Вкл/выкл эл. манит
Сб, 11/04/2015 - 08:38
// Инициализируем цифровой вход/выход в режиме выхода.
pinMode(65, OUTPUT);
if ("команда" = R1)
digitalWrite(65, HIGH); // вкл эл. магнит
if ("команда" = R0)
digitalWrite(65, LOW); // выкл. эл. магнит
// А ВОТ ОСНОВНОЙ КОД
// Makelangelo - supports raprapdiscount RUMBA controller
// dan@marginallycelver.com 2013-12-26
// RUMBA should be treated like a MEGA 2560 Arduino.
// Copyright at end of file. Please see
// http://www.github.com/MarginallyClever/Makelangelo for more information.
// INCLUDES
#include "MServo.h"
// GLOBALS
Axis a[NUM_AXIES]; // for line()
Axis atemp; // for line()
Motor motors[NUM_AXIES];
Segment line_segments[MAX_SEGMENTS];
Segment *working_seg = NULL;
volatile int current_segment=0;
volatile int last_segment=0;
int step_multiplier;
Servo servos[NUM_SERVOS];
// used by timer1 to optimize interrupt inner loop
int delta[NUM_AXIES];
int over[NUM_AXIES];
int steps_total;
int steps_taken;
int accel_until,decel_after;
long current_feed_rate;
long old_feed_rate=0;
long prescalers[] = {CLOCK_FREQ / 1,
CLOCK_FREQ / 8,
CLOCK_FREQ / 64,
CLOCK_FREQ / 256,
CLOCK_FREQ /1024};
// METHODS
// for reasons I don't understand... if i put this method in the .ino file i get compile errors.
// so I put it here, which forces the externs.
FORCE_INLINE Segment *segment_get_working() {
if(current_segment == last_segment ) return NULL;
working_seg = &line_segments[current_segment];
working_seg->busy=true;
return working_seg;
int get_next_segment(int i) {
return ( i + 1 ) & ( MAX_SEGMENTS - 1 );
int get_prev_segment(int i) {
return ( i + MAX_SEGMENTS - 1 ) & ( MAX_SEGMENTS - 1 );
float max_speed_allowed(float acceleration, float target_velocity, float distance) {
//return sqrt(target_velocity*target_velocity - 2*acceleration*distance);
return target_velocity - acceleration * distance;
* set up the pins for each motor
void motor_setup() {
motors[0].step_pin=60;
motors[0].dir_pin=61;
motors[0].enable_pin=56;
motors[0].limit_switch_pin=37;
motors[0].reel_in = HIGH;
motors[0].reel_out = LOW;
motors[1].step_pin=46;
motors[1].dir_pin=48;
motors[1].enable_pin=62;
motors[1].limit_switch_pin=36;
motors[1].reel_in = HIGH;
motors[1].reel_out = LOW;
int i;
for(i=0;i<NUM_AXIES;++i) {
// set the motor pin & scale
pinMode(motors[i].step_pin,OUTPUT);
pinMode(motors[i].dir_pin,OUTPUT);
pinMode(motors[i].enable_pin,OUTPUT);
// set the switch pin
motors[i].limit_switch_state=HIGH;
pinMode(motors[i].limit_switch_pin,INPUT);
digitalWrite(motors[i].limit_switch_pin,HIGH);
motor_set_step_count(0,0,0);
// setup servos
#if NUM_SERVOS>0
servos[0].attach(SERVO0_PIN);
#endif
#if NUM_SERVOS>1
servos[1].attach(SERVO1_PIN);
#endif
#if NUM_SERVOS>2
servos[2].attach(SERVO2_PIN);
#endif
#if NUM_SERVOS>3
servos[3].attach(SERVO3_PIN);
#endif
#if NUM_SERVOS>4
servos[4].attach(SERVO4_PIN);
#endif
current_segment=0;
last_segment=0;
Segment &old_seg = line_segments[get_prev_segment(last_segment)];
old_seg.a[0].step_count=0;
old_seg.a[1].step_count=0;
old_seg.a[2].step_count=0;
working_seg = NULL;
// disable global interrupts
noInterrupts();
// set entire TCCR1A register to 0
TCCR1A = 0;
// set the overflow clock to 0
TCNT1 = 0;
// set compare match register to desired timer count
OCR1A = 2000; // 1ms
// turn on CTC mode
TCCR1B = (1 << WGM12);
// Set 8x prescaler
TCCR1B |= ( 1 << CS11 );
// enable timer compare interrupt
TIMSK1 |= (1 << OCIE1A);
interrupts(); // enable global interrupts
// turn on power to the motors (make them immobile)
void motor_enable() {
int i;
digitalWrite(motors[i].enable_pin,LOW);
// turn off power to the motors (make them move freely)
void motor_disable() {
int i;
digitalWrite(motors[i].enable_pin,HIGH);
// Change pen state.
