Велосипедный спидометр Arduino
stels
приветствую
есть проект
Велосипедный спидометр на Arduino
и ссылка на оригинал статьи
Arduino Bike Speedometer
я немного переделал код под км/ч и не serial lcd, у меня получилось это
//bike speedometer
//by Amanda Ghassaei 2012
//http://www.instructables.com/id/Arduino-Bike-Speedometer/
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 3 of the License, or
* (at your option) any later version.
//outputs speed of bicycle to LCD
//calculations
//tire radius ~ 13.5 inches
//circumference = pi*2*r =~85 inches
//max speed of 35mph =~ 616inches/second
//max rps =~7.25
#define reed A0//pin connected to read switch
#include <LiquidCrystal.h>//установил обычный дисплей
LiquidCrystal lcd(12, 11, 5, 4, 3, 6);
//storage variables
int reedVal;
long timer = 0;// time between one full rotation (in ms)
float mph = 0.00;
float circumference;
boolean backlight;
int maxReedCounter = 100;//min time (in ms) of one rotation (for debouncing)
int reedCounter;
void setup(){
reedCounter = maxReedCounter;
circumference = 2095; //здесь явно задал окружность
pinMode(1,OUTPUT);//tx
pinMode(2,OUTPUT);//backlight switch
pinMode(reed, INPUT);
lcd.begin(16, 2);
Serial.write(12);//clear
// TIMER SETUP- the timer interrupt allows preceise timed measurements of the reed switch
//for mor info about configuration of arduino timers see http://arduino.cc/playground/Code/Timer1
cli();//stop interrupts
//set timer1 interrupt at 1kHz
TCCR1A = 0;// set entire TCCR1A register to 0
TCCR1B = 0;// same for TCCR1B
TCNT1 = 0;
// set timer count for 1khz increments
OCR1A = 1999;// = (1/1000) / ((1/(16*10^6))*8) - 1
// turn on CTC mode
TCCR1B |= (1 << WGM12);
// Set CS11 bit for 8 prescaler
TCCR1B |= (1 << CS11);
// enable timer compare interrupt
TIMSK1 |= (1 << OCIE1A);
sei();//allow interrupts
//END TIMER SETUP
ISR(TIMER1_COMPA_vect) {//Interrupt at freq of 1kHz to measure reed switch
reedVal = digitalRead(reed);//get val of A0
if (reedVal){//if reed switch is closed
if (reedCounter == 0){//min time between pulses has passed
mph = (3.6*float(circumference))/float(timer);//calculate miles per hour // и переделал формулу
timer = 0;//reset timer
reedCounter = maxReedCounter;//reset reedCounter
else{
if (reedCounter > 0){//don't let reedCounter go negative
reedCounter -= 1;//decrement reedCounter
else{//if reed switch is open
if (timer > 2000){
mph = 0;//if no new pulses from reed switch- tire is still, set mph to 0
else{
timer += 1;//increment timer
void displayMPH(){
lcd.clear();//clear
lcd.print("Speed =");
lcd.setCursor(0, 1);
lcd.print(mph);
//Serial.write(" MPH ");
//Serial.write("0.00 MPH ");
void loop(){
//print mph once a second
displayMPH();
подскажите, я правильно провел вычисления?
как можно добавить одометр?
stels
извиняюсь за форматирование, пока нет возможности вставить в нормальном, позже поправлю
stels
новая версия
//bike speedometer
//<a href="http://www.instructables.com/id/Arduino-Bike-Speedometer/" rel="nofollow">http://www.instructables.com/id/Arduino-Bike-Speedometer/</a>
//calculations
//max rps =~7.25
//storage variables
int reedVal;
int odo;//количество оборотов колеса
float mph = 0.00;
boolean backlight;
char vivod;
int reedCounter;
void setup(){
  odo=0;
  lcd.begin(16, 2);
  //for mor info about configuration of arduino timers see <a href="http://arduino.cc/playground/Code/Timer1" title="http://arduino.cc/playground/Code/Timer1" rel="nofollow">http://arduino.cc/playground/Code/Timer1</a>
  TCNT1 = 0;
  // turn on CTC mode
  //END TIMER SETUP
      odo++;
    else{
  if (timer > 2000){
  else{
void displayMPH(){
  lcd.clear();//clear
  lcd.print("Speed ");
  lcd.setCursor(6, 0);
  lcd.print(mph);
  lcd.print(String(byte(odo*circumference/1000000))+"km  "+int(odo*circumference/1000)+"m");
 /* lcd.setCursor(9, 1);
  lcd.print(int(odo*circumference/1000));*/
void loop(){
  displayMPH();
stels
и еще маленький вопрос, как лучше записать данные в eeprom, что-бы не использовать лишний раз цикл записи-чтения?
