Tiny GPS++ vs POST-запрос SIM900 GPRS
Пнд, 15/06/2015 - 14:00
Забавная ситуация. Есть исправный код для отсылки POST-запроса на сервер через SIM900 GSM.
Добавляю в код только одну строку "TinyGPSPlus gps; " - сразу после этого POST-запрос не формируется. Может TinyGPSPlus перехватывает управление RX TX для SIM900 GSM?
#include "SIM900.h"
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include "inetGSM.h"
InetGSM inet;
//To change pins for Software Serial, use the two lines in GSM.cpp.
//GSM Shield for Arduino
//www.open-electronics.org
//this code is based on the example of Arduino Labs.
//Simple sketch to start a connection as client.
//CallGSM call;
//SMSGSM sms;
//static const int RXPin = 5, TXPin = 6;
//static const uint32_t GPSBaud = 9600;
//double gpslat;
String double2string(double n, int ndec){
String r = "";
int v = n;
r += v; // whole number part
r += '.'; // decimal point
int i;
for (i=0;i<ndec;i++) {
// iterate through each decimal digit for 0..ndec
n -= v;
n *= 10;
v = n;
r += v;
return r;
String ltd, lnd;
char msg[50];
int numdata;
char inSerial[50];
int i=0;
boolean started=false;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
//SoftwareSerial ss(RXPin, TXPin);
{digitalWrite(9, HIGH);
//ss.begin(GPSBaud);
//Serial connection.
ltd = (double2string (44.391922, 5));
lnd = (double2string (33.794126, 5));
//Read for new byte on serial hardware,
//and write them on NewSoftSerial.
// serialhwread();
//Read for new byte on NewSoftSerial.
// serialswread();
//SoftwareSerial ss(7,8);
Serial.println("GSM Shield testing.");
//Start configuration of shield with baudrate.
//For http uses is raccomanded to use 4800 or slower.
if (gsm.begin(2400)){
Serial.println("\nstatus=READY");
started=true;
Serial.println("\nstatus=IDLE");
if(started){
//GPRS attach, put in order APN, username and password.
//If no needed auth let them blank.
if (inet.attachGPRS("internet.beeline.ru", "", ""))
Serial.println("status=ATTACHED");
Serial.println("status=ERROR");
//Read IP address.
gsm.SimpleWriteln("AT+CIFSR");
delay(5000);
//Read until serial buffer is emapty.
gsm.WhileSimpleRead();
String str = "{\"title\":\"temp31\", \"temperature\": \"";
str += 5;
str += "\",\"latitude\":\"";
str += ltd;
str += "\",\"longitude\":\"";
str += lnd;
str += "\", \"device_id\":\"";
str += 5;
str += "\"}";
int len = str.length()+1;
unsigned char* buf = new unsigned char[len];
str.getBytes(buf, len, 0);
Serial.println((const char*)buf);
numdata=inet.httpPOST("m-ark.kps-dev.com", 80, "/temperature ", (const char*)buf, msg, 50);
delete buf;
//TCP Client GET, send a GET request to the server and
//save the reply.
// numdata=inet.httpPOST("m-ark.kps-dev.com", 80, "/temperature ", "{\"title\":\"temp38\", \"temperature\": \"25\", \"latitude\":\"55.407749\",\"longitude\":\"38.866600\", \"device_id\":\"28\"}",msg,50);
//Print the results.
Serial.println("\nNumber of data received:");
Serial.println(numdata);
Serial.println("\nData received:");
Serial.println(msg);
