Помогите з русским языком
Ср, 07/12/2016 - 21:37
Матрица такая https://ru.aliexpress.com/item/P3-75-dot-matrix-led-module-3-75mm-high-c...
// Author: Phil Kaziewicz 19th July 2014
// 64x32 LED display matrix test code
// based upon original code from canton-electonics
// Arduino 1.0.5 UNO R3
#include <Arduino.h>
// Connections to board
const byte latchPin=8;
const byte clockPin=12;
const byte data_R1=10;
const byte data_R2=11;
const byte en_74138=2;
const byte la_74138=3;
const byte lb_74138=4;
const byte lc_74138=5;
const byte ld_74138=6;
byte ScanRow = 0;
unsigned long counter;
const char message[] ="Winston Churchill!"
const char message1[] ="Pogoda ";
byte buffer[256] = { // Display buffer (which is scanned by the interrupt timer) of 8x32 bytes
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
// FONTS sourced from various locations on the internet
// full ASCII character set (8x16) (1520 bytes)
const uint8_t font8x16_basic[] PROGMEM = {
/* (32) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
/* ! (33) */ 0x00, 0x00, 0x00, 0x18, 0x3C, 0x3C, 0x3C, 0x18, 0x18, 0x18, 0x00, 0x18, 0x18, 0x00, 0x00, 0x00,
/* " (34) */ 0x00, 0x00, 0x66, 0x66, 0x66, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
/* # (35) */ 0x00, 0x00, 0x00, 0x00, 0x6C, 0x6C, 0xFE, 0x6C, 0x6C, 0x6C, 0xFE, 0x6C, 0x6C, 0x00, 0x00, 0x00,
/* $ (36) */ 0x00, 0x18, 0x18, 0x7C, 0xC6, 0xC2, 0xC0, 0x7C, 0x06, 0x06, 0x86, 0xC6, 0x7C, 0x18, 0x18, 0x00,
/* % (37) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0xC2, 0xC6, 0x0C, 0x18, 0x30, 0x60, 0xC6, 0x86, 0x00, 0x00, 0x00,
/* & (38) */ 0x00, 0x00, 0x00, 0x38, 0x6C, 0x6C, 0x38, 0x76, 0xDC, 0xCC, 0xCC, 0xCC, 0x76, 0x00, 0x00, 0x00,
/* ' (39) */ 0x00, 0x00, 0x30, 0x30, 0x30, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
/* ( (40) */ 0x00, 0x00, 0x00, 0x0C, 0x18, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x18, 0x0C, 0x00, 0x00, 0x00,
/* ) (41) */ 0x00, 0x00, 0x00, 0x30, 0x18, 0x0C, 0x0C, 0x0C, 0x0C, 0x0C, 0x0C, 0x18, 0x30, 0x00, 0x00, 0x00,
/* * (42) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x66, 0x3C, 0xFF, 0x3C, 0x66, 0x00, 0x00, 0x00, 0x00, 0x00,
/* + (43) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x18, 0x7E, 0x18, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00,
/* , (44) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x18, 0x18, 0x30, 0x00, 0x00,
/* - (45) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
/* . (46) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x18, 0x00, 0x00, 0x00,
/* / (47) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x06, 0x0C, 0x18, 0x30, 0x60, 0xC0, 0x80, 0x00, 0x00, 0x00,
/* 0 (207) */ 0x00, 0x00, 0x00, 0x3C, 0x66, 0xC3, 0xC3, 0xDB, 0xDB, 0xC3, 0xC3, 0x66, 0x3C, 0x00, 0x00, 0x00,
/* 1 (49) */ 0x00, 0x00, 0x00, 0x18, 0x38, 0x78, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x7E, 0x00, 0x00, 0x00,
/* 2 (50) */ 0x00, 0x00, 0x00, 0x7C, 0xC6, 0x06, 0x0C, 0x18, 0x30, 0x60, 0xC0, 0xC6, 0xFE, 0x00, 0x00, 0x00,