в идеале бы при выключени, но как это сделать пока не знаю
maksim
stels пишет:
Контроль питания + ионистор.
std
Можно сделать выключатель по кнопке, с КМОП-триггером (4043 к примеру), или уход в SLEEP_MODE_PWR_DOWN, а перед этим писать в EEPROM. Но тогда больше актуально на 8 МГц и с трёхвольтовым экраном, чтобы не греть окружающее пространство всякими step-up'ами.
stels
думаю, пару таблеток батареек и контроль питания таки сделать, чтобы батареи только позволили записать данные. Ну и может для часов реального времени. Надо еще подумать над  нормальным дисплеем и заменить уно на что-то миниатюрнее
третья версия прошивки с одометром
//bike speedometer
//<a href="<a href="http://www.instructables.com/id/Arduino-Bike-Speedometer/" rel="nofollow">http://www.instructables.com/id/Arduino-Bike-Speedometer/</a>" rel="nofollow"><a href="http://www.instructables.com/id/Arduino-Bike-Speedometer/" rel="nofollow">http://www.instructables.com/id/Arduino-Bike-Speedometer/</a></a>
//calculations
//max rps =~7.25
//storage variables
int reedVal;
float mph = 0.00;
boolean backlight;
char vivod;
int reedCounter;
void setup(){
  odo=0;
  lcd.begin(16, 2);
  //for mor info about configuration of arduino timers see <a href="<a href="http://arduino.cc/playground/Code/Timer1" rel="nofollow">http://arduino.cc/playground/Code/Timer1</a>" title="<a href="http://arduino.cc/playground/Code/Timer1" rel="nofollow">http://arduino.cc/playground/Code/Timer1</a>" rel="nofollow"><a href="http://arduino.cc/playground/Code/Timer1" rel="nofollow">http://arduino.cc/playground/Code/Timer1</a></a>
  TCNT1 = 0;
  // turn on CTC mode
  //END TIMER SETUP
      odo++;
    else{
  if (timer > 2000){
  else{
void displayMPH(){
  lcd.clear();//clear
  lcd.print(mph);
  lcd.print(String(byte(odo*circumference/1000000))+"km "+int(odo*(int(circumference)%1000000))/1000+"m"); //здесь одометр, отдельно км и м, вычислить именно метры элегантней способа не нашел
  lcd.setCursor(11, 1);
  lcd.print(odo);//вывод оборотов колеса для отладки
void loop(){
  displayMPH();
adel
adel аватар
доброго времени суток
не силен особо в программировании, но задача стоит аналогичная, скопировал - все работает - спасибо, но хочу разобраться в сути
в принципе код достаточно понятен, не понятно только со строки 53
053   //set timer1 interrupt at 1kHz
054   TCCR1A = 0;// set entire TCCR1A register to 0
055   TCCR1B = 0;// same for TCCR1B
056   TCNT1 = 0;
057   // set timer count for 1khz increments
058   OCR1A = 1999;// = (1/1000) / ((1/(16*10^6))*8) - 1
059   // turn on CTC mode
060   TCCR1B |= (1 << WGM12);
061   // Set CS11 bit for 8 prescaler
062   TCCR1B |= (1 << CS11);
063   // enable timer compare interrupt
064   TIMSK1 |= (1 << OCIE1A);
065
066   sei();//allow interrupts
067
  //END TIMER SETUP
 что означает значение TCCR1A (1B); TCNT и другие сокращения?
dimax
dimax аватар
adel, это настройка таймера. Все непонятные сокращения -названия регистров. Общая суть  его -запускать каждую миллисекунду функцию ISR(Timer1
adel
adel аватар
по сути это функция? если я правильно понял
bwn
adel пишет:
Неа, по сути, это команды.
adel
adel аватар
опять возвращаюсь к данному скетчу
собрал код, собрал на LCD1602 - работает
пересобрал все на TFT не без помощи участников форума
пин перебил на А5 - так как А0 занят экраном - не обойти пока мне его
собрал - почти работает
почти заключается в том что он считает мне скорость 74 миль/час
одометр верно считает заданное растояние
 это все происходит при том что я ничего не делаю - отключаю геркон - продолжает считать
код перелопатил - считывание задано с А5 - куда копать?