void setPenAngle(int pen_angle) {
if(posz!=pen_angle) {
posz=pen_angle;
if(posz<PEN_DOWN_ANGLE) posz=PEN_DOWN_ANGLE;
if(posz>PEN_UP_ANGLE ) posz=PEN_UP_ANGLE;
servos[0].write(posz);
delay(PEN_DELAY);
void recalculate_reverse2(Segment *prev,Segment *current,Segment *next) {
if(current==NULL) return;
if(next==NULL) return;
if (current->feed_rate_start != current->feed_rate_start_max) {
// If nominal length true, max junction speed is guaranteed to be reached. Only compute
// for max allowable speed if block is decelerating and nominal length is false.
if ((!current->nominal_length_flag) && (current->feed_rate_start_max > next->feed_rate_start)) {
float v = min( current->feed_rate_start_max,
max_speed_allowed(-acceleration,next->feed_rate_start,current->steps_total));
current->feed_rate_start = v;
} else {
current->feed_rate_start = current->feed_rate_start_max;
current->recalculate_flag = true;
void recalculate_reverse() {
int s = last_segment;
Segment *blocks[3] = {NULL,NULL,NULL};
while(s != current_segment) {
s=get_prev_segment(s);
blocks[2]=blocks[1];
blocks[1]=blocks[0];
blocks[0]=&line_segments[s];
recalculate_reverse2(blocks[0],blocks[1],blocks[2]);
void recalculate_forward2(Segment *prev,Segment *current,Segment *next) {
if(prev==NULL) return;
// If the previous block is an acceleration block, but it is not long enough to complete the
// full speed change within the block, we need to adjust the entry speed accordingly. Entry
// speeds have already been reset, maximized, and reverse planned by reverse planner.
// If nominal length is true, max junction speed is guaranteed to be reached. No need to recheck.
if (!prev->nominal_length_flag) {
if (prev->feed_rate_start < current->feed_rate_start) {
double feed_rate_start = min( current->feed_rate_start,
max_speed_allowed(-acceleration,prev->feed_rate_start,prev->steps_total) );
// Check for junction speed change
if (current->feed_rate_start != feed_rate_start) {
current->feed_rate_start = feed_rate_start;
void recalculate_forward() {
int s = current_segment;
while(s != last_segment) {
s=get_next_segment(s);
blocks[0]=blocks[1];
blocks[1]=blocks[2];
blocks[2]=&line_segments[s];
recalculate_forward2(blocks[0],blocks[1],blocks[2]);
recalculate_forward2(blocks[1],blocks[2],NULL);
int intersection_time(float acceleration,float distance,float start_speed,float end_speed) {
#if 0
return ( ( 2.0*acceleration*distance - start_speed*start_speed + end_speed*end_speed ) / (4.0*acceleration) );
#else
float t2 = ( start_speed - end_speed + acceleration * distance ) / ( 2.0 * acceleration );
return distance - t2;
#endif
void segment_update_trapezoid(Segment *s,float start_speed,float end_speed) {
if(start_speed<MIN_FEEDRATE) start_speed=MIN_FEEDRATE;
if(end_speed<MIN_FEEDRATE) end_speed=MIN_FEEDRATE;
//int steps_to_accel = ceil( (s->feed_rate_max*s->feed_rate_max - start_speed*start_speed )/ (2.0*acceleration) );
//int steps_to_decel = floor( (end_speed*end_speed - s->feed_rate_max*s->feed_rate_max )/ -(2.0*acceleration) );
int steps_to_accel = ceil( ( s->feed_rate_max - start_speed ) / acceleration );
