led matrix p10
Втр, 28/07/2020 - 12:04
Здравствуйте форумчани, бьюсь почти неделю с матрицей p10, как выводить инфу немого понял, пытаюсь запилить свой шрифт, при компиляции выдает ошибку "exit status 1 Ошибка компиляции для платы Arduino/Genuino Uno." Использую библиотеку DMD.h. Подскажите пожалуйста, заранее спасибо.
/*-------------------------------------------------------------------------------------- dmd_clock_readout.cpp Example clock readout project for the Freetronics DMD, a 512 LED matrix display panel arranged in a 32 x 16 layout. Copyright (C) 2011 Marc Alexander (info <at> freetronics <dot> com) See http://www.freetronics.com/dmd for resources and a getting started guide. Note that the DMD library uses the SPI port for the fastest, low overhead writing to the display. Keep an eye on conflicts if there are any other devices running from the same SPI port, and that the chip select on those devices is correctly set to be inactive when the DMD is being written to. USAGE NOTES ----------- - Place the DMD library folder into the "arduino/libraries/" folder of your Arduino installation. - Get the TimerOne library from here: http://code.google.com/p/arduino-timerone/downloads/list or download the local copy from the DMD library page (which may be older but was used for this creation) and place the TimerOne library folder into the "arduino/libraries/" folder of your Arduino installation. - Restart the IDE. - In the Arduino IDE, you can open File > Examples > DMD > dmd_demo, or dmd_clock_readout, and get it running straight away! * The DMD comes with a pre-made data cable and DMDCON connector board so you can plug-and-play straight into any regular size Arduino Board (Uno, Freetronics Eleven, EtherTen, USBDroid, etc) * Please note that the Mega boards have SPI on different pins, so this library does not currently support the DMDCON connector board for direct connection to Mega's, please jumper the DMDCON pins to the matching SPI pins on the other header on the Mega boards. This example code is in the public domain. The DMD library is open source (GPL), for more see DMD.cpp and DMD.h --------------------------------------------------------------------------------------*/ /*-------------------------------------------------------------------------------------- Includes --------------------------------------------------------------------------------------*/ #include <SPI.h> //SPI.h must be included as DMD is written by SPI (the IDE complains otherwise) #include <DMD.h> // #include <TimerOne.h> // #include "fonts\Font5x7.h" //Fire up the DMD library as dmd DMD dmd(1,1); /*-------------------------------------------------------------------------------------- Interrupt handler for Timer1 (TimerOne) driven DMD refresh scanning, this gets called at the period set in Timer1.initialize(); --------------------------------------------------------------------------------------*/ void ScanDMD() { dmd.scanDisplayBySPI(); } /*-------------------------------------------------------------------------------------- Show clock numerals on the screen from a 4 digit time value, and select whether the flashing colon is on or off --------------------------------------------------------------------------------------*/ void ShowClockNumbers( unsigned int uiTime, byte bColonOn ) { dmd.clearScreen(true); dmd.drawChar( 1, 3,'0'+((uiTime%10000)/1000), GRAPHICS_NORMAL ); // thousands dmd.drawChar( 8, 3, '0'+((uiTime%1000) /100), GRAPHICS_NORMAL ); // hundreds dmd.drawChar( 17, 3, '0'+((uiTime%100) /10), GRAPHICS_NORMAL ); // tens dmd.drawChar( 25, 3, '0'+ (uiTime%10), GRAPHICS_NORMAL ); // units if( bColonOn ) dmd.drawChar( 15, 3, ':', GRAPHICS_OR ); // clock colon overlay on else dmd.drawChar( 15, 3, ':', GRAPHICS_NOR ); // clock colon overlay off } /*-------------------------------------------------------------------------------------- setup Called by the Arduino architecture before the main loop begins --------------------------------------------------------------------------------------*/ void setup(void) { //initialize TimerOne's interrupt/CPU usage used to scan and refresh the display Timer1.initialize( 5000 ); //period in microseconds to call ScanDMD. Anything longer than 5000 (5ms) and you can see flicker. Timer1.attachInterrupt( ScanDMD ); //attach the Timer1 interrupt to ScanDMD which goes to dmd.scanDisplayBySPI() //clear/init the DMD pixels held in RAM dmd.clearScreen( true ); //true is normal (all pixels off), false is negative (all pixels on) dmd.selectFont(Font5x7); } /*-------------------------------------------------------------------------------------- loop Arduino architecture main loop --------------------------------------------------------------------------------------*/ void loop(void) { unsigned int ui; // 10 x 14 font clock, including demo of OR and NOR modes for pixels so that the flashing colon can be overlayed ui = 1234; ShowClockNumbers( ui, true ); delay( 1000 ); ShowClockNumbers( ui, false ); delay( 1000 ); ShowClockNumbers( ui, true ); delay( 1000 ); ShowClockNumbers( ui, false ); delay( 1000 ); ui = 2345; ShowClockNumbers( ui, true ); delay( 1000 ); ShowClockNumbers( ui, false ); delay( 1000 ); ShowClockNumbers( ui, true ); delay( 1000 ); ShowClockNumbers( ui, false ); delay( 1000 ); }
Шрифт делал в программе "GLCDFontCreator2". Сам шрифт. https://drive.google.com/file/d/1PSd7eCBOo_LDQ_Z7Ig_UySGit0gXsPIJ/view?usp=sharing
это не весь текст ошибки, промотайте вывод ардуино ИДЕ чуть выше, там должны быть подробности. Если нет - надо включить в опциях Ардуино ИДЕ подробный вывод при компиляции.
приведите текст ошибки полностью.
Если интереснуетесь матрицами P10 - к ним есть библиотека, где прикручены шрифты Adafruit GFX
http://arduino.ru/forum/proekty/dmdstm32-versiya-biblioteki-dmd-dlya-stm32duino
либа для плат СТМ32, но базовые функции работают и на Ардуино Уно
Ошибка секретная, у нас допуска нет.
ошибка тут одна, вот она:
C:\Program Files (x86)\Arduino\libraries\DMD-master/fonts\Font5x7.h:48:26: error: variable 'Font5x7' must be const in order to be put into read-only section by means of '__attribute__((progmem))' static uint8_t Font5x7[] PROGMEM = {английским владеете?
к сожалению нет
к сожалению нет
и даже Гугля нет?... несчастный...
Копируете эту фразу, открываете Гугл-транслейт и вставляете ее туда.
https://translate.google.ru/?hl=en&tab=wT
Но вообще учите английский, без английского в программировании вообще делать нечего, 80% мануалов и почти все даташиты на английском
Все допер загрузилась, почему-то программа не дописывает. Спасибо больше, залились. Буду теперь со шрифтом колдовать. Если не сложно, может подсказать библиотеку для вывода символов, и чтоб можно было управлять местоположением. Я сейчас узаю пример из dmd для часов, возможно что-то по лучше есть, если не сложно, заранее спасибо.
не очень понял, что вам нужно... разве стандартная DMD не умеет выводить символы?
ну вот мои часики ... но, опять же, на СТМ32
ветка про них
http://forum.amperka.ru/threads/%D0%A7%D0%B0%D1%81%D1%8B-%D0%BE%D1%84%D0%B8%D1%81%D0%BD%D1%8B%D0%B5-%D0%BD%D0%B0-stm32-esp-01-p10-dmd.19633/
Если вам не сложно, скинете пожалуйста шрифт. И ваша ссылка не работает.
это проделки движка здешнего сайта.
Только что проверил - скопируйте все символы ссылки из моего сообщения как текст, а не как ссылку - и вставьте в адресную строку браузера, тогда работает. Там по ссылке архив, фонт в том числе
странно, я вставлял отдельно, не заходила, сейчас норм, спасибо большое, за ссылку.
только фонт этот на стандартной DMD библиотеке не пойдет. Хотя его можно легко перерисовать, он очень простой. Я собственно его сам срисовал у какого-то индийца. глядя на картинку и считая пиксели :)
я пытался рисовать, через GLCDFontCreator2. Он не то выводит, что я рисовал. Просто хочется в 2 пикселя, я нашел только в 1 или 2 пикселя.
Подскажите пожалуйста, кто подключал на nodemcu, dmd библиотека подходит?