может что то с пином не так?
stels
я вот думаю, вкоде delay надо убрать для нормально работающего одометра, пока он тормозит работу контроллера, обороты не считаются-же?
adel
adel аватар
решил вопрос
немного не правильно собрал аппаратную часть и поэтому ток постоянно шел мимо геркона параллельно
jeka_tm
jeka_tm аватар
чик чик - измерил время - пересчитал в скорость - вывел. врядли колесо будет крутится быстрее чем посчитает ардуина
adel
adel аватар
ну у меня применение не к велосипеду, а к мото
но все же у меня нет скоростей больше 150
jeka_tm
jeka_tm аватар
какой внешний диаметр колеса?
adel
adel аватар
21" только обод
stels
jeka_tm пишет:
void loop(){
114   //print mph once a second
115   displayMPH();
116   delay(1000);
117
ну вот, посчитал, вывел, ждем 1000мс. За это время пару обороов может пропустить, проще запомнить значение millis и выводить, когда millis будет больше на тысячу запомненного состояния millis.
я сейчас вообще пытаюсь не использовать в программах delay, где больше трех строк кода
jeka_tm
jeka_tm аватар
а я и не говорил про delay
прерывание. на колесе магнит например. на ободе датчик холла или катушка просто. далее согласующая цепи-2 или 3 пин ардуино - дисплей
куда проще. достаточно примеры посмотреть чтобы сделать
stels
понял теперь
а яписал, что контроллер тормозится после каждого вывода значения на дисплей и на целую секунду, мне кажется это не правильным
вот у меня с пониманием кода именно посчитать время между двумя импульсами туго(, поэтому я тупо нашел чужой код и нагло скопировал.
jeka_tm
jeka_tm аватар
ну сам тогда думай))
adel
adel аватар
сижу перечитываю код более углубленно уже и тут наткнулся на такие строки
077     if (reedCounter == 0){//min time between pulses has passed
078      mph = (3.6*float(circumference))/float(timer);//calculate miles per hour // и переделал формулу
так вот, в первоисточнике в строке вместо 3.6 было значение 56,8
я понимаю что 3.6 это производная от 3600 / 1000, но это значение справедливо при переводе м/с в км/ч
а мы указываем значение колеса в чем? в м? или все же в мм (судя по цифре именно в мм)
а время отсчета считается в "мкс" или в "мс" или в "с"?
собственно вот такой и вопрос
VitalikNic
Зачем юзать чужой код давайте вместе создадим свой
Для начала определимся что хотим получить ?
Я такойже програмиист ка и все, даже хуже, пока пробую все на экране 16/2
Обрисуя как я вижу велокомпьютер экран от 5110 плата
NANO 3.0 и любой контроллер литий ионной батареи. Корпус будет такойже но чуть больше
http://www.thingiverse.com/thing:188205
Первым делом хочу определится с алгоритмо как правельнее или удобнее мерять растояние пройденное за время
adel
adel аватар
5110 экран мне не совсем подходит, я бы из OLED собрал себе экран, но тоже не аис
пока ищу экран подобно 5110 но которыи не бликует на солнсе и большими размерами
по поводу кода, тоже бы поучаствовал бы, но не силен в этом
VitalikNic
Так, нашел пример работы таймера свое ничего не получилось взял готовый
Самое обидное в этом, что совсем не чего не понятно
  TCNT1  = 0;
  // turn on CTC mode
  //END TIMER SETUP
Теперь в томже примере который можно использовать проверку на срабатывания геркона
Сдесь все боле мене понятно
ISR(TIMER1_COMPA_vect) {//Прерывание на частота 1 кГц для проверки геркона
  if(analogRead(reed) >= 680 && analogRead(reed) <= 742){//Геркон замкнут при таких показаниях
    reedVal = true;
  }else{
    reedVal = false;
if (reedVal){//Геркон замкнут
if (timer > 110){
   moving = true;
if (reedCounter == 0){//Минимальное время между импульсами прошло
     if(moving){
      kmh = (56.8*float(circumference))/float(timer)*1.61;//километры в час
      distance += deltaD;
      distanceBuffer
      reedCounter = maxReedCounter;//Сбрасываем reedCounter
      timer = 0;//Сбрасываем таймер геркона
  } else{
      if (reedCounter > 0){//Не улетаем в минуса
        reedCounter -= 1;//Уменьшаем reedCounter
  }else{//Если геркон не замкнут
  if (timer > 2000){
    kmh = 0;//Если долго нет сигналов от геркона, мы стоим.
