Таймер в функции
Сб, 11/01/2014 - 21:55
Использую такой код для обработки нажатий кнопки. Может не самый удачный(большой размер), но работает.
#define buttonPin 8
#define ledPin1 4
#define ledPin2 5
#define ledPin3 6
#define ledPin4 7
boolean ledVal1 = false;
boolean ledVal2 = false;
boolean ledVal3 = false;
boolean ledVal4 = false;
pinMode(buttonPin, INPUT);
digitalWrite(buttonPin, HIGH );
pinMode(ledPin1, OUTPUT);
digitalWrite(ledPin1, ledVal1);
pinMode(ledPin2, OUTPUT);
digitalWrite(ledPin2, ledVal2);
pinMode(ledPin3, OUTPUT);
digitalWrite(ledPin3, ledVal3);
pinMode(ledPin4, OUTPUT);
digitalWrite(ledPin4, ledVal4);
int b = checkButton();
if (b == 1) clickEvent();
if (b == 2) doubleClickEvent();
if (b == 3) holdEvent();
if (b == 4) longHoldEvent();
void clickEvent() {
ledVal1 = !ledVal1;
void doubleClickEvent() {
ledVal2 = !ledVal2;
void holdEvent() {
ledVal3 = !ledVal3;
void longHoldEvent() {
ledVal4 = !ledVal4;
int debounce = 20;
int DCgap = 250;
int holdTime = 2000;
int longHoldTime = 5000;
boolean buttonVal = HIGH;
boolean buttonLast = HIGH;
boolean DCwaiting = false;
boolean DConUp = false;
boolean singleOK = true;
long downTime = -1;
long upTime = -1;
boolean ignoreUp = false;
boolean waitForUp = false;
boolean holdEventPast = false;
boolean longHoldEventPast = false;
int checkButton()
int event = 0;
buttonVal = digitalRead(buttonPin);
if (buttonVal == HIGH && buttonLast == LOW && (millis() - upTime) > debounce) {
downTime = millis();
ignoreUp = false;
waitForUp = false;
singleOK = true;
if ((millis()-upTime) < DCgap && DConUp == false && DCwaiting == true) DConUp = true;
else DConUp = false;
DCwaiting = false;
else if (buttonVal == LOW && buttonLast == HIGH && (millis() - downTime) > debounce) {
if (not ignoreUp) {
upTime = millis();
if (DConUp == false) DCwaiting = true;
else {
event = 2;
DConUp = false;
DCwaiting = false;
singleOK = false;
if ( buttonVal == LOW && (millis()-upTime) >= DCgap && DCwaiting == true && DConUp == false && singleOK == true) {
event = 1;
DCwaiting = false;
if (buttonVal == HIGH && (millis() - downTime) >= holdTime) {
if (not holdEventPast) {
event = 3;
waitForUp = true;
ignoreUp = true;
DConUp = false;
DCwaiting = false;
holdEventPast = true;
if ((millis() - downTime) >= longHoldTime) {
if (not longHoldEventPast) {
event = 4;
longHoldEventPast = true;
buttonLast = buttonVal;
return event;
Нужно при длительном нажатии кнопки (hold) не менять состояние светодиода, а чтобы он горел 2 сек. Попытки вставить код из примера " мигаем без задержек" результата не дают - светик горит постоянно. Наверное проблема с таймером - он используется в обработке кнопки. Почитал про Timer1, но как его использовать в данном случае понять не могу. Как решить такую проблемку?