/* 3 (51) */ 0x00, 0x00, 0x00, 0x7C, 0xC6, 0x06, 0x06, 0x3C, 0x06, 0x06, 0x06, 0xC6, 0x7C, 0x00, 0x00, 0x00,
/* 4 (52) */ 0x00, 0x00, 0x00, 0x0C, 0x1C, 0x3C, 0x6C, 0xCC, 0xFE, 0x0C, 0x0C, 0x0C, 0x1E, 0x00, 0x00, 0x00,
/* 5 (53) */ 0x00, 0x00, 0x00, 0xFE, 0xC0, 0xC0, 0xC0, 0xFC, 0x06, 0x06, 0x06, 0xC6, 0x7C, 0x00, 0x00, 0x00,
/* 6 (54) */ 0x00, 0x00, 0x00, 0x38, 0x60, 0xC0, 0xC0, 0xFC, 0xC6, 0xC6, 0xC6, 0xC6, 0x7C, 0x00, 0x00, 0x00,
/* 7 (55) */ 0x00, 0x00, 0x00, 0xFE, 0xC6, 0x06, 0x06, 0x0C, 0x18, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00,
/* 8 (56) */ 0x00, 0x00, 0x00, 0x7C, 0xC6, 0xC6, 0xC6, 0x7C, 0xC6, 0xC6, 0xC6, 0xC6, 0x7C, 0x00, 0x00, 0x00,
/* 9 (57) */ 0x00, 0x00, 0x00, 0x7C, 0xC6, 0xC6, 0xC6, 0x7E, 0x06, 0x06, 0x06, 0x0C, 0x78, 0x00, 0x00, 0x00,
/* : (58) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x18, 0x00, 0x00, 0x00, 0x18, 0x18, 0x00, 0x00, 0x00, 0x00,
/* ; (59) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x18, 0x00, 0x00, 0x00, 0x18, 0x18, 0x30, 0x00, 0x00, 0x00,
/* < (60) */ 0x00, 0x00, 0x00, 0x00, 0x06, 0x0C, 0x18, 0x30, 0x60, 0x30, 0x18, 0x0C, 0x06, 0x00, 0x00, 0x00,
/* = (61) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7E, 0x00, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
/* > (62) */ 0x00, 0x00, 0x00, 0x00, 0x60, 0x30, 0x18, 0x0C, 0x06, 0x0C, 0x18, 0x30, 0x60, 0x00, 0x00, 0x00,
/* ? (63) */ 0x00, 0x00, 0x00, 0x7C, 0xC6, 0xC6, 0x0C, 0x18, 0x18, 0x18, 0x00, 0x18, 0x18, 0x00, 0x00, 0x00,
/* @ (64) */ 0x00, 0x00, 0x00, 0x00, 0x7C, 0xC6, 0xC6, 0xDE, 0xDE, 0xDE, 0xDC, 0xC0, 0x7C, 0x00, 0x00, 0x00,
/* A (65) */ 0x00, 0x00, 0x00, 0x10, 0x38, 0x6C, 0xC6, 0xC6, 0xFE, 0xC6, 0xC6, 0xC6, 0xC6, 0x00, 0x00, 0x00,
/* B (66) */ 0x00, 0x00, 0x00, 0xFC, 0x66, 0x66, 0x66, 0x7C, 0x66, 0x66, 0x66, 0x66, 0xFC, 0x00, 0x00, 0x00,
/* C (67) */ 0x00, 0x00, 0x00, 0x3C, 0x66, 0xC2, 0xC0, 0xC0, 0xC0, 0xC0, 0xC2, 0x66, 0x3C, 0x00, 0x00, 0x00,
/* D (68) */ 0x00, 0x00, 0x00, 0xF8, 0x6C, 0x66, 0x66, 0x66, 0x66, 0x66, 0x66, 0x6C, 0xF8, 0x00, 0x00, 0x00,
/* E (69) */ 0x00, 0x00, 0x00, 0xFE, 0x66, 0x62, 0x68, 0x78, 0x68, 0x60, 0x62, 0x66, 0xFE, 0x00, 0x00, 0x00,
/* F (70) */ 0x00, 0x00, 0x00, 0xFE, 0x66, 0x62, 0x68, 0x78, 0x68, 0x60, 0x60, 0x60, 0xF0, 0x00, 0x00, 0x00,
/* G (71) */ 0x00, 0x00, 0x00, 0x3C, 0x66, 0xC2, 0xC0, 0xC0, 0xDE, 0xC6, 0xC6, 0x66, 0x3A, 0x00, 0x00, 0x00,
/* H (72) */ 0x00, 0x00, 0x00, 0xC6, 0xC6, 0xC6, 0xC6, 0xFE, 0xC6, 0xC6, 0xC6, 0xC6, 0xC6, 0x00, 0x00, 0x00,
/* I (73) */ 0x00, 0x00, 0x00, 0x3C, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x3C, 0x00, 0x00, 0x00,
/* J (74) */ 0x00, 0x00, 0x00, 0x1E, 0x0C, 0x0C, 0x0C, 0x0C, 0x0C, 0xCC, 0xCC, 0xCC, 0x78, 0x00, 0x00, 0x00,
/* K (75) */ 0x00, 0x00, 0x00, 0xE6, 0x66, 0x66, 0x6C, 0x78, 0x78, 0x6C, 0x66, 0x66, 0xE6, 0x00, 0x00, 0x00,
/* L (76) */ 0x00, 0x00, 0x00, 0xF0, 0x60, 0x60, 0x60, 0x60, 0x60, 0x60, 0x62, 0x66, 0xFE, 0x00, 0x00, 0x00,
