -1; break; case OK: if (w == 0) state = T0; else return -1; break; case T0: gotBit(w); break; } } else if (width >= 1500 && pos >= 9) return 1; else return -1; return 0; } }; class KSxDecoder : public DecodeOOK { public: KSxDecoder () {} // see also <a data-cke-saved-href="<a href="http://www.dc3yc.homepage.t-online.de/protocol.htm" rel="nofollow">http://www.dc3yc.homepage.t-online.de/protocol.htm</a>" href="<a href="http://www.dc3yc.homepage.t-online.de/protocol.htm" rel="nofollow">http://www.dc3yc.homepage.t-online.de/protocol.htm</a>" rel="nofollow"><a href="http://www.dc3yc.homepage.t-online.de/protocol.htm" rel="nofollow">http://www.dc3yc.homepage.t-online.de/protocol.htm</a></a> virtual char decode (word width) { if (200 <= width && width < 1000) { byte w = width >= 600; switch (state) { case UNKNOWN: gotBit(w); bits = pos = 0; if (data[0] != 0x95) state = UNKNOWN; break; case OK: state = w == 0 ? T0 : T1; break; case T0: gotBit(1); if (!w) return -1; break; case T1: gotBit(0); if (w) return -1; break; } } else if (width >= 1500 && pos >= 6) return 1; else return -1; return 0; } }; class FSxDecoder : public DecodeOOK { public: FSxDecoder () {} // see also <a data-cke-saved-href="<a href="http://fhz4linux.info/tiki-index.php?page=FS20%20Protocol" rel="nofollow">http://fhz4linux.info/tiki-index.php?page=FS20%20Protocol</a>" href="<a href="http://fhz4linux.info/tiki-index.php?page=FS20%20Protocol" rel="nofollow">http://fhz4linux.info/tiki-index.php?page=FS20%20Protocol</a>" rel="nofollow"><a href="http://fhz4linux.info/tiki-index.php?page=FS20%20Protocol" rel="nofollow">http://fhz4linux.info/tiki-index.php?page=FS20%20Protocol</a></a> virtual char decode (word width) { if (300 <= width && width < 775) { byte w = width >= 500; switch (state) { case UNKNOWN: if (w == 0) ++flip; else if (flip > 20) state = T1; else return -1; break; case OK: state = w == 0 ? T0 : T1; break; case T0: gotBit(0); if (w) return -1; break; case T1: gotBit(1); if (!w) return -1; break; } } else if (width >= 1500 && pos >= 5) return 1; else return -1; return 0; } }; OregonDecoderV2 orscV2; OregonDecoderV3 orscV3; CrestaDecoder cres; KakuDecoder kaku; XrfDecoder xrf; HezDecoder hez; VisonicDecoder viso; EMxDecoder emx; KSxDecoder ksx; FSxDecoder fsx; #define PORT 2 volatile word pulse; #if defined(__AVR_ATmega1280__) void ext_int_1(void) { #else ISR(ANALOG_COMP_vect) { #endif static word last; // determine the pulse length in microseconds, for either polarity pulse = micros() - last; last += pulse; } void reportSerial (const char* s, class DecodeOOK& decoder) { byte pos; const byte* data = decoder.getData(pos); Serial.print(s); Serial.print(' '); for (byte i = 0; i < pos; ++i) { Serial.print(data[i] >> 4, HEX); Serial.print(data[i] & 0x0F, HEX); } // Serial.print(' '); // Serial.print(millis() / 1000); Serial.println(); decoder.resetDecoder(); } void setup () { Serial.begin(115200); Serial.println("\n[ookDecoder]"); #if !defined(__AVR_ATmega1280__) pinMode(13 + PORT, INPUT); // use the AIO pin digitalWrite(13 + PORT, 1); // enable pull-up // use analog comparator to switch at 1.1V bandgap transition ACSR = _BV(ACBG) | _BV(ACI) | _BV(ACIE); // set ADC mux to the proper port ADCSRA &= ~ bit(ADEN); ADCSRB |= bit(ACME); ADMUX = PORT - 1; #else attachInterrupt(1, ext_int_1, CHANGE); DDRE &= ~_BV(PE5); PORTE &= ~_BV(PE5); #endif } void loop () { static int i = 0; cli(); word p = pulse; pulse = 0; sei(); //if (p != 0){ Serial.print(++i); Serial.print('\n');} if (p != 0) { if (orscV2.nextPulse(p)) reportSerial("OSV2", orscV2); if (orscV3.nextPulse(p)) reportSerial("OSV3", orscV3); if (cres.nextPulse(p)) reportSerial("CRES", cres); if (kaku.nextPulse(p)) reportSerial("KAKU", kaku); if (xrf.nextPulse(p)) reportSerial("XRF", xrf); if (hez.nextPulse(p)) reportSerial("HEZ", hez); } if (p != 0) { if (viso.nextPulse(p)) reportSerial("VISO", viso); if (emx.nextPulse(p)) reportSerial("EMX", emx); if (ksx.nextPulse(p)) reportSerial("KSX", ksx); if (fsx.nextPulse(p)) reportSerial("FSX", fsx); } }
Теперь вопрос . Что надо добавить в скетч чтобы информация отображалась на OLED дисплее и к каким контактам подключать RF приемник ?
Прошу сильно не пинать , я только начинаю программировать
