gy gps6mv2 arduino не работает
Здравствуйте!
Прошу Вашей помощи в решении следуещего вопроса:
подключил модуль gy gps6mv2 к arduino uno (5v gnd rx tx), прошил скетчем:
#include <SoftwareSerial.h>
#include <TinyGPS.h>
/* This sample code demonstrates the normal use of a TinyGPS object.
It requires the use of SoftwareSerial, and assumes that you have a
4800-baud serial GPS device hooked up on pins 3(rx) and 4(tx).
TinyGPS gps;
SoftwareSerial nss(3, 4);
static void gpsdump(TinyGPS &gps);
static bool feedgps();
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
Serial.begin(115200);
nss.begin(9600);
Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
Serial.println("by Mikal Hart");
Serial.println();
Serial.print("Sizeof(gpsobject) = "); Serial.println(sizeof(TinyGPS));
Serial.println();
Serial.println("Sats HDOP Latitude Longitude Fix Date Time Date Alt Course Speed Card Distance Course Card Chars Sentences Checksum");
Serial.println(" (deg) (deg) Age Age (m) --- from GPS ---- ---- to London ---- RX RX Fail");
Serial.println("--------------------------------------------------------------------------------------------------------------------------------------");
bool newdata = false;
unsigned long start = millis();
// Every second we print an update
while (millis() - start < 1000)
if (feedgps())
newdata = true;
gpsdump(gps);
float flat, flon;
unsigned long age, date, time, chars = 0;
unsigned short sentences = 0, failed = 0;
static const float LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
gps.f_get_position(&flat, &flon, &age);
print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 9, 5);
print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 5);
print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
print_date(gps);
print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 8, 2);
print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2);
print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0UL : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : TinyGPS::course_to(flat, flon, 51.508131, -0.128002), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
gps.stats(&chars, &sentences, &failed);
print_int(chars, 0xFFFFFFFF, 6);
print_int(sentences, 0xFFFFFFFF, 10);
print_int(failed, 0xFFFFFFFF, 9);
Serial.println();
char sz[32];
if (val == invalid)
strcpy(sz, "*******");
sprintf(sz, "%ld", val);
sz[len] = 0;
for (int i=strlen(sz); i<len; ++i)
sz[i] = ' ';
if (len > 0)
sz[len-1] = ' ';
Serial.print(sz);
feedgps();
char sz[32];
if (val == invalid)
sz[len] = 0;
if (len > 0)
sz[len-1] = ' ';
for (int i=7; i<len; ++i)
sz[i] = ' ';
Serial.print(sz);
Serial.print(val, prec);
int vi = abs((int)val);
int flen = prec + (val < 0.0 ? 2 : 1);
flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
for (int i=flen; i<len; ++i)
Serial.print(" ");
feedgps();
int year;
byte month, day, hour, minute, second, hundredths;
unsigned long age;
gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
if (age == TinyGPS::GPS_INVALID_AGE)
Serial.print("******* ******* ");
char sz[32];
sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d ",
month, day, year, hour, minute, second);
Serial.print(sz);
feedgps();
int slen = strlen(str);
for (int i=0; i<len; ++i)
Serial.print(i<slen ? str[i] : ' ');
feedgps();
while (nss.available())
if (gps.encode(nss.read()))
return true;
return false;
Светодиод на GPS горит зелёный цветом, но ничего в терминале не отображается, кроме как:
Testing TinyGPS library v. 13
by Mikal Hart
Sizeof(gpsobject) = 115
**** **** ******* ******* **** ******* ******* **** ******* ****** ***** *** 0 0.00 *** 0 0 0
в чём может быть проблема?
И ещё вопрос, как проверить работоспособность самого модуля, т.к. светодиод (питание) наверное ни о чём ещё не говорит (могу ошибаться)...
Два вопроса:
1. Видно ли небо (спутники) с того места, где Вы проводите испытания?
2. В течение какого времени Вы ждали результат? (GPS нужно время на "раскачку")
В подходе. Начинать работу с новым устройством лучше с кода в несколько строк, а не - сразу с несхольких сотен. Вот Вы запустили простыню, а теперь не знаете за что хвататься. Почему не запустить крохотный код, в котором невозможно ошибиться, чтобы просто оценить работоспособность прибора, а потом уж кидаться во все тяжкие?
Запустите и посмотрите.
#include <SoftwareSerial.h> SoftwareSerial nss(3, 4); void setup(void) { Serial.begin(115200); nss.begin(9600); Serial.println("Fun begins:"); } void loop(void) { if (nss.available()) Serial.write(nss.read()); }Если модуль рабочий, он что-нибудь да выдаст. Что он выдаёт можно разобрать, там протокол простой и везде описан.
А если это заработает, значит модуль жив. Тогда уж усложняйте, и то - потихоньку.
Два вопроса:
1. в квартире на подоконике
2. в течении часа
Ничего кроме (как я уже выше писал) светодиода не выдаёт в терминал (arduino uno) при этом на ардуино светодиод не мигает, а постоянно "горит" повторюсь:
как проверить сам модуль на работоспоность?
Вот именно так. В моём скетче нет вообще нифига - просто ретрансляция того, что говорит модуль.
Так что если Вы его правильно подключили (питание, RX-TX не перепутали, скорость порта правильно выставили, и т.п., то он должен что-то выдавать, даже если не поймает спутников.
Давайте подробную фотку подключения.
Фото как получилось, цвета:
красный - питание 5 v
оранжевый - земля
серый - tx
белый - rx
http://rgho.st/7nY8BqTBF
Фото выслал, что не так?
Вы сами на нём что-нибудь видите? Я - нет.