/* M (77) */ 0x00, 0x00, 0x00, 0xC3, 0xE7, 0xFF, 0xFF, 0xDB, 0xC3, 0xC3, 0xC3, 0xC3, 0xC3, 0x00, 0x00, 0x00,
/* N (78) */ 0x00, 0x00, 0x00, 0xC6, 0xE6, 0xF6, 0xFE, 0xDE, 0xCE, 0xC6, 0xC6, 0xC6, 0xC6, 0x00, 0x00, 0x00,
/* O (79) */ 0x00, 0x00, 0x00, 0x7C, 0xC6, 0xC6, 0xC6, 0xC6, 0xC6, 0xC6, 0xC6, 0xC6, 0x7C, 0x00, 0x00, 0x00,
/* P (80) */ 0x00, 0x00, 0x00, 0xFC, 0x66, 0x66, 0x66, 0x7C, 0x60, 0x60, 0x60, 0x60, 0xF0, 0x00, 0x00, 0x00,
/* Q (81) */ 0x00, 0x00, 0x00, 0x7C, 0xC6, 0xC6, 0xC6, 0xC6, 0xC6, 0xC6, 0xD6, 0xDE, 0x7C, 0x0C, 0x0E, 0x00,
/* R (82) */ 0x00, 0x00, 0x00, 0xFC, 0x66, 0x66, 0x66, 0x7C, 0x6C, 0x66, 0x66, 0x66, 0xE6, 0x00, 0x00, 0x00,
/* S (83) */ 0x00, 0x00, 0x00, 0x7C, 0xC6, 0xC6, 0x60, 0x38, 0x0C, 0x06, 0xC6, 0xC6, 0x7C, 0x00, 0x00, 0x00,
/* T (84) */ 0x00, 0x00, 0x00, 0xFF, 0xDB, 0x99, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x3C, 0x00, 0x00, 0x00,
/* U (85) */ 0x00, 0x00, 0x00, 0xC6, 0xC6, 0xC6, 0xC6, 0xC6, 0xC6, 0xC6, 0xC6, 0xC6, 0x7C, 0x00, 0x00, 0x00,
/* V (86) */ 0x00, 0x00, 0x00, 0xC3, 0xC3, 0xC3, 0xC3, 0xC3, 0xC3, 0xC3, 0x66, 0x3C, 0x18, 0x00, 0x00, 0x00,
/* W (87) */ 0x00, 0x00, 0x00, 0xC3, 0xC3, 0xC3, 0xC3, 0xC3, 0xDB, 0xDB, 0xFF, 0x66, 0x66, 0x00, 0x00, 0x00,
/* X (88) */ 0x00, 0x00, 0x00, 0xC3, 0xC3, 0x66, 0x3C, 0x18, 0x18, 0x3C, 0x66, 0xC3, 0xC3, 0x00, 0x00, 0x00,
/* Y (89) */ 0x00, 0x00, 0x00, 0xC3, 0xC3, 0xC3, 0x66, 0x3C, 0x18, 0x18, 0x18, 0x18, 0x3C, 0x00, 0x00, 0x00,
/* Z (90) */ 0x00, 0x00, 0x00, 0xFF, 0xC3, 0x86, 0x0C, 0x18, 0x30, 0x60, 0xC1, 0xC3, 0xFF, 0x00, 0x00, 0x00,
/* [ (91) */ 0x00, 0x00, 0x00, 0x3C, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x3C, 0x00, 0x00, 0x00,
/* \ (92) */ 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xE0, 0x70, 0x38, 0x1C, 0x0E, 0x06, 0x02, 0x00, 0x00, 0x00,
/* ] (93) */ 0x00, 0x00, 0x00, 0x3C, 0x0C, 0x0C, 0x0C, 0x0C, 0x0C, 0x0C, 0x0C, 0x0C, 0x3C, 0x00, 0x00, 0x00,
/* ^ (94) */ 0x00, 0x10, 0x38, 0x6C, 0xC6, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
/* _ (95) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0x00,
/* ` (96) */ 0x00, 0x30, 0x30, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
/* a (97) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x0C, 0x7C, 0xCC, 0xCC, 0xCC, 0x76, 0x00, 0x00, 0x00,
/* b (98) */ 0x00, 0x00, 0x00, 0xE0, 0x60, 0x60, 0x78, 0x6C, 0x66, 0x66, 0x66, 0x66, 0x7C, 0x00, 0x00, 0x00,
/* c (99) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0xC6, 0xC0, 0xC0, 0xC0, 0xC6, 0x7C, 0x00, 0x00, 0x00,
/* d (100) */ 0x00, 0x00, 0x00, 0x1C, 0x0C, 0x0C, 0x3C, 0x6C, 0xCC, 0xCC, 0xCC, 0xCC, 0x76, 0x00, 0x00, 0x00,
/* e (101) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0xC6, 0xFE, 0xC0, 0xC0, 0xC6, 0x7C, 0x00, 0x00, 0x00,
/* f (102) */ 0x00, 0x00, 0x00, 0x38, 0x6C, 0x64, 0x60, 0xF0, 0x60, 0x60, 0x60, 0x60, 0xF0, 0x00, 0x00, 0x00,
/* g (103) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x76, 0xCC, 0xCC, 0xCC, 0xCC, 0xCC, 0x7C, 0x0C, 0xCC, 0x78,
