usb->arduino->lpt ?
art100
Какие варианты?
1.Делаем тестер на светодиодах.
Я накидал такого кода
// art100 to write test pin centronics Blink leads 2-12
  for(int n=2; n<=12; n++){  pinMode(n, OUTPUT); }
   digitalWrite(n, HIGH);   // turn the LED on (HIGH is the voltage level)
   delay(1000);               // wait for a second
   digitalWrite(n, LOW);    // turn the LED off by making the voltage LOW
   delay(100);               // wait for a second
2.Убедились что ничего не отпалим. Попробуем что-нибудь такое.
// art100 copy other 20140907 code usb->arduino->lpt
const int startup_charsPerLine = 80;
const int startup_num_lines = 2;
byte startup_message[startup_num_lines][startup_charsPerLine] = {
  "This is the startup message. It prints whenever",
  "the Arduino is reset.",
const int charsPerLine = 80;   // this is the max # of chars per line
const int num_lines = 10;
byte message[num_lines][charsPerLine] = {
  "    ",   // blank line
  "This is the normal message. It prints whenever",
  "you connect pin 14 (analog 0) to GND.",
  "  ",  // blank line
  "------------------------------------------------------------------------------",   // a spiffy line
  "1) More message content",
  "II) you can have up to about 80 chars per line ",
// parallel port  = arduino //Centronics Connector
const int nStrobe =  2;//1	1	nStrobe	(input)
const int data_0  =  3;//2	2	Data pin 0	(input)
const int data_1  =  4;//3	3	Data pin 1	(input)
const int data_2  =  5;//4	4	Data pin 2	(input)
const int data_3  =  6;//5	5	Data pin 3	(input)
const int data_4  =  7;//6	6	Data pin 4	(input)
const int data_5  =  8;//7	7	Data pin 5	(input)
const int data_6  =  9;//8	8	Data pin 6	(input)
const int data_7  = 10;//9	9	Data pin 7	(input)
const int nAck    = 11;//10	10	nAck	(output)
const int busy    = 12;//11	11	busy	(output)
                       //18-25	19-30	Ground (-)
const int strobeWait = 2;   // microseconds to strobe for
  pinMode(nStrobe, OUTPUT); digitalWrite(nStrobe, HIGH);       // is active LOW    // set HIGH
  pinMode(data_0,  OUTPUT);
  pinMode(data_1,  OUTPUT);
  pinMode(data_2,  OUTPUT);
  pinMode(data_3,  OUTPUT);
  pinMode(data_4,  OUTPUT);
  pinMode(data_5,  OUTPUT);
  pinMode(data_6,  OUTPUT);
  pinMode(data_7,  OUTPUT);
  pinMode(nAck,     INPUT);     // is active LOW
  pinMode(busy,     INPUT);
  pinMode(13,      OUTPUT);
  pinMode(14,       INPUT); digitalWrite(14, HIGH);  // analog pin 0 on duemilanove and uno
  resetPrinter();
  printStartupMessage();
  resetPrinter();
  Serial.println("Delay for 5 sec");
  delay(5000);
  Serial.println("Startup complete");
 while(digitalRead(14) == HIGH) {
   // wait
  resetPrinter();
  printMessage();
  resetPrinter();
void printByte(byte inByte) {
  while(digitalRead(busy) == HIGH) {
    // wait for busy to go low
  int b0 = bitRead(inByte, 0);
  int b1 = bitRead(inByte, 1);
  int b2 = bitRead(inByte, 2);
  int b3 = bitRead(inByte, 3);
  int b4 = bitRead(inByte, 4);
  int b5 = bitRead(inByte, 5);
  int b6 = bitRead(inByte, 6);
  int b7 = bitRead(inByte, 7);
  digitalWrite(data_0, b0);        // set data bit pins
  digitalWrite(data_1, b1);
  digitalWrite(data_2, b2);
  digitalWrite(data_3, b3);
  digitalWrite(data_4, b4);
  digitalWrite(data_5, b5);
  digitalWrite(data_6, b6);
  digitalWrite(data_7, b7);
  digitalWrite(nStrobe, LOW);       // strobe nStrobe to input data bits
  delayMicroseconds(strobeWait);
    // wait for busy line to go low
void resetPrinter() {
  Serial.println("Reseting printer...");
  printByte(27); // reset printer
  printByte('E');
  Serial.println("Printer Reset");
void printMessage() {
  digitalWrite(13, HIGH);
  for(int line = 0; line < num_lines; line++) {
    for(int cursorPosition = 0; cursorPosition < charsPerLine; cursorPosition++) {
      byte character = message[line][cursorPosition];
      printByte(character);
      delay(1);
    printByte(10); // new line
    printByte(13); // carriage return
  digitalWrite(13,LOW);
void printStartupMessage() {
  Serial.println("Print start-up mssage");
  for(int line = 0; line < startup_num_lines; line++) {
    for(int cursorPosition = 0; cursorPosition < startup_charsPerLine; cursorPosition++) {
      byte character = startup_message[line][cursorPosition];
      //      delay(1);
    Serial.print("Line ");
    Serial.print(line);
    Serial.println(" printed.");
  Serial.println("Startup message printed");
Железо в порядке.