int steps_to_decel = floor( ( end_speed - s->feed_rate_max ) / -acceleration );
int steps_at_top_speed = s->steps_total - steps_to_accel - steps_to_decel;
if(steps_at_top_speed<=0) {
steps_to_accel = ceil( intersection_time(acceleration,s->steps_total,start_speed,end_speed) );
steps_at_top_speed=0;
steps_to_accel = max(steps_to_accel,0);
steps_to_accel = min(steps_to_accel,s->steps_total);
Serial.print("M"); Serial.println(s->feed_rate_max);
Serial.print("E"); Serial.println(end_speed);
Serial.print("S"); Serial.println(start_speed);
Serial.print("@"); Serial.println(acceleration);
Serial.print("A"); Serial.println(steps_to_accel);
Serial.print("D"); Serial.println(steps_to_decel);
CRITICAL_SECTION_START
if(s->busy==false) {
s->accel_until = steps_to_accel;
s->decel_after = steps_to_accel+steps_at_top_speed;
s->feed_rate_start = start_speed;
s->feed_rate_end = end_speed;
CRITICAL_SECTION_END
void recalculate_trapezoids() {
Segment *current;
Segment *next = NULL;
current = next;
next = &line_segments[s];
if (current) {
// Recalculate if current block entry or exit junction speed has changed.
if (current->recalculate_flag || next->recalculate_flag)
// NOTE: Entry and exit factors always > 0 by all previous logic operations.
segment_update_trapezoid(current,current->feed_rate_start, next->feed_rate_start);
current->recalculate_flag = false; // Reset current only to ensure next trapezoid is computed
// Last/newest block in buffer. Make sure the last block always ends motion.
if(next != NULL) {
segment_update_trapezoid(next, next->feed_rate_start, MIN_FEEDRATE);
next->recalculate_flag = false;
void recalculate_acceleration() {
recalculate_reverse();
recalculate_forward();
recalculate_trapezoids();
#if VERBOSE > 1
//Serial.println("\nstart max,max,start,end,rate,total,up steps,cruise,down steps,nominal?");
Serial.println("---------------");
Segment *next = &line_segments[s];
// Serial.print(next->feed_rate_start_max);
// Serial.print(F("\t")); Serial.print(next->feed_rate_max);
// Serial.print(F("\t")); Serial.print(acceleration);
Serial.print(F("\tS")); Serial.print(next->feed_rate_start);
// Serial.print(F("\tE")); Serial.print(next->feed_rate_end);
Serial.print(F("\t*")); Serial.print(next->steps_total);
Serial.print(F("\tA")); Serial.print(next->accel_until);
int after = (next->steps_total - next->decel_after);
int total = next->steps_total - after - next->accel_until;
Serial.print(F("\tT")); Serial.print(total);
Serial.print(F("\tD")); Serial.print(after);
Serial.print(F("\t")); Serial.println(next->nominal_length_flag==1?'*':' ');
#endif
void motor_set_step_count(long a0,long a1,long a2) {
if( current_segment==last_segment ) {
old_seg.a[0].step_count=a0;
old_seg.a[1].step_count=a1;
old_seg.a[2].step_count=a2;
laststep[0]=a0;
laststep[1]=a1;
laststep[2]=a2;
* Supports movement with both styles of Motor Shield
* @input newx the destination x position
* @input newy the destination y position
void motor_onestep(int motor) {
#ifdef VERBOSE
char *letter="XYZUVW";
Serial.print(letter[motor]);
#endif
digitalWrite(motors[motor].step_pin,HIGH);
digitalWrite(motors[motor].step_pin,LOW);
* Set the clock 2 timer frequency.