/* h (104) */ 0x00, 0x00, 0x00, 0xE0, 0x60, 0x60, 0x6C, 0x76, 0x66, 0x66, 0x66, 0x66, 0xE6, 0x00, 0x00, 0x00,
/* i (105) */ 0x00, 0x00, 0x00, 0x18, 0x18, 0x00, 0x38, 0x18, 0x18, 0x18, 0x18, 0x18, 0x3C, 0x00, 0x00, 0x00,
/* j (106) */ 0x00, 0x00, 0x00, 0x06, 0x06, 0x00, 0x0E, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x66, 0x66, 0x3C,
/* k (107) */ 0x00, 0x00, 0x00, 0xE0, 0x60, 0x60, 0x66, 0x6C, 0x78, 0x78, 0x6C, 0x66, 0xE6, 0x00, 0x00, 0x00,
/* l (108) */ 0x00, 0x00, 0x00, 0x38, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x3C, 0x00, 0x00, 0x00,
/* m (109) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE6, 0xFF, 0xDB, 0xDB, 0xDB, 0xDB, 0xDB, 0x00, 0x00, 0x00,
/* n (110) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xDC, 0x66, 0x66, 0x66, 0x66, 0x66, 0x66, 0x00, 0x00, 0x00,
/* o (111) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0xC6, 0xC6, 0xC6, 0xC6, 0xC6, 0x7C, 0x00, 0x00, 0x00,
/* p (112) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xDC, 0x66, 0x66, 0x66, 0x66, 0x66, 0x7C, 0x60, 0x60, 0xF0,
/* q (113) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x76, 0xCC, 0xCC, 0xCC, 0xCC, 0xCC, 0x7C, 0x0C, 0x0C, 0x1E,
/* r (114) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xDC, 0x76, 0x66, 0x60, 0x60, 0x60, 0xF0, 0x00, 0x00, 0x00,
/* s (115) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0xC6, 0x60, 0x38, 0x0C, 0xC6, 0x7C, 0x00, 0x00, 0x00,
/* t (116) */ 0x00, 0x00, 0x00, 0x10, 0x30, 0x30, 0xFC, 0x30, 0x30, 0x30, 0x30, 0x36, 0x1C, 0x00, 0x00, 0x00,
/* u (117) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xCC, 0xCC, 0xCC, 0xCC, 0xCC, 0xCC, 0x76, 0x00, 0x00, 0x00,
/* v (118) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC3, 0xC3, 0xC3, 0xC3, 0x66, 0x3C, 0x18, 0x00, 0x00, 0x00,
/* w (119) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC3, 0xC3, 0xC3, 0xDB, 0xDB, 0xFF, 0x66, 0x00, 0x00, 0x00,
/* x (120) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC3, 0x66, 0x3C, 0x18, 0x3C, 0x66, 0xC3, 0x00, 0x00, 0x00,
/* y (121) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC6, 0xC6, 0xC6, 0xC6, 0xC6, 0xC6, 0x7E, 0x06, 0x0C, 0xF8,
/* z (122) */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0xCC, 0x18, 0x30, 0x60, 0xC6, 0xFE, 0x00, 0x00, 0x00,
/* { (123) */ 0x00, 0x00, 0x00, 0x0E, 0x18, 0x18, 0x18, 0x70, 0x18, 0x18, 0x18, 0x18, 0x0E, 0x00, 0x00, 0x00,
/* | (124) */ 0x00, 0x00, 0x00, 0x18, 0x18, 0x18, 0x18, 0x00, 0x18, 0x18, 0x18, 0x18, 0x18, 0x00, 0x00, 0x00,
/* } (125) */ 0x00, 0x00, 0x00, 0x70, 0x18, 0x18, 0x18, 0x0E, 0x18, 0x18, 0x18, 0x18, 0x70, 0x00, 0x00, 0x00,
/* ~ (126) */ 0x00, 0x00, 0x00, 0x76, 0xDC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
/* BLK(127)*/ 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
// full ASCII character set (8x8) (760 bytes)
const uint8_t font8x8_basic[] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // U+0020 (space)
0x18, 0x3C, 0x3C, 0x18, 0x18, 0x00, 0x18, 0x00, // U+0021 (!)