    moving = false;
  }else{
    timer += 1;//Увеличиваем таймер
Переделаю все под LCD 16/2? пока едет экран 5110
adel
adel аватар
VitalikNic пишет:
ну на верху темы этот де код мусолится
adel
adel аватар
а что если реализовать работу таким образом
запускаем ардуину и счетчик
в момент поступления сигнала от геркона извлекаем из памяти переменную "time1" к примеру (если переменная не записана то принимаем значение равное 0)
и присваиваем значению "time2" реальное значение счетчика
time2 - time1 = Vвремя оборота
вычиляем пройденный путь
вычисляем скорость
выводим на экран
значению "time1" присваемваем значение "time2"
записываем "time1" в память
выполнили задачу запустили заново
VitalikNic
Так дело движется..
Уже есть рабочий пример для экрана 5110 (собирал из кусков на разных форумах)
Прошел первые испытания на макете )))
Напечатал корпус.
Добавит еще осталосось.
1. Меню настройки
2. Добавить измерения напряжения на аккамуляторе Li-Io
3. Еще не разобрался полностью с часами, и  не понятна сама процедура записи и чтения в eerom  (для внешней и внутренней памяти)
4. Не совсем ясно как добавить второй датчик для педалей (нужно ли использовать второй выход для аппаратного пррывания?)
5. Как реализовать энергосбережни (тоесть когда нет срабатывания от датчико в течение допустим 30 сек то контроллер выключал всех потребителей) ?
Как то так.
bodriy2014
bodriy2014 аватар
VitalikNic пишет:
Привет.
Может пригодится, заснял как у меня организованно питание от аккума и измерение на нем напряжения.
https://youtu.be/PdtF6JnS6jo
Корпус прикольный, пока не прочитал пост думал что взяли от сгоревшего китайского велокомпа.
ovaday
Делаю свой проект самокатокомпьютера, возникла проблема с взаимодействием геркона и спидометра, постоянно скачет 0- 16км/ч, хотя колесо раскручиваю равномерно и скорости выше 10км/ч быть попросту не может.
Геркон работает нормально, с подключением тоже проблем нет - проверял. Делаю на nokia 5110LCD, с быстродействием у нее проблем нет, проверял выводом микросекунд - обновляется достаточно оперативно.
Смотреть updateDisplay() смысла нет, скорее всего проблема в ISR(TIMER1_COMPA_vect), хотя может и loop неправильно скорректировал. Сам код:
#include <Adafruit_GFX.h>
#include <Adafruit_PCD8544.h>
Adafruit_PCD8544 display = Adafruit_PCD8544(3,4,5,6,7);
int count=0;
#define reed A3//
//storage variables
float radius = 4;//Радиус шины в дюймах. У 26 дюймовой шины, около 13.5 (магия)
boolean reedVal;
long timer = 0;//Время между оборотами в миллисекундах
float kmh = 0.00;//Скорость в км/ч
int kmhcel = 0;
int kmhost = 0;
float distance = 0;//Дистанция поездки в метрах
long totalDistance = 0;//Дистанция всех поездок в метрах
long totalTime = 0;//Время всех поездок в минутах
float distanceBuffer = 0;//Несохранённая дистанция поездки в метрах
long timeBuffer = 0;//Несохранённое время поездки в секундах
float deltaD;//Проезжаем за оборот в метрах
boolean moving = false; //флаг - едем или нет
long times = 5;//Время езды в секундах
unsigned long prevtimes = 0;
int timem=0;
int hour = 0;
long lastTime = millis();
long cureed = 0;
long prevreed = 0;
long duration = 0;
int maxReedCounter = 70;//Минимальное время в миллисекундах на оборот
int reedCounter;
void setup(void)
  pinMode(10, OUTPUT);//Магия для карты памяти
  deltaD = 2*3.415926535*radius*0.025;//Проезжается за один оборот колеса в метрах
  circumference = 2*3.14*radius;//То же самое, но с меньшей точностью (для измерения скорости) и не в метрах
  pinMode(A0, INPUT);
  TCNT1  = 0;
  // turn on CTC mode
  //END TIMER SETUP
  display.begin();
  display.display(); // show splashscreen
  display.clearDisplay();
  if(analogRead(reed) >= 400 && analogRead(reed) <= 1000){//Геркон замкнут при таких показаниях