* @input desired_freq_hz the desired frequency
* Source: http://letsmakerobots.com/node/28278
* Different clock sources can be selected for each timer independently.
* To calculate the timer frequency (for example 2Hz using timer1) you will need:
FORCE_INLINE void timer_set_frequency(long desired_freq_hz) {
if( desired_freq_hz > MAX_FEEDRATE ) desired_freq_hz = MAX_FEEDRATE;
if( desired_freq_hz < MIN_FEEDRATE ) desired_freq_hz = MIN_FEEDRATE;
if( old_feed_rate == desired_freq_hz ) return;
old_feed_rate = desired_freq_hz;
// Source: https://github.com/MarginallyClever/ArduinoTimerInterrupt
// Different clock sources can be selected for each timer independently.
// To calculate the timer frequency (for example 2Hz using timer1) you will need:
if( desired_freq_hz > 20000 ) {
step_multiplier = 4;
desired_freq_hz >>= 2;
} else if( desired_freq_hz > 10000 ) {
step_multiplier = 2;
desired_freq_hz >>= 1;
} else {
step_multiplier = 1;
long counter_value = ( CLOCK_FREQ / 8 ) / desired_freq_hz;
if( counter_value >= MAX_COUNTER ) {
//Serial.print("this breaks the timer and crashes the arduino");
//Serial.flush();
counter_value = MAX_COUNTER - 1;
} else if( counter_value < 100 ) {
counter_value = 100;
OCR1A = counter_value;
* Process all line segments in the ring buffer. Uses bresenham's line algorithm to move all motors.
ISR(TIMER1_COMPA_vect) {
// segment buffer empty? do nothing
if( working_seg == NULL ) {
working_seg = segment_get_working();
if( working_seg != NULL ) {
// New segment!
// set the direction pins
digitalWrite( MOTOR_0_DIR_PIN, working_seg->a[0].dir );
digitalWrite( MOTOR_1_DIR_PIN, working_seg->a[1].dir );
//move the z axis
servos[0].write(working_seg->a[2].step_count);
// set frequency to segment feed rate
timer_set_frequency(working_seg->feed_rate_start);
current_feed_rate = working_seg->feed_rate_start;
// defererencing some data so the loop runs faster.
steps_total=working_seg->steps_total;
steps_taken=0;
delta[0] = working_seg->a[0].absdelta;
delta[1] = working_seg->a[1].absdelta;
delta[2] = working_seg->a[2].absdelta;
memset(over,0,sizeof(int)*NUM_AXIES);
accel_until=working_seg->accel_until;
decel_after=working_seg->decel_after;
return;
} else {
OCR1A = 2000; // wait 1ms
return;
// move each axis
for(int i=0;i<step_multiplier;++i) {
// M0
over[0] += delta[0];
if(over[0] >= steps_total) {
digitalWrite(MOTOR_0_STEP_PIN,LOW);
over[0] -= steps_total;
digitalWrite(MOTOR_0_STEP_PIN,HIGH);
// M1
over[1] += delta[1];
if(over[1] >= steps_total) {
digitalWrite(MOTOR_1_STEP_PIN,LOW);
over[1] -= steps_total;
digitalWrite(MOTOR_1_STEP_PIN,HIGH);
// make a step
steps_taken++;
// accel
float nfr=current_feed_rate;
if( steps_taken <= accel_until ) {
nfr-=acceleration;
if(nfr<MIN_FEEDRATE) nfr = MIN_FEEDRATE;
} else if( steps_taken > decel_after ) {
nfr+=acceleration;
if(nfr>MAX_FEEDRATE) nfr = MAX_FEEDRATE;
if(nfr!=current_feed_rate) {
current_feed_rate=nfr;
timer_set_frequency(current_feed_rate);
// Is this segment done?
if( steps_taken >= steps_total ) {
// Move on to next segment without wasting an interrupt tick.