0x36, 0x36, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // U+0022 (")
0x36, 0x36, 0x7F, 0x36, 0x7F, 0x36, 0x36, 0x00, // U+0023 (#)
0x0C, 0x3E, 0x03, 0x1E, 0x30, 0x1F, 0x0C, 0x00, // U+0024 ($)
0x00, 0x63, 0x33, 0x18, 0x0C, 0x66, 0x63, 0x00, // U+0025 (%)
0x1C, 0x36, 0x1C, 0x6E, 0x3B, 0x33, 0x6E, 0x00, // U+0026 (&)
0x06, 0x06, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, // U+0027 (')
0x18, 0x0C, 0x06, 0x06, 0x06, 0x0C, 0x18, 0x00, // U+0028 (()
0x06, 0x0C, 0x18, 0x18, 0x18, 0x0C, 0x06, 0x00, // U+0029 ())
0x00, 0x66, 0x3C, 0xFF, 0x3C, 0x66, 0x00, 0x00, // U+002A (*)
0x00, 0x0C, 0x0C, 0x3F, 0x0C, 0x0C, 0x00, 0x00, // U+002B (+)
0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x0C, 0x06, // U+002C (,)
0x00, 0x00, 0x00, 0x3F, 0x00, 0x00, 0x00, 0x00, // U+002D (-)
0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x0C, 0x00, // U+002E (.)
0x60, 0x30, 0x18, 0x0C, 0x06, 0x03, 0x01, 0x00, // U+002F (/)
0x3E, 0x63, 0x73, 0x7B, 0x6F, 0x67, 0x3E, 0x00, // U+0030 (0)
0x0C, 0x0E, 0x0C, 0x0C, 0x0C, 0x0C, 0x3F, 0x00, // U+0031 (1)
0x1E, 0x33, 0x30, 0x1C, 0x06, 0x33, 0x3F, 0x00, // U+0032 (2)
0x1E, 0x33, 0x30, 0x1C, 0x30, 0x33, 0x1E, 0x00, // U+0033 (3)
0x38, 0x3C, 0x36, 0x33, 0x7F, 0x30, 0x78, 0x00, // U+0034 (4)
0x3F, 0x03, 0x1F, 0x30, 0x30, 0x33, 0x1E, 0x00, // U+0035 (5)
0x1C, 0x06, 0x03, 0x1F, 0x33, 0x33, 0x1E, 0x00, // U+0036 (6)
0x3F, 0x33, 0x30, 0x18, 0x0C, 0x0C, 0x0C, 0x00, // U+0037 (7)
0x1E, 0x33, 0x33, 0x1E, 0x33, 0x33, 0x1E, 0x00, // U+0038 (8)
0x1E, 0x33, 0x33, 0x3E, 0x30, 0x18, 0x0E, 0x00, // U+0039 (9)
0x00, 0x0C, 0x0C, 0x00, 0x00, 0x0C, 0x0C, 0x00, // U+003A (:)
0x00, 0x0C, 0x0C, 0x00, 0x00, 0x0C, 0x0C, 0x06, // U+003B (//)
0x18, 0x0C, 0x06, 0x03, 0x06, 0x0C, 0x18, 0x00, // U+003C (<)
0x00, 0x00, 0x3F, 0x00, 0x00, 0x3F, 0x00, 0x00, // U+003D (=)
0x06, 0x0C, 0x18, 0x30, 0x18, 0x0C, 0x06, 0x00, // U+003E (>)
0x1E, 0x33, 0x30, 0x18, 0x0C, 0x00, 0x0C, 0x00, // U+003F (?)