art100
Какая должна быть программа чтобы от компьютера печатать? Варианты? Скажем HP LaserJet LPT. Я думаю что привязать драйвер допустим HPLaserJet к COM27 не составляет труда ни у кого. А дальше что зашивать в arduino?
Пните ногой куда дальше копать?
toc
драйвер принтера, который предназначен для работы через LPT порт не может работать через COM порт+ардуина. Варианты:
1. изменить устройство так чтобы ОС его определяла как lpt порт.
2. разработать свой драйвер или просто программу для печати ("блокнот" умеющий работать с вашим устройством и подключённым принтером).
MikSer
а не проще комовский термопринтер подключить? У меня классно он работает.
http://www.adafruit.com/product/597
art100
Какое-то грустное решение. Все варианты сходятся к usb-atmega8-lpt  или другими словами Травить платку искать atmega8 кварц12МГц кандер резисторы пара диодов
Вариант с Кипарисом(cupres) который прошивку каждый раз подгружает перед работой ради скорости странный. Делал я на нем осцилограф и 3Dочки работали ну там скорости всегда мало.
Что-то у меня совсем нет желания кварц12 искать по рынкам. Плату паять и в итоге получить глюкалово юсбишное.
Arduino-ами тут совсем не пахнет. :(
art100
MikSer пишет:
хохма в том что я захотел для технологии РисовалкаPCB->LPT->СвободныйЛазерныйПринтерОтХьюлетта->БумажкуЮтугомКГетинаксуПрижат->ХлорноеЖелезоВВанночке->Какую-нибудь чудо платку вытравить. ЛУТ
А в ардуинах в лучшем случае текст выгоняли.
А графика никак.
Я как старый админ всегда от таких переходников плевался.
Чувствую что надо что-нибудь в духе на PCI-E->CH382->DB25(Lin/Win) за 10-20 баксов к принтеру прикупить и успокоится.
Puhlyaviy
Puhlyaviy аватар
art100 пишет:
там где ты скеч спионерил, у них все работает. мотай ниже, там они этот скеч ускорили еще
art100
Puhlyaviy пишет:
art100 пишет:
не видел
я на arduino.cc что-то выковырял какой-то труп без графики
дай если видел
Только что победил связку Windows7(32бита)->rs232->ПолКилоЖелезаИзПринтераВыкинулНаДурныеДаташитыMAXIM232поплевалсяПоплевалсяcHPдибильныхДебильныхСайтовНалистался->rs232->HPLaserJet4P
Короче Косяки не только в том что на DTR сигналы уже можно забить, но и XON/XOFF у ХьюлеттовПаккардов не гарантирется на стандартных вындо 9600. Вот у меня 57600 работает и все остальные скорости вот такой прикол нет. Можетлюминисцентная лампа так влияла? Еще короче. Не верю ничему. Все сам проверяю. Еще короче фото.
Puhlyaviy
Puhlyaviy аватар
Чего дать то, ты ту тему на arduino.cc дальше прочитай.
art100
Puhlyaviy пишет:
щас поищу ссылку там вроде две с кодом были
art100
код от куда брал не нашел
Чувствую что в этой цепочке Win7->HP древний прокалдывай не прокладывай arduino ни чего надежного или быстрого не получить. Ключевые слова
arduino
LPT
Надежно
или Быстро
не получить