working_seg = NULL;
current_segment = get_next_segment(current_segment);
* @return 1 if buffer is full, 0 if it is not.
char segment_buffer_full() {
int next_segment = get_next_segment(last_segment);
return (next_segment == current_segment);
* Uses bresenham's line algorithm to move both motors
void motor_line(long n0,long n1,long n2,float new_feed_rate) {
// get the next available spot in the segment buffer
while( next_segment == current_segment ) {
// the buffer is full, we are way ahead of the motion system
delay(1);
int prev_segment = get_prev_segment(last_segment);
Segment &new_seg = line_segments[last_segment];
Segment &old_seg = line_segments[prev_segment];
new_seg.a[0].step_count = n0;
new_seg.a[1].step_count = n1;
new_seg.a[2].step_count = n2;
new_seg.a[0].delta = n0 - old_seg.a[0].step_count;
new_seg.a[1].delta = n1 - old_seg.a[1].step_count;
new_seg.a[2].delta = n2 - old_seg.a[2].step_count;
new_seg.feed_rate_max = new_feed_rate;
// the axis that has the most steps will control the overall acceleration
new_seg.steps_total = 0;
float len=0;
int i;
new_seg.a[i].dir = (new_seg.a[i].delta < 0 ? motors[i].reel_in:motors[i].reel_out);
new_seg.a[i].absdelta = abs(new_seg.a[i].delta);
len += new_seg.a[i].absdelta * new_seg.a[i].absdelta;
if( new_seg.steps_total < new_seg.a[i].absdelta ) {
new_seg.steps_total = new_seg.a[i].absdelta;
// No steps? No work! Stop now.
if( new_seg.steps_total == 0 ) return;
len = sqrt( len );
float ilen = 1.0f / len;
new_seg.a[i].delta_normalized = new_seg.a[i].delta * ilen;
new_seg.steps_taken = 0;
// what is the maximum starting speed for this segment?
float feed_rate_start_max = MIN_FEEDRATE;
// is the robot changing direction sharply?
// aka is there a previous segment with a wildly different delta_normalized?
if(last_segment != current_segment) {
float cos_theta = 0;
cos_theta += new_seg.a[i].delta_normalized * old_seg.a[i].delta_normalized;
feed_rate_start_max = min( new_seg.feed_rate_max, old_seg.feed_rate_max );
if(cos_theta<0.95) {
if(cos_theta<0) cos_theta = 0;
feed_rate_start_max *= cos_theta;
float allowable_speed = max_speed_allowed(-acceleration, MIN_FEEDRATE, new_seg.steps_total);
// come to a stop for entering or exiting a Z move
if( new_seg.a[2].delta != 0 || old_seg.a[2].delta != 0 ) allowable_speed = MIN_FEEDRATE;
//Serial.print("max = "); Serial.println(feed_rate_start_max);
// Serial.print("allowed = "); Serial.println(allowable_speed);
new_seg.feed_rate_start_max = feed_rate_start_max;
new_seg.feed_rate_start = min(feed_rate_start_max, allowable_speed);
new_seg.nominal_length_flag = ( allowable_speed >= new_seg.feed_rate_max );
new_seg.recalculate_flag = true;
new_seg.busy=false;
// when should we accelerate and decelerate in this segment?
segment_update_trapezoid(&new_seg,new_seg.feed_rate_start,MIN_FEEDRATE);
recalculate_acceleration();
last_segment = next_segment;
void wait_for_empty_segment_buffer() {
while( current_segment != last_segment );
* This file is part of DrawbotGUI.
* DrawbotGUI is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* DrawbotGUI is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with DrawbotGUI. If not, see <http://www.gnu.org/licenses/>.
Немного смуту навел в предыдущем посту (простите по неопытоности)
Продолжу все таки борьбу за вкл/выкл электромагнита.
Имею ардуино управляющую двумя шаговыми двигателями
Построчно посылаются команды в нее она отрабатывает в соответствии с командой.
Хочу придумать новую команду R1 и R0 включить и выключить эл. магнит. Посмотрите - я на правильном пути?