0x3E, 0x63, 0x7B, 0x7B, 0x7B, 0x03, 0x1E, 0x00, // U+0040 (@)
0x0C, 0x1E, 0x33, 0x33, 0x3F, 0x33, 0x33, 0x00, // U+0041 (A)
0x3F, 0x66, 0x66, 0x3E, 0x66, 0x66, 0x3F, 0x00, // U+0042 (B)
0x3C, 0x66, 0x03, 0x03, 0x03, 0x66, 0x3C, 0x00, // U+0043 (C)
0x1F, 0x36, 0x66, 0x66, 0x66, 0x36, 0x1F, 0x00, // U+0044 (D)
0x7F, 0x46, 0x16, 0x1E, 0x16, 0x46, 0x7F, 0x00, // U+0045 (E)
0x7F, 0x46, 0x16, 0x1E, 0x16, 0x06, 0x0F, 0x00, // U+0046 (F)
0x3C, 0x66, 0x03, 0x03, 0x73, 0x66, 0x7C, 0x00, // U+0047 (G)
0x33, 0x33, 0x33, 0x3F, 0x33, 0x33, 0x33, 0x00, // U+0048 (H)
0x1E, 0x0C, 0x0C, 0x0C, 0x0C, 0x0C, 0x1E, 0x00, // U+0049 (I)
0x78, 0x30, 0x30, 0x30, 0x33, 0x33, 0x1E, 0x00, // U+004A (J)
0x67, 0x66, 0x36, 0x1E, 0x36, 0x66, 0x67, 0x00, // U+004B (K)
0x0F, 0x06, 0x06, 0x06, 0x46, 0x66, 0x7F, 0x00, // U+004C (L)
0x63, 0x77, 0x7F, 0x7F, 0x6B, 0x63, 0x63, 0x00, // U+004D (M)
0x63, 0x67, 0x6F, 0x7B, 0x73, 0x63, 0x63, 0x00, // U+004E (N)
0x1C, 0x36, 0x63, 0x63, 0x63, 0x36, 0x1C, 0x00, // U+004F (O)
0x3F, 0x66, 0x66, 0x3E, 0x06, 0x06, 0x0F, 0x00, // U+0050 (P)
0x1E, 0x33, 0x33, 0x33, 0x3B, 0x1E, 0x38, 0x00, // U+0051 (Q)
0x3F, 0x66, 0x66, 0x3E, 0x36, 0x66, 0x67, 0x00, // U+0052 (R)
0x1E, 0x33, 0x07, 0x0E, 0x38, 0x33, 0x1E, 0x00, // U+0053 (S)
0x3F, 0x2D, 0x0C, 0x0C, 0x0C, 0x0C, 0x1E, 0x00, // U+0054 (T)
0x33, 0x33, 0x33, 0x33, 0x33, 0x33, 0x3F, 0x00, // U+0055 (U)
0x33, 0x33, 0x33, 0x33, 0x33, 0x1E, 0x0C, 0x00, // U+0056 (V)
0x63, 0x63, 0x63, 0x6B, 0x7F, 0x77, 0x63, 0x00, // U+0057 (W)
0x63, 0x63, 0x36, 0x1C, 0x1C, 0x36, 0x63, 0x00, // U+0058 (X)
0x33, 0x33, 0x33, 0x1E, 0x0C, 0x0C, 0x1E, 0x00, // U+0059 (Y)
0x7F, 0x63, 0x31, 0x18, 0x4C, 0x66, 0x7F, 0x00, // U+005A (Z)
0x1E, 0x06, 0x06, 0x06, 0x06, 0x06, 0x1E, 0x00, // U+005B ([)
0x03, 0x06, 0x0C, 0x18, 0x30, 0x60, 0x40, 0x00, // U+005C (\)
0x1E, 0x18, 0x18, 0x18, 0x18, 0x18, 0x1E, 0x00, // U+005D (])
0x08, 0x1C, 0x36, 0x63, 0x00, 0x00, 0x00, 0x00, // U+005E (^)
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, // U+005F (_)
0x0C, 0x0C, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, // U+0060 (`)
0x00, 0x00, 0x1E, 0x30, 0x3E, 0x33, 0x6E, 0x00, // U+0061 (a)
0x07, 0x06, 0x06, 0x3E, 0x66, 0x66, 0x3B, 0x00, // U+0062 (b)
0x00, 0x00, 0x1E, 0x33, 0x03, 0x33, 0x1E, 0x00, // U+0063 (c)
0x38, 0x30, 0x30, 0x3e, 0x33, 0x33, 0x6E, 0x00, // U+0064 (d)
0x00, 0x00, 0x1E, 0x33, 0x3f, 0x03, 0x1E, 0x00, // U+0065 (e)
0x1C, 0x36, 0x06, 0x0f, 0x06, 0x06, 0x0F, 0x00, // U+0066 (f)
0x00, 0x00, 0x6E, 0x33, 0x33, 0x3E, 0x30, 0x1F, // U+0067 (g)
0x07, 0x06, 0x36, 0x6E, 0x66, 0x66, 0x67, 0x00, // U+0068 (h)
0x0C, 0x00, 0x0E, 0x0C, 0x0C, 0x0C, 0x1E, 0x00, // U+0069 (i)
0x30, 0x00, 0x30, 0x30, 0x30, 0x33, 0x33, 0x1E, // U+006A (j)
0x07, 0x06, 0x66, 0x36, 0x1E, 0x36, 0x67, 0x00, // U+006B (k)
0x0E, 0x0C, 0x0C, 0x0C, 0x0C, 0x0C, 0x1E, 0x00, // U+006C (l)
0x00, 0x00, 0x33, 0x7F, 0x7F, 0x6B, 0x63, 0x00, // U+006D (m)
0x00, 0x00, 0x1F, 0x33, 0x33, 0x33, 0x33, 0x00, // U+006E (n)
0x00, 0x00, 0x1E, 0x33, 0x33, 0x33, 0x1E, 0x00, // U+006F (o)
