Адаптация ATMEGA1284 к светодиодной матрице
zumer67
есть скетч для мега 2560 мне нужно перенсти его на атмега1284 - есть некоторые морменты мне не понятные.
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
// Arduino Mega is now tested and confirmed, with the following caveats:
// Because digital pins 2-7 don't map to a contiguous port register,
// the Mega requires connecting the matrix data lines to different pins.
// Digital pins 24-29 are used for the data interface, and 22 & 23 are
// unavailable for other outputs because the software needs to write to
// the full PORTA register for speed.  Clock may be any pin on PORTB --
// on the Mega, this CAN'T be pins 8 or 9 (these are on PORTH), thus the
// wiring will need to be slightly different than the tutorial's
// explanation on the Uno, etc.  Pins 10-13 are all fair game for the
// clock, as are pins 50-53.
#define DATAPORT PORTA ///< RGB data PORT register
#define DATADIR DDRA   ///< RGB data direction register
#define CLKPORT PORTB  ///< RGB clock PORT register
#elif defined(__AVR_ATmega32U4__)
// Arduino Leonardo: this is vestigial code an unlikely to ever be
// finished -- DO NOT USE!!!  Unlike the Uno, digital pins 2-7 do NOT
// map to a contiguous port register, dashing our hopes for compatible
// wiring.  Making this work would require significant changes both to
// the bit-shifting code in the library, and how this board is wired to
// the LED matrix.  Bummer.
#define DATAPORT PORTD ///< RGB data PORT register
#define DATADIR DDRD   ///< RGB data direction register
#elif defined(ARDUINO_ARCH_SAMD) || defined(ARDUINO_ARCH_ESP32)
// Support for ATSAMD21-based boards, done with PortType!
#else
// Ports for "standard" boards (Arduino Uno, Duemilanove, etc.)
#endif
из этого следует что матрица по RGB подключена к порту D  а потр тактирования B?
zumer67
вот сама схема проекта
zumer67
далее в скетче указано
// управляющие пины матрицы
#define CLK   1
#define OE    2
#define LAT   3
#define A     A5
#define B     A4
#define C     A3
#define D     A3
это непосредственно ножки микроконтроллера?
Green
atmega1284 arduino pinout
ua6em
ua6em аватар
Онлайн
а в чем проблема добавить:
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__) || defined(__AVR_ATmega1284__)
zumer67
да собственно оно и по умолчанию на этот порт ссылается - вот только тактирование на порт В - поставил на порт А дальше
1
2
#define CLK   1
3
#define OE    2
4
#define LAT   3
5
#define A     A5
6
#define B     A4
7
#define C     A3
8
#define D     A3
тоже поменял
простите, если вы не понимаете, что такое порт А и портВ - зачем лезете менять? чем вам не угодил  порт тактирования В - неужеди у атмеги 1280 нет порта В ?
Скорее всего в коде управление матрицей и тактом идет через регистры - и если вы в заголовке что-то меняете, придется все менять и в коде.
zumer67
вверху схема  - и уже готовая плата - надо адаптировать.  в pic18?dspic33 такой проблемы не существует - а здесь это для меня новый подход.
zumer67
да и чем он там отличается? ну могут же аналоговый входа работать как цифровые!
у вас там на схеме CLK и так подключен к порту В - не пойму. что вы там меняете
zumer67 пишет:
тем, что по программе пины данных матрицы должны быть последовательными выходами одного порта. произвольно их менять нельзя, работать не будет.
Может и CLK тоже ограничение есть.
У меня есть своя библиотека под такие матрицы - так у меня пины данных и клока ДОЛЖНЫ БЫТЬ на одном физическом порту, так алгоритм постоен. На разных портах не заработает.
zumer67
проблемы не закончились - не стартует МК этого достаточно для программирования фьюзов?
zumer67
насколько критичны емкости конденсаторов на осциляторе
zumer67, не надо дублировать вопросы из темы в тему - это нарушение правил.
Я вам в той теме уже ответил.