    reedVal = true;
  }else{
    reedVal = false;
if (timer > 100){
   moving = true;
     if(moving){
      distance += deltaD;
      distanceBuffer;
  } else{
  if (timer > 3000){
    moving = false;
  }else{
void updateDisplay(){
  display.setContrast(50);
  display.clearDisplay();   // clears the screen and buffer
unsigned long cutimes = millis();
if (cutimes-prevtimes>=1000){times++;prevtimes=cutimes;}
if (times>=60){ timem++; times=0;};
if (timem>=60){ hour++; timem=0;};
  // text display tests
  display.setTextSize(0);
    for (uint8_t i=1; i < 16; i++) {
    display.setCursor(0,i*3-3);
    display.write(22);
  for (uint16_t i=1; i < 15; i++) {
    display.setCursor(77,i*3);
    display.write(22);
  for (uint16_t i=0; i < 82; i++) {
   display.drawPixel(i, 47, BLACK);
  display.setCursor(0,-1);
  display.write(29);
  display.setCursor(77,0);
  display.write(15);
  display.setCursor(52,15);
  display.print("km/h");
  if (timem<10){display.setCursor(51,25); display.print("0"); display.setCursor(57,25);}else{display.setCursor(51,25);};
  display.print(timem);
  display.setCursor(61,25);
  display.print(":");
  if (times<10){display.setCursor(65,25); display.print("0"); display.setCursor(71,25);}else{display.setCursor(65,25);};
  display.print(times);
  display.setCursor(47,25);
  display.print(":");
  display.setCursor(43,25);
  display.print(hour);
    display.setTextSize(4);
  display.setTextColor(BLACK);
  kmhcel = (kmh*100)/100;
  kmhost = ((kmh*1000)/1000)*10;
  if (kmh<10){
    display.setCursor(25,0);
  display.print(kmhcel);
  display.setTextSize(2);
   display.print(".");
   display.print(kmhost%10);
  } else{
    display.setCursor(5,0);
   display.print(".");
   display.print(kmhost%10);};
  display.setTextSize(1);
  display.setCursor(8,35);
  display.print("DST:");
  display.setCursor(32,35);
  if (distance >= 1000){
    display.print(distance/1000);
    display.setCursor(63,35);
    display.print("km");
  } else{
    display.print(distance);
  display.setCursor(70,35);
  display.print("m");
  display.display();
void loop(void)
if (timer <= 110){
  moving = false;//Мы остановились, замкнув геркон
}else{
   moving = true;
  updateDisplay();
//  saveData();
  if (moving){
  int d = (int)((millis()-lastTime));}
Все идет в замкнутом постоянном цикле, без всяких delay, может в этом и есть проблема?
Во всяком случае, надеюсь кто-нибудь поможет поправить код, уже замучался, полностью переписывать заново не хочется, еще больше ошибок и непонятностей будет.
Заранее спасибо.
Andy
Andy аватар
ovaday пишет:
Я бы не стал искать ошибки, а написал снова и по-уму. У меня фантазии не хватило понять глубокий смысл вычислений в строках 154-155. Почему прерывание от таймера, а не от геркона, почему геркон на аналоговом входе, а не на цифровом, почему обновление экрана в каждом цикле, а не раз в секунду, зачем вычисления с плавающей точкой каждую миллисекунду и т.д и т.п????
Ты бы стал искать ошибки в этом опусе?
"Смиеца суслег в ниуютнай норке.
На спинко апракинулсо жучог.
Хахочит йожиг, носецо па горке,
Сафсем с котушег съехал дурачог!
Литайут птичке странныме кругаме,
И ржот кобылко з пенкай иза рта.
Сороконожко дрыгаит нагаме.
Ац смеха слёзке льюцо у крата.
Ржут белачке и падают з диревьеф.
Сава забавно ухает ф дупле.
Хахочит грач да выпаденья перьеф.
И мушко са свирчком нависиле.
Кузнечеги смиююцо в трафке где-то,
Мышонаг, змейко, ящерко и тля...
Стояло жаркое, засушливое лето.
Гарели сцуко канапляные паля..."
Олег М.
Олег М. аватар
Andy пишет:
Сам сочинил или как?
Если сам, то где траву такую забористую берешь?
Пишит исчо!
Или пруфлинк в студию!
Andy
Andy аватар
Первая строка и яндекс в помощь. Здесь другие перлы с комментариями.