0x00, 0x00, 0x3B, 0x66, 0x66, 0x3E, 0x06, 0x0F, // U+0070 (p)
0x00, 0x00, 0x6E, 0x33, 0x33, 0x3E, 0x30, 0x78, // U+0071 (q)
0x00, 0x00, 0x3B, 0x6E, 0x66, 0x06, 0x0F, 0x00, // U+0072 (r)
0x00, 0x00, 0x3E, 0x03, 0x1E, 0x30, 0x1F, 0x00, // U+0073 (s)
0x08, 0x0C, 0x3E, 0x0C, 0x0C, 0x2C, 0x18, 0x00, // U+0074 (t)
0x00, 0x00, 0x33, 0x33, 0x33, 0x33, 0x6E, 0x00, // U+0075 (u)
0x00, 0x00, 0x33, 0x33, 0x33, 0x1E, 0x0C, 0x00, // U+0076 (v)
0x00, 0x00, 0x63, 0x6B, 0x7F, 0x7F, 0x36, 0x00, // U+0077 (w)
0x00, 0x00, 0x63, 0x36, 0x1C, 0x36, 0x63, 0x00, // U+0078 (x)
0x00, 0x00, 0x33, 0x33, 0x33, 0x3E, 0x30, 0x1F, // U+0079 (y)
0x00, 0x00, 0x3F, 0x19, 0x0C, 0x26, 0x3F, 0x00, // U+007A (z)
0x38, 0x0C, 0x0C, 0x07, 0x0C, 0x0C, 0x38, 0x00, // U+007B ({)
0x18, 0x18, 0x18, 0x00, 0x18, 0x18, 0x18, 0x00, // U+007C (|)
0x07, 0x0C, 0x0C, 0x38, 0x0C, 0x0C, 0x07, 0x00, // U+007D (})
0x6E, 0x3B, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // U+007E (~)
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, // U+007F (block)
// Routine to print a single character in one of 8 columns
// Inputs:
// x is one of (0,16,24,32,40,48,56),
// y (0 to 16 or 24 depending upon font size),
// n is either (0 to 9) or an ascii value,
// font=0 for big font, 2 for small font,
// inverse is true for an inverted character
void drawChar(uint16_t x, uint16_t y, byte n, byte font, boolean inverse) {
byte charbytes[16], fontrows, xover8 = x>>3;
int index;
if (0 != (x % 8)) return; // x not a multiple of 8
if ((n>9) && (n<32)) return; // invalid character
if (font==2) fontrows=16; else fontrows=8;
if ((n>=0) && (n<=9)) index=(n+16)*fontrows; else index=(n-32)*fontrows; // go to the right code for this character
// addressing start at buffer and add y (rows) * (WIDTH is 64 so WIDTH/8) is 8 plus (x / 8) is 0 to 7
byte *pDst = buffer + (y << 3) + xover8;
for (byte i=0;i<fontrows;i++) { // fill up the charbytes array with the right bits
if (font==0) charbytes[i] = pgm_read_byte(&(font8x8_basic[index+i]));
// if (font==1) charbytes[i] = pgm_read_byte(&(font8x8_extended[index+i]));
if (font==2) charbytes[i] = pgm_read_byte(&(font8x16_basic[index+i]));
// reverse bit order for fonts 0 and 1
if (font != 2) {
charbytes[i] = (charbytes[i] & 0xF0) >> 4 | (charbytes[i] & 0x0F) << 4;
charbytes[i] = (charbytes[i] & 0xCC) >> 2 | (charbytes[i] & 0x33) << 2;
charbytes[i] = (charbytes[i] & 0xAA) >> 1 | (charbytes[i] & 0x55) << 1;
if (inverse) charbytes[i] = ~charbytes[i];
const byte *pSrc = charbytes; // point at the first set of 8 pixels
for (byte i=0; i<fontrows; i++) {
*pDst = *pSrc; // populate the destination byte
pDst += 8; // go to next row on buffer
pSrc++; // go to next set of 8 pixels in character
void moveLeft(byte pixels, byte rowstart, byte rowstop) { // routine to move certain rows on the screen "pixels" pixels to the left
byte row, column;
short unsigned int address;
for (column=0;column<8;column++) {
for (row=rowstart;row<rowstop;row++) {
address = (row<<3) + column; /// right here!
