exit status 1 Ошибка компиляции для платы Arduino Nano.
Втр, 20/11/2018 - 13:03
C:\Users\Uzer\Downloads\LiveOV7670 (1)\LiveOV7670\LiveOV7670.ino:8:22: fatal error: avr / io.h: No such file or directory
#include <avr / io.h>
compilation terminated.
exit status 1
Preferences:
board=nano
boardsmanager.additional.urls=
build.verbose=true
build.warn_data_percentage=75
compiler.cache_core=true
compiler.warning_level=none
console=true
console.auto_clear=true
console.error.file=stderr.txt
console.length=500
console.lines=4
console.output.file=stdout.txt
custom_cpu=nano_atmega328
editor.antialias=true
editor.caret.blink=true
editor.code_folding=false
editor.divider.size=2
editor.external=false
editor.font=Monospaced,plain,12
editor.indent=true
editor.invalid=false
editor.keys.alternative_cut_copy_paste=true
editor.keys.home_and_end_beginning_end_of_doc=false
editor.keys.shift_backspace_is_delete=true
editor.languages.current=
editor.linenumbers=false
editor.save_on_verify=true
editor.tabs.expand=true
editor.tabs.size=2
editor.update_extension=true
editor.window.height.default=600
editor.window.height.min=290
editor.window.width.default=500
editor.window.width.min=400
export.applet.separate_jar_files=false
export.application.fullscreen=false
export.application.platform=true
export.application.stop=true
export.delete_target_folder=true
gui.scale=auto
last.folder=C:\Users\Uzer\Downloads\LiveOV7670 (1)\LiveOV7670\LiveOV7670.ino
last.ide.1.8.2.daterun=1542703864
last.ide.1.8.2.hardwarepath=C:\Program Files (x86)\Arduino\hardware
last.screen.height=768
last.screen.width=1366
last.serial.location=0,0,1175,378
last.sketch.count=1
last.sketch.default.location=-8,-8,1382,744,536,6
last.sketch.default.path=C:\Users\Uzer\Downloads\LiveOV7670 (1)\LiveOV7670\LiveOV7670.ino
last.sketch0.location=-8,-8,1382,744,536,6
last.sketch0.path=C:\Users\Uzer\Downloads\LiveOV7670 (1)\LiveOV7670\LiveOV7670.ino
last.sketch1.location=-8,-8,1382,744,536,6
last.sketch1.path=C:\Users\Uzer\Downloads\LiveOV7670 (1)\LiveOV7670\LiveOV7670.ino
platform.auto_file_type_associations=true
preproc.color_datatype=true
preproc.enhanced_casting=true
preproc.imports.list=java.applet.*,java.awt.Dimension,java.awt.Frame,java.awt.event.MouseEvent,java.awt.event.KeyEvent,java.awt.event.FocusEvent,java.awt.Image,java.io.*,java.net.*,java.text.*,java.util.*,java.util.zip.*,java.util.regex.*
preproc.output_parse_tree=false
preproc.save_build_files=false
preproc.substitute_floats=true
preproc.substitute_unicode=true
preproc.web_colors=true
ну раз у вас интернета и гугла нет - перевожу - нет такого файла или деректория.
пробелы уберите в <avr / io.h>
Первый кандидад в песочницу: Ошибка No such file or directory
Спасибо за ответ, Просто мы до этого никогда не работали с Ардуино.
Мы подключили Арудино Нано с камерой модуль OV7670 и с помощью Arduino IDE проверили и нам выдал и еще одну ошибку:
C:\Users\Uzer\Downloads\LiveOV7670 (1)\LiveOV7670\LiveOV7670.ino:12:27: fatal error: Adafruit_GFX.h: No such file or directory
а с другими языками программирования?
а ошибка та же - идем на гитхаб, ищем библиотеку на которую компилятор ругается - идем в меню Arduino IDE и согласно инструкции устанавливаем
тоже да, с другими не работали((и поэтому нам трудно
Если вам не трудно, можете посоветовать книги или отправить ссылки по работе ардиуно нано и камеры OV7670 с рассширенной информацией.
Мы искали в интернете, но непонятно и не расширено.
Извините за беспокойство
"мы" ? - вас много?
Похоже, что вопросы задает мама, которая мастерит ардуино с чадом 5 лет? - если да, этот форум для вас мало подходит, тут взрослые дядьки общаются. которые в программировании ХХХ лет :)
Вы всегда за неподъемное беретесь? Типа, первый раз топор взял, полено расколол и пошел Кижи строить. В "Общем" есть тема "Песочница", там ссылки на книжки. Но до камер, там ох как далеко.
Только на этом форуме (!) более 60 ссылок на OV7670.
Но скажу сразу: OV7670 - это не для новичков, и Ардуино Нано не очень подходит для работы с OV7670.
Почитайте на этом форуме тему http://arduino.ru/forum/obshchii/pesochnitsa-dlya-vsekh-novichkov
Постарайтесь найти уроки и внимательно их повторить.
Выберите для реализации проект попроще.
Если дело пойдет, четвертым-пятым проектом моджно будет попытаться поработать и с камерой.
Нет, мы студенты: я и одногруппница.
нам в универе дали такое задание: создать фотомодуль (нано соединили с OV7670, нужно проверить работает ли эта схема через Arduino IDE.
спасибо
Если текст задания воспроизведен точно, то ответ "нет".