if (column==7)
buffer[address] = buffer[address]<<pixels; // shuffle pixels left on last column and fill with a blank
else { // shuffle pixels left and add leftmost pixels from next column
byte incomingchar = buffer[address+1];
for (byte x=0;x<pixels;x++) { buffer[address] += ((incomingchar & (128>>x)) >> (7-x))<<(pixels-x-1); };
// set a single pixel on or off
void setPixel(byte x, byte y, byte colour) { bitWrite(buffer[(y<<3)+(x>>3)],7-(x&7),colour); };
void drawRect(byte x1, byte y1, byte x2, byte y2, byte colour) {
for (byte x=x1;x<=x2;x++) { setPixel(x,y1,colour); setPixel(x,y2,colour); };
for (byte y=y1;y<=y2;y++) { setPixel(x1,y,colour); setPixel(x2,y,colour); };
void shiftOut(byte row) { // fast routine to shove out 8 columns into two rows via board's shift registers
for(byte column=0;column<8;column++) {
byte index = column + (row<<3);
for(byte i=0;i<8;i++) {
PORTB &=~(3<<(data_R1-8)); // data_R2 is LOW; data_R1 is LOW;
PORTB &=~(1<<(clockPin-8)); // digitalWrite(clockPin,LOW);
PORTB |= !((buffer[index]>>(7-i)) & 0x01) << (data_R1-8); // top set of rows
PORTB |= !((~buffer[index+128]>>(7-i)) & 0x01) << (data_R2-8); // bottom set of rows
PORTB |= 1<<(clockPin-8); // digitalWrite(clockPin,HIGH);
// Scan a pair of rows on to the display from "buffer" via the interrupt
ISR(TIMER2_COMPA_vect){
cli();
digitalWrite(en_74138, HIGH); // Turn off display
shiftOut(ScanRow); // Shift out 8 columns
digitalWrite(latchPin, LOW);
digitalWrite(latchPin, HIGH);
PORTD = (ScanRow << 3) | (PORTD & 0X87); // Highlight row: pins 3 4 5 6 (la_74138 lb_74138 lc_74138 ld_74138)
digitalWrite(en_74138, LOW); // Turn on display
ScanRow++; // Do the next pair of rows next time this routine is called
if (ScanRow==16) ScanRow=0;
sei();
// Set up Timer2 as the scanning interrupt timer
cli(); // clear interrupts
TCCR2A = 0; TCCR2B = 0; TCNT2 = 0;
TCCR2B |= (1 << CS12) | (1 << CS10); // Set 1024 prescaler
// 160Hz scan rate = 10 frames/second (16 pairs of rows)
OCR2A = 97; // 97 = (16,000,000 / (1024*160)) - 1
TCCR2A |= (1 << WGM21); TIMSK2 |= (1 << OCIE2A);
pinMode(latchPin,OUTPUT); pinMode(clockPin,OUTPUT);
pinMode(data_R1,OUTPUT); pinMode(data_R2,OUTPUT);
pinMode(en_74138,OUTPUT);
pinMode(la_74138,OUTPUT); pinMode(lb_74138,OUTPUT);
pinMode(lc_74138,OUTPUT); pinMode(ld_74138,OUTPUT);
digitalWrite(data_R1, HIGH); digitalWrite(data_R2, HIGH);
counter = millis();
sei(); //allow interrupts
// Note that there's no need to do anything with the screen in the main loop.
// Whatever's in "buffer" is constantly scanned out.
static int count=0;
byte seconds, colour;
// display clock
drawChar(56,16,message1[count%(sizeof(message1)-1)],0,false);
for (byte i=0; i<7; i++) {
delay(100);
moveLeft(1,16,32);
// display next character of message
drawChar(56,24,message[count%(sizeof(message)-1)],0,false);
count = (count + 1);
// move the text 7 pixels (not 8 because it looks better) to the left
for (byte i=0; i<1; i++) {
delay(50);
moveLeft(1,24,32);
